Author Topic: key layout?  (Read 3074 times)
Offline PrawnZ
key layout?
« on: Sun, 03 April 2016, 12:19:53 »
So im new to all this but I have a Razer Black widow tournament 2014 (UK Layout)
I was wondering if I was to buy custom Cherry Keycaps what layout would I have to buy ?
133161-0
Thanks in advance
« Last Edit: Sun, 03 April 2016, 12:24:18 by PrawnZ »
Offline soilheart
Re: key layout?
« Reply #1 on: Sun, 03 April 2016, 13:09:24 »
Looks like 1.5+1+1.5+6+1.5+1+1+1.5 .
A little odd layout, but not as bad as Corsair =P
Just some more info:
The most usual layouts here are:
1.25+1.25+1.25+6.25+1.25+1.25+1.25+1.25
1.5+1+1.5+7+1.5+1+1.5
So the latter would suit your board better, but the spacebar won't fit (and you'll have to find another small 1u key).
EDIT: Seems like it's a center mounted 6u spacebar too, which seems a little unusual (according to DeskThority wiki)
« Last Edit: Sun, 03 April 2016, 13:13:58 by soilheart »
(K70 -  Brown) --- Pok3r - Clear --- Ducky Shine4 - Clear --- WKL B.face X2 - 67g Zealios --- CP-SQ - 78g Zealios --- RS68 - 62g Zealios
(Sold/retired - To be built)
Offline Malenky
Re: key layout?
« Reply #2 on: Sun, 03 April 2016, 18:27:11 »
This image is not ISO UK, its pretty much ANSI with a non-standard bottom row (I think).
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: key layout?
« Reply #3 on: Sun, 03 April 2016, 18:33:18 »
If you're not 100% sure it's best to get out your ruler and check the measurements  :thumb:
Offline seville57
Re: key layout?
« Reply #4 on: Mon, 04 April 2016, 15:09:43 »
Thanks in advance
The problem is the non-standard bottom row (Ctrl, Win, Alt, FN/Menu and the Spacebar) on razor and corsair k-boards.
You need a standard bottom row size: Ctrl, Win, Alt and FN/Menu = 1x1.25.
Spacebar = 1x6.25.
Second row in the link (Ducky, Das, Deck, WASD + some more k-boards) shows a standard bottom row size.
http://www.maxkeyboard.com/mechanical-keycap-layout-and-size-chart.html
A pic of my 2 Ducky k-boards, the white  Ducky One RGB YOTG is a ANSI layout, the black Ducky Shine 3 is a ISO/Nordic layout.
Both with a standard bottom row.
Here is maybe somerhing from Max:
http://www.maxkeyboard.com/max-universal-cherry-mx-translucent-clear-black-full-keycap-set-front-side-print.html
This keycaps set is ANSI - ISO/UK layout in the same set.
The ISO/UK Enter + left Shift keycaps (+ 2 of the 3 Spacebars) in the Max set. The orange Pumkin cap don't belong to the Max set.
« Last Edit: Tue, 05 April 2016, 10:09:28 by seville57 »
