Author Topic: Infinity Ergodox micro b cable  (Read 2168 times)
Offline climbalima
  • likes building stuff
« on: Thu, 31 March 2016, 17:10:04 »
I am looking for the type of cable used in the infinity ergodox to connect the two halves. I know it is a usb 3.0 micro b, but I can't seem to find one with both ends.
Any help would be very appreciated. Thank you.
Offline OverKill
Re: Infinity Ergodox micro b cable
« Reply #1 on: Thu, 31 March 2016, 21:50:46 »
The Infinity ErgoDox uses a regular micro b cable not a micro b to micro b. You connect the Type A to the computer, then the micro b to whichever hand you want, then the other cable type a goes in to the type a port on  the side plugged in to the computer, and the micro b gets plugged in to the slave side not connected to the computer. Or if you want to you can connect both hands individually to the computer. Either way you still need 2 Type A to usb 3 micro b cables.
Offline climbalima
« Reply #2 on: Thu, 31 March 2016, 21:51:33 »
Ahh thanks for clearing that up for me.
