Author Topic: Hewlett/Packard 2645A terminal keyboard  (Read 11141 times)
Offline Red October
« on: Wed, 16 March 2016, 13:53:10 »
Here's another of the keyboards that follow me home from work:  A tired old HP 2645A terminal keyboard, as featured in The Cassandra Crossing.
Compatible with Cherry?  I do not know.  They seem to fit the mounts on my IBM 6112884, though, which I have to say is giving me ideas.
Here's the connector:
Anyone know how this communicates?  Remotely possible to connect to PC?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Hewlett/Packard 2645A terminal keyboard
« Reply #1 on: Wed, 16 March 2016, 13:55:52 »
Oh wow, what switches are those? =o
Offline Red October
« Reply #2 on: Wed, 16 March 2016, 14:03:55 »
I do not know.  I will be glad to post anything that might help find out, though.  For starters they are linear and have a longish travel.  Setting a Zippo lighter on them pushed them down about halfway, and if you push it down it doesn't have the guts to lift the Zippo back up.  Maybe it did when it was new?
Offline quasistellar
« Reply #3 on: Wed, 16 March 2016, 14:11:18 »
The slider picture is kinda blurry, but it could be some black Alps SKCC maybe?
Can you get a better picture of the slider?  Cross or T-shaped?
Oh, and does the top of the slider come off?
« Last Edit: Wed, 16 March 2016, 14:14:26 by quasistellar »
« Reply #4 on: Wed, 16 March 2016, 14:19:46 »
https://deskthority.net/wiki/File:Alps_integrated_membrane_white_side.jpg
Could be one of these but with a black slider.  The indentations on the sides of the switch casing are offset similarly to what I can see in your picture.
Offline chyros
  • a.k.a. Thomas
« Reply #5 on: Wed, 16 March 2016, 14:25:01 »
Looks cross-shaped to me, which would mean no SKCC.
They look a bit like SMK switches or their millions of clones, but the housing sits lower and the clips aren't in the right place. It's possible that it was another SMK clone.
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Wed, 16 March 2016, 14:25:53 »
You're right, they look just like them, but those are tactile, not linear. Maybe a new variant?
« Reply #7 on: Wed, 16 March 2016, 14:36:43 »
Oooo what an interesting board. I too wonder what those switches are. Are you planning on doing a teardown?
Offline jacobolus
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #9 on: Wed, 16 March 2016, 15:08:00 »
Now I'm wondering if those keys are salvageable for modern use. I doubt they would fit on an mx board though :(
Offline chyros
  • a.k.a. Thomas
« Reply #10 on: Wed, 16 March 2016, 16:07:25 »
Some vintage cross mounts actually fit MX switches, but virtually none of them take into account that the stem has to disappear into the switch, so some fit but none will work.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #11 on: Wed, 16 March 2016, 16:12:47 »
I see now. That's a bummer. Still a nice find
Offline chyros
  • a.k.a. Thomas
« Reply #12 on: Wed, 16 March 2016, 16:22:21 »
I know right, I have some virtually solid MX-compatible keycaps that put Honeywells to shame, was gutted when I found they wouldn't work D: .
Offline Red October
« Reply #13 on: Wed, 16 March 2016, 16:53:34 »
I really don't know if they'd fit Cherry MX, I don't have any such board.  If someone wants to gift me one so I can try, well I would graciously accept!  :p
They work fine on a 6112884, with a little TI99/4A thrown in to get the correct legends on the number keys.  I actually find this more agreeable to type on than the default keycaps on the 6112884.  I am happy.  The TI keys are sunken compared to the HPs.  I'll see if this becomes a problem in practice.  It's just a shame that I couldn't get more of the larger keys involved here; the TI just has no large keys besides right shift and the HP wasn't exactly flush with them as well, and while the "cursor fast" key might be the right width for left shift on the 6112884, the mounting scheme is subtly different, the HP has three cross-shaped holes, the IBM has one switch towards the right and one post towards the left that rides up into a simple cavity in the keycap, which bottoms out on a rubber o-ring on the post.  It would have required physically modifying one of those items, and I am simply unwilling to make it so either the HP or the IBM won't go back to the way they were meant to be.
I don't have time for a teardown right now but I will see about later this week; I'll get there eventually, but for the meantime, this happened while I was swapping keycaps:
(It went back in fine)
Offline jacobolus
« Reply #14 on: Wed, 16 March 2016, 17:05:59 »
Heresy. Those Alps caps are amazing, better than anything on the market today, and the HP ones are complete crap. :-)
Offline Red October
« Reply #15 on: Thu, 17 March 2016, 01:50:43 »
I know... the keycaps are the whole reason I bought the 6112884; and the deeper scoop of the IBM keycaps is better, as is the fact that the IBMs are different per row, but for whatever reason, the height of the HP keycaps just puts them in the right place for me.  It's not what I was expecting, but it's what happened.
Offline invariance
  • ...here with all the other boson's
« Reply #16 on: Thu, 17 March 2016, 09:10:16 »
I wish I had your problem, vintage keyboards following me home.
Having a quick look through the reference manual (http://bitsavers.trailing-edge.com/pdf/hp/terminal/02645-90005_Nov-1978.pdf) I would guess the terminal scans the keyboard; there may not be an onboard controller.
That would make a very interesting and difficult restoration though.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline Red October
« Reply #17 on: Tue, 22 March 2016, 14:11:27 »
So some folks were curious if these keycaps were Cherry compatible... I'm afraid the answer is no.
Offline birdman
« Reply #18 on: Sat, 14 July 2018, 14:21:52 »
Just found one of these, thinking about doing a restoration on it, this thing is great.
