Author Topic: Salvaged keycaps from TA 7007L typewriter  (Read 2972 times)
Offline callofcandy
« on: Wed, 02 March 2016, 16:50:46 »
Hi guys,
I got my hands on a Triumph-Adler 7007L electric typewriter.
The typewriter uses Cherry MY switches and the keycaps fit just perfectly on my Gateron Blues  :)
They are dye sublimated PBT blue on grey.
I made some photos, if you want to ckeck them out.
Cheers
Offline ideus
  • Björkö.
Re: Salvaged keycaps from TA 7007L typewriter
« Reply #1 on: Wed, 02 March 2016, 16:51:46 »
Post your pictures for the community to enjoy and welcome to GH.
Offline jacobolus
« Reply #2 on: Wed, 02 March 2016, 16:54:36 »
Note, you need to use the direct image links when you post images, e.g.:
Code: [Select]
[img]http://i.imgur.com/OddYWB3.jpg[/img]
Here are your four pics:
« Last Edit: Wed, 02 March 2016, 16:57:01 by jacobolus »
Offline callofcandy
« Reply #3 on: Fri, 04 March 2016, 13:42:16 »
Hey, thanks for the welcome and for fixing my pictures! :)
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #4 on: Fri, 04 March 2016, 13:50:08 »
Some nice CYMK mods and a Cyan spacebar..
mmmmm that would look so gooood.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Fri, 04 March 2016, 15:07:47 »
Your spacebar is on backwards! FTFY!  :)) Seriously, very delicious  :)
