Author Topic: GH-122.2016 Case Options  (Read 70491 times)
Offline Data
Re: GH-122.2016 Case Options
« Reply #200 on: Wed, 21 December 2016, 13:14:36 »
You're welcome and thank you for the two posts.
Those, my friend, I believe to be stabilizer holes for a Japanese spacebar.  From the bottom row for all people and all situations.  I thought I got rid of those!  Apparently, however, I got rid of the switch position and kept the stabilizers, and then did the reverse for the 6.25.  Grrr.
Anyhow, thanks!
 - Ron | samwisekoi
Auto-typed by my GH-122 keyboard.
Happy to help.  This has been a fun and challenging build from start to finish.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #201 on: Wed, 21 December 2016, 20:06:08 »
Anyone interested in an ANSI/ISO plate?
Semi-universal plate for GH-122.2016-2017.
This plate is designed to the same dimensions as the PCB, and will support standard ANSI with 104 or full function keys, as well as ISO Enter with split right shift.  (The weird slices on the function key cutouts are cutaway ribs to allow 104-style function rows with offset F5-F8.)  It also supports single or double keys in the upper-left block, the numpad, and the backspace.  Stepped and non-stepped Caps keys are supported, and Cherry plate-mount stabilizers for the 6.25 spacebar (using 50mm centers!).
I will probably add guides for cutting the plate to fit the Unicomp case, and to be used in a 5x24 wide-body configuration.
Anyhow, my testing shows that this PCB likes a plate, and for five or more plates, Big Blue Saw wants $82 in raw stainless steel.
I wiil probably have some made for a 2017 run of PCBs, and I wondered if any of the current builders are interested.
Please reply here if this might be for you, and if there is a cutout you think I missed.
Thanks very much,
 - Ron | samwisekoi
I would be interested! What would be the added cost for switch modding cuts?
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #202 on: Thu, 22 December 2016, 10:08:56 »
I don't know, mostly because I've never designed or made a plate with the complicated cut-outs for modding.  Probably because I mod with a soldering iron ;^)
I'll draw up a smaller sample plate both ways and find out the pricing delta for water jet cuts.
Does anyone know of a source for on-line quotes for laser cutting?
 - Ron | samwisekoi
Offline Data
« Reply #203 on: Thu, 22 December 2016, 11:56:27 »
A lot of GeekHackers have been using Lasergist lately with good results.  Have not used them myself.  They are stainless steel only.
http://lasergist.com/
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #204 on: Thu, 22 December 2016, 12:28:13 »
Thanks!  This plate falls into the "contact us" size, so I have contacted them to see about estmated pricing.
Thanks again,
 - Ron | samwisekoi
« Last Edit: Thu, 22 December 2016, 12:42:57 by samwisekoi »
Offline Hak Foo
  • Make America Clicky Again!
« Reply #205 on: Sun, 25 December 2016, 11:25:28 »
One thing you might want to look into with it-- when I did my plate, I found that the price difference to add top and bottom plates was only like $15.  You might want to inquire about economies of scale for including bottom plates, at least; top ones might vary quite a bit.
Overton130, Box Pale Blues.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #206 on: Mon, 26 December 2016, 14:02:23 »
Thank you, yes. That is a very good idea.
My bottom plate would be .250" larger on each side, or .500" taller and .500" wider, but the same material with just a few holes might make things cheaper in volume indeed.
Thanks very much!
 - Ron | samwisekoi
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #207 on: Mon, 26 December 2016, 18:52:27 »
I spent some time this weekend working on a case surround for the GH-122.  This version is 7.0" x 20.0"; 0.50" at the front, rising to 1.00" at the rear.  It is one piece of (currently) 3D-printed "Strong and Flexible Plastic" (sintered nylon).  It is designed to work with or without a plate, and a the builder's choice of an optional layout-specific top cover in 0.125" (3mm) acrylic or other material.  This allows a single case to support all full-board configurations.  The walls are 0.250" (6mm) thick, with a 0.125" thick (3mm) support ridge.  The small cutouts near the corners are only 1/32" deep, and strictly cosmetic.  They are a tip of the design hat to the Model M and Model F from IBM.  Finally, there are six mounting holes on the bottom edge for a 7.0" x 20.0" bottom plate.
I am going to test qty=1 from Shapeways for $115 USD.  Depending on material and volume, a top cover adds $25-45 from Big Blue Saw.
It would be excellent to get this cast in metal, but for now 3D-printing is the plan.
 - Ron | samwisekoi
« Last Edit: Mon, 26 December 2016, 18:56:41 by samwisekoi »
Offline xondat
  • i'm not a star
« Reply #208 on: Mon, 26 December 2016, 19:24:10 »
Hey Sam, dropped you a PM - hopefully you can reply! Thanks.
Offline xondat
  • i'm not a star
« Reply #209 on: Tue, 27 December 2016, 06:34:26 »
Regarding an all-metal case, oddly enough I have an 8x20" chunk of .250" aluminum for a base plate right here.  Not looking forward to cutting and sanding it.  But yeah, all-metal would be awesome!
 - Ron | samwisekoi
6 months late, but I'll have this made when the 2017 GB happens. This version is based around the 2016 files, as that's all that's available, but I'll be able to make the necessary changes for next year. The only thing I'm struggling with is the Teensy++ USB port and where it is in relation (as I don't have a PCB file, only a mid-plate). If anyone could help me with that, then I'd appreciate it.
« Last Edit: Thu, 05 January 2017, 10:59:33 by xondat »
Offline henz
  • What?
« Reply #210 on: Tue, 27 December 2016, 06:36:49 »
shiet, this looks like alot of fun
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #211 on: Tue, 27 December 2016, 15:52:06 »
 - Ron | samwisekoi
Oh and it weighs 3900 grams. Or 8.6 lbs. I was going to add a brass weight, but I think it would take it over 6kg.. so I'll skip that for now. There are 16 (8 each side) top mounting points for the plate, and 10 (5 each side) holes to join the top/bottom. Probably going to have 8 feet as well.
Regarding the LED holes, I know they're too big but I'll add a small acrylic/polycarbonate piece under them to diffuse them and fix that up later when I have more information. The engraving will be quite shallow, .5mm at the minute, as there are quite a lot of small parts to it.
The plate is also not final - I meant to have a winkeyless bottom row, and also a stepped caps, but I forgot when initially starting so I'll edit that later on too. If there are any other things I should change regarding the plate then let me know and I can incorporate it. Oh, and switch opening is a must in my eyes, I can change the style to the image below, or remove it completely too. I'll also clean up the stabilizer holes when I can be bothered.
I'll quickly touch on price - it shouldn't be as bad as mentioned, perhaps only $400 max although that'd be with only 2/3 colors and no plate/top options etc. Removing the brass weigh will lower the price compared to my other cases which is why that price is achievable.
Mane, that's killer  :thumb:
Offline Data
« Reply #212 on: Thu, 29 December 2016, 12:55:30 »
 - Ron | samwisekoi
Wow.  :eek:
Offline 0100010
  • Not Sure
« Reply #213 on: Sun, 06 August 2017, 11:06:54 »
Cross post : I finally (mostly finished) my GH-122 : https://geekhack.org/index.php?topic=80326.msg2470914#msg2470914
    • WTB/WTTF Thread
« Reply #214 on: Sun, 06 August 2017, 17:07:16 »
I'll need the plate file.
Offline 0100010
  • Not Sure
« Reply #215 on: Sun, 06 August 2017, 20:18:35 »
Pretty sure this is the one I had BBS cut for me (attached).  I was not completely happy with the costar stab locations though - had to sand the top side of the key inserts to get clearance (which is an issue I vaguely recall others commenting about using same DXFs from the master CAD thread).
    • WTB/WTTF Thread
« Reply #216 on: Sun, 06 August 2017, 21:15:03 »
Good to know. I am terrible with CAD and would probably be using cherry stabs any way so I guess I would need to confirm the measurements and such
Offline 0100010
  • Not Sure
« Reply #217 on: Sun, 06 August 2017, 21:56:26 »
That DXF has stab cutouts that supports both cherry and costar.
