Author Topic: Does the IBM Rapid Access Pro 1 or 2 have input lag/ghosting?  (Read 1331 times)
Offline biscuits
« on: Wed, 30 March 2016, 17:57:44 »
Does anyone know if this keyboard has lag/ghosting? It uses rubber domes and apparently it was one of the best keyboards for its time, I was thinking of getting it but don't wanna use it if it has lag or ghosting hehe. Thanks.
Offline Keycap
Re: Does the IBM Rapid Access Pro 1 or 2 have input lag/ghosting?
« Reply #1 on: Wed, 30 March 2016, 18:29:04 »
You're most likely asking if it uses blocking or not. I'm fairly sure that there is no ghosting with it, but it's definitely limited to only 2KRO, given the fact that it's an old and cheap rubber dome keyboard. So, yes, you'll have some issues with not all keys responding to multi-key combinations, but actual ghosting (where you press a certain amount of keys and a random key that you didn't even press is registered) is nothing to be worried about.
