Author Topic: Who are you - ALPS64 60% w/ SGI caps and SKCM Browns  (Read 3290 times)
Offline Mattr567
« on: Thu, 24 March 2016, 22:59:24 »
http://www.ebay.com/itm/252325676565
This is pretty cool. Some of the best Alps caps with SKCM Browns. I guess i'm getting a similar experience with my SKCM Orange SGI Granite ;)
IBM P77, SKCC Green, 1984
Offline cooldiscretion
  • Convicted guilty of being totally rad.
Re: Who are you - ALPS64 60% w/ SGI caps and SKCM Browns
« Reply #1 on: Fri, 25 March 2016, 12:18:34 »
It's me.
Someone contacted me on eBay and asked if I would be willing to sell the keyboard at a lower price then $150 if I didn't include the case.
I just want to let people know I'm not trying to make a quick buck by flipping this board. It turned out Brown Alps weren't my cup of tea, but
building this board (as I'm sure many others that participated in the GB BlueNalgene was kind enough to spearhead know) took a while and
was only possible with the acquisition of several different parts from different areas. If I was to breakdown the parts invovled, it would be
this:
1) Brown Alps Switches Harvested from Vintage Brown Alps keyboard ~$70
2) SGI AT-101 for PBT keyset - $80
3) PCB & Plate - ~$70
4) Dell AT-101 for spacebar - $30
5) Plastic case $20
Some of these things I was able to recoup funds on by selling the remaining parts in pieces, so these prices aren't a direct reflection of
how much the keyboard cost. Either way, the point was just to demonstrate I'm trying to be very fair here.
« Last Edit: Fri, 25 March 2016, 14:14:55 by cooldiscretion »
Offline jacobolus
« Reply #2 on: Fri, 25 March 2016, 16:35:10 »
What was wrong with the SGI spacebar?
Edit: anyway, seems like an awesome board. I hope some folks put in high snipe bids, and you end up fetching a good price for it. :-)
Would be sad if you had to disassemble and sell the parts out separately to break even.
« Last Edit: Fri, 25 March 2016, 16:44:52 by jacobolus »
Offline exitfire401
  • The Force is Re/\l
« Reply #3 on: Sun, 27 March 2016, 15:41:25 »
Got sniped at the last second
« Reply #4 on: Sun, 27 March 2016, 16:14:09 »
The SGI spacebar has it's stabilizer mounts farther in to the center then the Dell AT-101 spacebar. Since the plate was made for Dell AT-101 compatibility, it has the clips very far out.
This essentially means that you either HAVE to make your own stabilizer (which I tried using the ez bender) or buy an actual Dell AT101 for the spacebar. When I made my own stabilizer it was unstable
due to the fact that it has to go so far out for the plate clips and come so far back for the spacebar mount clips. Once I acquired the Dell AT-101 spacebar, it was smooth sailing.
It sure did! But that's okay my base price was the lowest I was willing to sell it for. It went to a good GH member too so that makes me happy.
