Author Topic: [GB] Out of the Vault - The Megaton Vault Drop (Extras Subsets Open)  (Read 420424 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Re: [GB] Out of the Vault - The Megaton Vault Drop: (Key Changes/Price Drop)
« Reply #100 on: Fri, 15 April 2016, 07:28:05 »
TL:DR current OP set order numbers are:
SA Row 1: 18
SA Row 3: 23
DSA: 23
We are getting there, slowly but surely. Thank you, now let's get the word out about the changes...
I will try to work on the banners
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline nosage
« Reply #101 on: Fri, 15 April 2016, 07:32:11 »
Damn that is sexy.
Offline 00zeRO
« Reply #102 on: Fri, 15 April 2016, 08:47:35 »
Damn that is sexy.
Eh, better in person I am sure. Can't wait!
Offline nosage
« Reply #103 on: Fri, 15 April 2016, 09:21:49 »
Maybe we can bribe @thesiscamper with a set to create 3d renders to help advertise?
Offline thesiscamper
    • Keyrenders
« Reply #104 on: Fri, 15 April 2016, 09:24:14 »
Hmm.. You probably can.
"haters are confused admirers"
Offline 00zeRO
« Reply #105 on: Fri, 15 April 2016, 09:24:27 »
I have my team...we are all just really slammed
Offline 00zeRO
« Reply #106 on: Fri, 15 April 2016, 09:25:07 »
lol, thanks. are you looking to put a render on a keyboard for dramatic effect?
    • Keyrenders
« Reply #107 on: Fri, 15 April 2016, 09:27:08 »
I'm not sure what you mean, is it to put some fallout caps on a keyboard for better effect, rather than mock-ups of just the caps?
Offline 00zeRO
« Reply #108 on: Fri, 15 April 2016, 09:36:54 »
I didn't know what you had in mind as the original banner features lifelike mockups. I just put up my 2d renders for explanatory value until one of my Graphics Officers, harlw, gets to put it together for us...
    • Keyrenders
« Reply #109 on: Fri, 15 April 2016, 09:39:48 »
Ah, I was not really thinking how I'd do it, was just replying to nosage that I can probably do mock-ups in exchange for a set. Didn't really check the thread, but if harlw's working on it then it's all good ;)
Offline 00zeRO
« Reply #110 on: Fri, 15 April 2016, 10:01:44 »
boy, do I feel dumb. I just realized that my sig banner points to the IC...nicht so gut!
I fixed it, though.
Yay, me.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #111 on: Fri, 15 April 2016, 10:32:34 »
New mock-ups looking good  :thumb:
Offline 00zeRO
« Reply #112 on: Fri, 15 April 2016, 10:43:06 »
Just my standard 2d mockupery
Offline 00zeRO
New banner is up! We are getting there, thanks to harlw's wizardry... :thumb:
Offline 00zeRO
edit: prices need to be changed...
Offline 00zeRO
Offline 00zeRO
Re: [GB] Out of the Vault - The Megaton Vault Drop: Fallout-Inspired Novelties
« Reply #117 on: Fri, 15 April 2016, 17:52:20 »
OP now corrected...phew...
Check this out FB'ers:
https://www.facebook.com/589719521065041/photos/a.589962681040725.1073741828.589719521065041/988492724521050/?type=3
Any way you can get this page updated: http://nathanrosspowell.com/00keys/gbs/megatonvaultdrop/ ?
Each of us on the team is hard at work at day jobs...we will get it updated as soon as we can
« Reply #118 on: Fri, 15 April 2016, 19:49:39 »
Not idea what you are talking about... check again  ;)
(Sadly can't update things while I am at work)
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Sweet. Going to update now. Thanks.
Offline MikeTheTiger
« Reply #120 on: Fri, 15 April 2016, 21:03:44 »
So...for those of us who have paid already...do we need to reorder or will you be adjusting for the price difference?
"all the numbers or none of them cmon man" -Kokaloo
Offline 00zeRO
« Reply #121 on: Fri, 15 April 2016, 21:36:26 »
I will be refunding the overages
Offline 00zeRO
« Reply #122 on: Fri, 15 April 2016, 21:36:58 »
It will be a while
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #123 on: Fri, 15 April 2016, 22:51:47 »
It will be a while
Don't worry, I know you're good for it.
Offline 00zeRO
« Reply #124 on: Fri, 15 April 2016, 23:02:47 »
It will be a while
By the way check your signature banner...we updated it in the OP
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #125 on: Fri, 15 April 2016, 23:05:11 »
It will be a while
IDK what you're talking about ;)
« Reply #126 on: Sun, 17 April 2016, 03:33:29 »
It will be a while
No worries...just wanted to make sure I didn't need to reorder.
Offline Sempre
« Reply #127 on: Sun, 17 April 2016, 06:48:54 »
Any recommendation on which is the appropriate profile to choose if i'm using this with a cherry profile set?
Offline 00zeRO
« Reply #128 on: Sun, 17 April 2016, 07:08:44 »
DSA since it is the shortest.
Offline 00zeRO
« Reply #129 on: Sun, 17 April 2016, 07:23:58 »
SA Row 3 would be okay but only Top Row placement. It will stick up higher like in the reference photo in the OP.
Offline Sempre
« Reply #130 on: Sun, 17 April 2016, 07:38:02 »
Yeah that's where i'll be using it so i'll likely choose Row 3
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #131 on: Sun, 17 April 2016, 07:45:59 »
Here's some comparison shots. SA row 1, row 3, JTK, DSA.
http://imgur.com/a/LyNi1
Offline Sempre
« Reply #132 on: Sun, 17 April 2016, 09:04:25 »
Wow row 1 really is tall. It would look nice if I had a SA set but it looks like row 3 does the job. Thanks for the pictures.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #133 on: Sun, 17 April 2016, 09:29:33 »
Yea, SA row 1 is very tall. R3 would be the best match for anything OEM or cherry profile.
00zeRO, feel free to use any of those pictures to show the profile differences.
Offline 00zeRO
« Reply #134 on: Sun, 17 April 2016, 11:37:49 »
Thanks, man
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #135 on: Sun, 17 April 2016, 11:54:09 »
Thanks, man
No problemo.
Offline 00zeRO
« Reply #136 on: Sun, 17 April 2016, 21:35:19 »
Just updated OP with new ref pics and also updated the order totals.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #137 on: Sun, 17 April 2016, 22:54:15 »
Looks like we're getting there
Offline 00zeRO
« Reply #138 on: Mon, 18 April 2016, 19:03:50 »
Happy Monday to all. Hope you've had a great start to your work week.  ;D
Offline sek1ne
  • Sek-eye-n
« Reply #139 on: Mon, 18 April 2016, 19:18:52 »
Everything was great except for the raffle results. Rng can eat it.
Biking is fun.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #140 on: Mon, 18 April 2016, 19:48:22 »
It was a good day
Offline techmattr
« Reply #141 on: Mon, 18 April 2016, 20:20:41 »
Nuka!
Offline 00zeRO
« Reply #142 on: Mon, 18 April 2016, 22:54:15 »
Nuka!
That should go on the classicfallout sub as fan art
Offline 00zeRO
« Reply #143 on: Mon, 18 April 2016, 22:58:25 »
Updated totals in OP as we inch our way toward the goal for raffleage.
« Reply #144 on: Mon, 18 April 2016, 23:00:31 »
Nuka!
Congrats, fooled me into thinking it was a render for a second or two  :eek:
Offline 00zeRO
« Reply #145 on: Mon, 18 April 2016, 23:01:14 »
I like Martin's sales. He is always first come first served. Plus, if you miss something, it will eventually show up on MechanicalKeyboards.com.  :cool:
Offline 00zeRO
« Reply #146 on: Mon, 18 April 2016, 23:02:25 »
Nuka!
Me too...
Offline 00zeRO
« Reply #147 on: Mon, 18 April 2016, 23:04:31 »
Nuka!
Me too...
I just can't stop looking at it
Offline 00zeRO
« Reply #148 on: Wed, 20 April 2016, 12:17:24 »
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #149 on: Wed, 20 April 2016, 12:52:43 »
Dogmeat is the best! All of the other NPC's suck.
