Author Topic: Dolch PAC 60 Thread/Restoration Log  (Read 4333 times)
Offline jerue
  • (Whenever that happens :P)
« on: Sat, 19 March 2016, 19:46:26 »
I couldn't really find a home for this (not modding anything really, just discussing the board), hopefully this subforum will do.
I recently acquired a Dolch PAC 60 keyboard, but couldn't find very many resources on it (only PAC61-64/5 and other models like the 386).
From what I know, this board is unique in the series of Dolch keyboards because it has a built in PS/2 connector rather than the more common RJ45. I guess my first question is why only this model? Were the folks over at Dolch growing tired of making adapters for their computers?
Anyways, when I got the board in the mail, it was in rough shape to put it nicely.
Unlike most PAC boards, the PAC 60 has the PS/2 connector on the upper-left hand side of the keyboard
Again, this case...is rough.
Note: There is actually no screw under either the back or the front logo, I think I remember reading this was the case for most Dolch boards, but not this one.
I removed the logo and unscrewed the case and PCB from the board.
Some keycaps...you guessed it, it's time for a bath!
(please disregard my dirty bathtub >.<)
While things are in the bath let's look at the PCB...
There is some...sort of sticky substance on the back. I had another 1800 imported from taobao and noticed the same thing, maybe it's something with old cherry boards? Or both are just dirty :))
Cherry Vintage Blues. They feel great, nice and soft, somewhat lighter than modern MX Blues. The real winner is the spacebar...that MX Green is awesome.
After a while I went to check on the cases, and saw not much was happening. I guess the rubberized coating on the outside of the keyboard is standard. Either way, the rubber was so worn on each side, so I decided to strip the coating off of the case.
I am a fan of the brushed look. I was able to scrub the entire board and give it the matte look; both the top and bottom case are currently air drying and I will let them dry overnight.
More to come!
Offline harlw
Re: Dolch PAC 60 Thread/Restoration Log
« Reply #1 on: Sun, 20 March 2016, 07:53:20 »
I have a 60 as well irc. I really recently ordered a derelict keyboard as well, it has a lot of caps missing and is pretty beat up.
I've always wanted to do something with the computer or the casing but as you have noticed, documentation is scarce.
Ergodox (x2), V.EA Clone, Tada68, Atreus XL, Planck, Model M 70% Mod
Offline jerue
« Reply #2 on: Sun, 20 March 2016, 23:51:45 »
I finished everything up today, and it's reassembled. Tomorrow I should be getting a PS/2 cable to see if everything actually works.
Here's a little sneak peak before I head off to bed :)
Nice! I think I know which one you're referring to :)
« Last Edit: Sun, 20 March 2016, 23:53:20 by jerue »
Offline mason
  • have fun with her, ryan
« Reply #3 on: Mon, 21 March 2016, 00:18:44 »
Does your PCB smell weird? I had two of those boards a while ago and I couldn't stand using them because of the smell.
Offline jerue
« Reply #4 on: Mon, 21 March 2016, 07:14:03 »
Yes, it had a really strange smell. Almost fruit like? It's pretty bad. I think I fixed that issue though, I wiped everything off the case and the foam separating the case from the pcb.
Offline Hzza
« Reply #5 on: Mon, 21 March 2016, 07:20:48 »
I have a 60 too, the rubber coating was disgusting so I took it off as well which is just about as far as I got with the restoration :D. IIRC 3 of the 4 screw mounts for the case have come off so I have to come up with a way of re-attaching them.
Does the numpad/nav cluster on yours send numpad scancodes as well?
This is how mine has been since last Summer.
https://deskthority.net/photos-f62/dolch-pac-keyboard-t10816.html?hilit=pac60#p234227
Offline joey
« Reply #6 on: Mon, 21 March 2016, 07:26:18 »
I thought this was a Dolch PAC 60% conversion :P
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #7 on: Mon, 21 March 2016, 08:32:06 »
I really impressed by PS2 connector  :thumb:
