Author Topic: [IC] Beam Spring Tour Planning  (Read 14078 times)
Offline NewbieOneKenobi
Re: Beam Spring
« Reply #50 on: Thu, 19 May 2016, 16:09:54 »
Lol. I own a piece of such, but it would require a custom controller or some beefy piece of a converter (on converter on converter) to work with a PC. Zero chance for normal recognition, perhaps a chance of miracle through all the conversion into a USB keyboard, eventually. Though this is probably wishful thinking. Cost me a grand total of eight bucks. The key feel is enormously kewl.
Do you have pictures? Sounds very kewl indeed.
I'll get some! Meanwhile, it looks like this (there's a hi-res pic midway down the page).
Offline y11971alex
  • Looking for Toronto meetup
Re: Beam Spring
« Reply #51 on: Tue, 31 May 2016, 10:45:21 »
So I received my 3101 keyboard, and admittedly it needs some work before it's in presentable condition.  In the meantime, is there still an interest in a tour of this board?
If the HHKB can do it, so can the 3101!
Re: Beam Spring
« Reply #52 on: Tue, 31 May 2016, 11:11:01 »
Sure!
How much will shipping be, though?  :-\
Offline y11971alex
Re: Beam Spring
« Reply #53 on: Tue, 31 May 2016, 11:25:30 »
Sure!
Shipping... it cost around $65 for it to reach me from the US, so it's definitely a problem.   The 3101 is 14 lbs.   :eek:
Offline Niomosy
Re: [IC] Beam Spring Tour Planning
« Reply #54 on: Tue, 31 May 2016, 16:12:20 »
Sounds like you'd want to do tours with continental focus.  Let it tour Europe and North America separately so there's only limited inter-continental travel required.
Offline y11971alex
« Reply #55 on: Tue, 31 May 2016, 17:09:06 »
I can only put this on tour after I deal with the pealing coat problem, though.
Offline y11971alex
« Reply #56 on: Mon, 06 June 2016, 02:45:24 »
Still no interest?  :3
Offline Bucake
« Reply #57 on: Mon, 06 June 2016, 03:28:43 »
too high shipping cost for me just to try out a keyboard :-/
and if i end up liking it, i will get depressed for not having one myself!
this is totally a bad idea.
Offline y11971alex
« Reply #58 on: Mon, 06 June 2016, 08:10:47 »
:3
Offline Niomosy
« Reply #59 on: Mon, 06 June 2016, 19:20:32 »
I'm honestly not huge on tactile keyboards, though IBM tactile boards seem better to me than others I've tried.  I'd be curious if it makes a US tour, depending on shipping costs.
« Reply #60 on: Tue, 07 June 2016, 00:06:27 »
Yeah, I'm totally down for this but shipping will be a killer.
Offline ThoughtArtist
« Reply #61 on: Tue, 07 June 2016, 00:44:52 »
I like the IBM clickers because the click is actually part of the actuation, unlike Alps and Cherry with extra bits of material flopping around in the switch that feel like junk in the key.
I definitely want to try out some beamsprings on a tour, because I seriously doubt I can afford to go as far with the hobby in order to collect them on my budget.
« Last Edit: Tue, 07 June 2016, 00:49:19 by ThoughtArtist »
Offline y11971alex
« Reply #62 on: Thu, 11 August 2016, 10:57:01 »
Board is now fitted with solenoid.  Since demik won't tour Canada with his HHKB, let's do the same with this capsense board!
« Reply #63 on: Thu, 11 August 2016, 10:59:59 »
 :eek:
Offline y11971alex
« Reply #64 on: Thu, 11 August 2016, 17:56:53 »
 :eek:
Well, it's gonna stay here in Toronto for a month if nothing happens by tomorrow evening.  I'll be travelling to Vancouver then.   :p
Offline y11971alex
« Reply #65 on: Sat, 13 August 2016, 04:14:45 »
The tour is happening!  It's just making one stop though, at a neighbour's, who wants to try out various keyboards before investing on one.
