Author Topic: Website not working- mechanicalkeyboards.com  (Read 3223 times)
Offline jcoffin1981
« on: Thu, 24 March 2016, 19:51:47 »
Does anybody know what happened to the website for mechanicalkeyboards.com?  It seems to have been out of commision for the last 48 hours?  Is it temporary or permanent?
Offline Vittra
  • Airflow Optimizer
Re: Website not working- mechanicalkeyboards.com
« Reply #1 on: Thu, 24 March 2016, 19:52:41 »
I have had no problems accessing it within the time frame you have specified. Working currently as well.
Filco MJ Linear R LE TKL
Offline Shaussman
« Reply #2 on: Thu, 24 March 2016, 20:05:00 »
No issues for me, either
MX Brown Quickfire XT | MX Clear WASD VP3 | MX Blue Ducky Zero
Offline jcoffin1981
« Reply #3 on: Thu, 24 March 2016, 20:29:01 »
Interesting.  I used bookmarks as well as typing it into the browser.  I don't really have a solution.  Maybe the problem will right itself.  It doesn't work  when using the google search results either.  Strange.
Offline Shaussman
« Reply #4 on: Thu, 24 March 2016, 20:31:11 »
Did you try a different browser/computer?
Offline jcoffin1981
« Reply #5 on: Fri, 25 March 2016, 14:06:11 »
Strange, it works at work.  At  home I cannot  get it to load.  After about 30 seconds it simply times out.  I  don't have another computer to use here, but this is  working lightening fast.  I've tried loading it from bookmarks as well  as browser history and search engine  results.  I have tried several browsers, all with the same result.
Offline jcoffin1981
« Reply #6 on: Fri, 25 March 2016, 14:18:19 »
What is really strange is that I just tried opening a VPN and I can then browse the website.  If I close the VPN I can no longer navigate the site; it simply times out again.  It's as if my IP address is blocked for some reason.   I am stumped.
« Reply #7 on: Fri, 25 March 2016, 14:20:36 »
It's probably your DNS not working right. Open a command prompt, and type "ipconfig /flushdns" then try it again. You might also need to clear the cache and cookies on your browser.
Offline appleonama
  • Trollo en USA
« Reply #8 on: Fri, 25 March 2016, 14:21:22 »
I think they have been doing some inventory changes. I wasn't able to check out a day ago .
Offline jcoffin1981
« Reply #9 on: Fri, 25 March 2016, 15:33:12 »
I flushed the DNS and cleared the cookies as well as rebooted the router, all which had no effect.  I  guess I have to give it a few days  and see if it rights  itself.  I just have never seen a problem like this.  I assume  the problem is on my end.
« Reply #10 on: Fri, 25 March 2016, 16:11:40 »
Try setting Google as your dns server in your router. IP addresses for Google dns servers are 8.8.8.8 and 8.8.4.4
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #11 on: Fri, 25 March 2016, 17:07:21 »
They found out that you're trying to buy out their stock! The shame!  :eek:
« Last Edit: Fri, 25 March 2016, 21:02:22 by csmertx »
Offline jcoffin1981
« Reply #12 on: Fri, 25 March 2016, 20:53:07 »
I'm not sure what this would do.  I'm not a network IT guy and I had a heck of a time setting up my router.  I have it  bridged with another router.  This is the only way I could get a strong enough signal consistently.
Offline Vittra
  • Airflow Optimizer
« Reply #13 on: Fri, 25 March 2016, 21:05:28 »
jdcarpe's suggestion can potentially change your routing tables/transmission route, a similar result to you going on to VPN.
VPN working indicates that it most likely a routing issue. Data that is transmitted from point A (your home) to point B (MK) will travel through various routing points to reach it's destination. If one of those locations is having an issue, this is the result. You could try the "tracert" command in CMD prompt to view the route the packets are taking in real time, but based on a test I just did it looks like this request will be blocked, so no luck there.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14 on: Fri, 25 March 2016, 23:19:32 »
You don't have to configure much, just go to your network adapter in control panel and change your IPv4 DNS addresses. It could very well fix your issue. DNS routing issues can cause just this issue. Every site is located at a specific IP address which DNS translates into a URI. For a quick rundown, here is what happens when you access a website:
« Reply #15 on: Sat, 26 March 2016, 04:45:24 »
Try disabling your firewall temporarily (only for as long as it takes to check the site).
Have you tried multiple browsers on the one computer?  Or multiple devices on your network (e.g. several computers, or a tablet or smart phone)?
Offline jcoffin1981
« Reply #16 on: Sat, 26 March 2016, 21:45:51 »
Yes I did try these tips and disabled windows firewall as well as all the antivirus and malware programs.  This is the only computer I have tried to access it on that I have. I guess  I could have used my e-book reader which has a browser as well.  The website loaded  on the computers at work.
Today the website is loading up just fine, which is great.  I'm more concerned with learning why it would not work before, which is absolutely baffling to me, but if it continues to work I will just forget about it I suppose.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #17 on: Sat, 26 March 2016, 22:47:07 »
It was probably one of those compounded network route issues. I get that on occasion with random websites. Although, usually I can google search the site and access it that way so idk what you were experiencing.  :confused:
