Author Topic: Imsto vs. EnjoyPBT  (Read 7957 times)
Offline the big aristotle
Imsto vs. EnjoyPBT
« on: Fri, 01 April 2016, 08:15:00 »
I've been eyeing the Miami sets and since they're about the same price, I was wondering if there were any glaring differences between EnjoyPBT and Imsto that I should be made aware of. Quality, legends, etc.
I'll be putting these on a Novatouch.
Offline FrostyToast
  • Litshoard
Re: Imsto vs. EnjoyPBT
« Reply #1 on: Fri, 01 April 2016, 08:18:25 »
It depends on what set you're looking at.
IMSTO only does the dye sublimation and uses caps from other manufacturers.
His most recent ongoing run for keycaps uses gateron PBT keycaps, the exact same as Enjoypbt; there really isn't any difference in quality.
Though, if I recall Enjoypbt has more vibrant legend colours.
Quote from: elton5354
Offline 27
  • The Maple Man
« Reply #2 on: Fri, 01 April 2016, 08:18:34 »
I believe they both use Gateron keycaps that they dyesub (correct me if I'm wrong), so the only real difference would be that the legends are slightly different.  How different? No idea.
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline ika
« Reply #3 on: Fri, 01 April 2016, 08:21:54 »
https://geekhack.org/index.php?topic=74405.msg2024804#msg2024804
Probably the best comparison you'll get. R4 Imsto is using Gateron base.
« Reply #4 on: Fri, 01 April 2016, 08:34:49 »
I was looking at the cyan & pink with KR legends from Enjoypbt and the Miami set from Imsto
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Fri, 01 April 2016, 10:15:40 »
So you're thinking of a taihao, or SP DCS Miami set, but you want to make sure that you're not missing out on a great pbt set? I'm a bit confused.
Geekkeys Miami set is ABS SP DCS
Taihao is PBT (some have a nasty microbial coating that peels away after use)
If you're talking about IvanIvanovitch's Miami Odessa set.. well.. first of all don't buy directly from that guy, second, where did you find that set? I don't see it on the IMSTO website.
« Reply #6 on: Fri, 01 April 2016, 10:23:45 »
Yeah I was talking about the Miami set that's on Imsto's website. He's has an option for it on here.
http://imsto.cn/index.php?route=product/product&path=62&product_id=115
And I'm pretty sure that it's the same look as the Miami Odessa set from Ivan's R4.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #7 on: Fri, 01 April 2016, 10:38:57 »
Ah I see it now. So I guess it is the same colorway with the Cyrillic legends. Cool
« Reply #8 on: Fri, 01 April 2016, 10:42:16 »
Yeah so other than the slight difference in legends, I was just curious about the manufacturing differences. If it's not too different, I'll probably just grab a set from Shadovved because it'll be available faster.
Offline kokokoy
« Reply #9 on: Fri, 01 April 2016, 11:13:49 »
phoenix1234 did some comparison shot here
https://geekhack.org/index.php?topic=74405.50
Offline FrostyToast
  • Litshoard
« Reply #10 on: Fri, 01 April 2016, 12:00:11 »
Like I said, Enjoypbt uses more vibrant colours on their Hangul set.
I can't find any good shots of the Miami set as the colours vary so drastically between shots. However, you will see that the blues in the Miami odessa sets look kind of washed out compared to Enjoypbt which opts for a darker blue.
« Last Edit: Fri, 01 April 2016, 12:03:41 by FrostyToast »
Offline ThoughtArtist
« Reply #11 on: Sun, 03 April 2016, 03:39:50 »
Speaking of IMSTO, is that vendor currently active? I put in an order for the dark grey PBT on the 31st but it still says "pending". I'm wondering if anyone has ordered from there recently.
« Last Edit: Sun, 03 April 2016, 04:19:39 by ThoughtArtist »
