Author Topic: best site for typing speed tests??  (Read 4182 times)
Offline Phenix
« on: Sun, 13 March 2016, 13:23:46 »
Hello
Whats the best site for best site for typing speed tests??
If possible I want the following features:
-decide for english/German tests
-possibility to write some infos down, like "which keyboard was used/layout.."
Thanks for!
Winter is coming.
Re: best site for typing speed tests??
« Reply #1 on: Sun, 13 March 2016, 13:42:16 »
10fastfingers
Offline xondat
  • i'm not a star
« Reply #2 on: Sun, 13 March 2016, 13:47:02 »
I don't think any website makes note of board/switches etc but I recommend 10fastfingers like everybody else will.
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Sun, 13 March 2016, 14:53:32 »
Hey, I actually don't recommend 10fastfingers.
It's important to consider, what kind of text you're typing, how the app deals with typos, what stats are calculated in the end, and what the user interface is like.
If there's anything I do recommend, it's Amphetype, because it lets you retype any kind of text you like, has all the advantages of an open-source multiplatform desktop app, keeps a lot of stats and allows generation of new texts based on past typos (or less fluid typing).
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4 on: Sun, 13 March 2016, 15:24:58 »
idk which one is 'best' but here are the sites that I use
Sites I use to warm up:
10fastfingers.com
Typingtest.com
My Average wpm:
Typeracer.com
Offline Phenix
« Reply #5 on: Sun, 13 March 2016, 17:20:54 »
I just meant a comment field to enter some infos for myself (e.g. still trying out different switches - so for comparison)
Will look into thosetomorrow
Winter is coming.
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline bocahgundul
  • a seal
« Reply #7 on: Sun, 13 March 2016, 19:49:40 »
typeracer.com if you want a real typing test  :thumb:
Offline superbia
« Reply #8 on: Mon, 14 March 2016, 14:19:03 »
http://typing-speed-test.aoeu.eu/
if english is not your native language
if you want to type most commonly used english words
if you don't want to bother reading complicated english words (typeracer or any other rice-ing website)
if you just want to view your average typing speed
Knowing your typing speed can be useful when learning a new layout or learning to touch type.
IMHO you should not chase high numbers (above 120), rather focus on getting a more ergonomic layout (like Colemak Mod DH angle mod), and push a constant 70-90 wpm...
Keebio Iris 2.8 (Alps) X Colemak Mod-DH
« Reply #9 on: Mon, 14 March 2016, 14:24:24 »
Haven't seen it mentioned yet, but 10fastfingers.
Also, TypeRacer.
Offline Rad
« Reply #10 on: Mon, 14 March 2016, 19:54:50 »
No one has said it yet, but 10fastfingers.com is a good one.
Offline derb2k2
  • Something of a Topre ****..
« Reply #11 on: Mon, 14 March 2016, 19:57:33 »
if you want a challenge:  http://www.goodtyping.com/test.php
It's cool in that you don't have to press backspace when you make an error since you won't move on until you type the correct letter.
also, another good one is: typeonline.co.uk/typingspeed.php         , throws lots of different characters at you
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
