Author Topic: Share software that makes your life easier.  (Read 49420 times)
Offline dante
Re: Share software that makes your life easier.
« Reply #100 on: Wed, 29 June 2016, 08:51:46 »
Most of you probably prefer having two monitors but I prefer one big one.
VirtualWin is what I use for Virtual Desktop swapping.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #101 on: Wed, 29 June 2016, 17:25:51 »
Two monitors... pssh... gotta have three :D
Offline Maave
« Reply #102 on: Wed, 17 August 2016, 20:06:40 »
Some Chrome addons for work:
MultiHighlighter - like Ctrl+F for multiple strings, each one is highlighted a different color
Linkclump - open multiple links at once
Tampermonkey - write my own javascript to interact with the job website
Other work stuff:
Autohotkey clipboard typer - I deal with a lot of remote machines that don't have clipboard sharing, this types it in anyway
4t Tray Minimizer - hide the background stuff
EitherMouse - settings for multiple mice. Dual wield mice, one for each hand  :cool:
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #103 on: Wed, 17 August 2016, 23:01:00 »
Other work stuff:
I thought I was the only dual wielder/Switch hitter here on GH :D
Offline decker
« Reply #104 on: Fri, 19 August 2016, 01:21:34 »
At last I found a non obsolete mouse gesture software to replace old StrokeIt.
It's called Strokes Plus.
It is a bit harder to configure, but it looks like it is able to do a lot more as you can write scripts and launch them with a mouse gesture.
Mouse gesture if you don't know is a little drawing you do usually with a right click.
For instance G for geekhack ! Or simpler things like next, back, close.
In the past some browsers included them, but with a desktop level software you can use them anywhere and to do almost anything.
