Author Topic: Solid starter TKL mechanical keyboard?  (Read 5078 times)
Offline Sehcure
« on: Wed, 23 March 2016, 04:19:29 »
Like the minimal look, no backlight etc.
Help! :)
Offline klennkellon
  • I like bottoming out
Re: Solid starter TKL mechanical keyboard?
« Reply #1 on: Wed, 23 March 2016, 04:38:01 »
cm storm quickfire rapid
solid boards for the price, half decent variety of switches.
Offline mrlooolz
« Reply #2 on: Wed, 23 March 2016, 04:55:43 »
Look into ducky! i got the shine 5 and cant be happier
Ducky Shine 5 w Mx Browns  | White fox w Zelio's purple 67g | Gateron Blank set
Current Aims: Jack O Lantern is my end game cap. Looking for one.
                                                   --> MrLooolz's Classified. <--
Offline Dernubenfrieken
« Reply #3 on: Wed, 23 March 2016, 06:34:38 »
Quickfire rapid. Solid board to start with, replaceable top case, can take out the controller to make it programmable, and just generally easy to work with.
Offline bocahgundul
  • a seal
« Reply #4 on: Wed, 23 March 2016, 06:36:10 »
KUL ES87
Offline sitch
« Reply #5 on: Wed, 23 March 2016, 06:44:34 »
Filco 87!
Offline appleonama
  • Trollo en USA
« Reply #6 on: Wed, 23 March 2016, 06:49:53 »
leopold fc750r there is nothing better
I will shill the hell out of this board because it was the best stock board I've ever tried
« Last Edit: Wed, 23 March 2016, 06:56:41 by appleonama »
Offline appleonama
  • Trollo en USA
« Reply #7 on: Wed, 23 March 2016, 06:53:28 »
Help! :)
Offline mrlooolz
« Reply #8 on: Wed, 23 March 2016, 06:55:17 »
Help! :)
lol. My bad.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Offline The Hobbiest
« Reply #10 on: Wed, 23 March 2016, 12:37:48 »
Another Kul-ES87 user here that would happily suggest this board for what you are looking for.  The Leopold fc750r is another good option but I was able to get the Kul and a set of pbt dyesub keycaps for slightly less than the total cost of the Leopold.
Offline StormyMonday
« Reply #11 on: Wed, 23 March 2016, 13:25:49 »
These are all good suggestions; you won't go wrong with either of them. The deciding factor will come down to price and availability when it comes time to pull the trigger. Don't agonize about finding "The One." Narrow your list down to two, or three and then go with the best deal that you can find.
Offline jamster
« Reply #12 on: Thu, 24 March 2016, 00:59:35 »
Do the Filco and Leopolds have DIP switch options to flip the Caps Lock and Ctrl keys?
Besides being a very solid and minimalist board, the KUL does and it's a great feature to have.
Offline clacktalk
  • circa 2015
« Reply #13 on: Thu, 24 March 2016, 01:35:25 »
quickfire rapid
then upgrade into programmable layout via frosty flake
then switch switches to vintage black
then get gateron blanx
then we are twins
diary of a clacktalk
radio_killah: too much frank
« Reply #14 on: Thu, 24 March 2016, 02:13:19 »
hhkb, it's technically a TKL.
it's minimal, no tacky backlight, has great switches and you won't need another keyboard after it. im saving you money and headaches!
Offline KRKS
  • Your friendly neighbourhood umbrella
« Reply #15 on: Thu, 24 March 2016, 02:35:45 »
Ozone Strike Battle
also +1 for Quickfire Rapid it's solid too.
The increasing power of Massdrop WILL kill the community group buys - don't come crying to me after it happens when you're too stupid to see it now. Join me in saving the community!
MD = NO $, NO EXCEPTIONS
Offline spanyam
  • Enjoy the gift of life!
« Reply #16 on: Thu, 24 March 2016, 02:41:39 »
If you really care to swap caps/ctrl then KUL ES-87 is likely your best bet. Really solid board for the price. If you want to get a similar solid feel for less and don't really care to remap keys, then Quickfire Rapid is excellent.
SKCM Orange ALPS on Infinity 60% bent-metal case w/ hasu ALPS64 PCB and PBT blank DSA caps | KBP V60 w/ Matias Quiet Linears | IBM Model M | QFR w/ MX Blues
« Reply #17 on: Thu, 24 March 2016, 05:24:13 »
RealForce 87U 55g uniform.
Or if you want to stick with Cherry then QFR, Filco, KUL or WASD.
Or Alps get a Matias something or a KB Paradise V80 (currently on Massdrop).
Buckling spring = SSK.
Offline carmenohio
« Reply #18 on: Thu, 24 March 2016, 19:20:23 »
Putting in another vote for the CM Quickfire Rapid.  You can get them for about $60 these days, and they're 90% of what a Filco is at a fraction of the price.
Offline TalkingTree
    • My projects
« Reply #19 on: Fri, 25 March 2016, 04:32:28 »
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« Reply #20 on: Fri, 25 March 2016, 04:40:32 »
Depends on what you want to spend
Over 100$
leopold fc750r (Great stock caps)
Kul 87 es (Stellar support and warranty )
Cheaper priced boards
Ganss G.s 87 (Basically a much cheaper FILCO i have two they are very solid buys when on sale got both mine for under 60$ US)
Quickfire rapid
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline losing_ctrl
« Reply #21 on: Fri, 25 March 2016, 07:48:04 »
I would give this WASD TKL board a look:
http://www.wasdkeyboards.com/index.php/products/mechanical-keyboard/wasd-87-key-doubleshot-pbt-black-slate-mechanical-keyboard.html
I have this keyboard with MX Greens, but in a full size form factor, and really like it - it feels very solid and the keycaps have a very pleasant texture.
« Last Edit: Fri, 25 March 2016, 07:55:50 by losing_ctrl »
