Author Topic: SGI Granite KB problem  (Read 5211 times)
Offline h1ggs
  • @switzcaps
« on: Mon, 04 April 2016, 16:24:03 »
Hey all,
Newbie here with an sgi granite kb problem. I bought the thing new on ebay; came without a cable. Took a look at the port and guessed its for a ps/2 cable. Bought one, hooked up it and no response. However the keyboard is getting power because I can hear a little click noise (coming from some internal soundchip) that goes off on a keypress.
It's not responding in windows however, the capslock led doesn't even turn on when toggled.
Any ideas as to what I'm missing? Posting photos below
Offline JimByr
  • ...old guy...
Re: SGI Granite KB problem
« Reply #1 on: Mon, 04 April 2016, 20:31:48 »
What's the model number? There are different models of the SGI granite and all are not PS/2. The most common ASCII PS/2 model has an attached cable.
See the DT article...
http://deskthority.net/wiki/SGI_Granite
Offline h1ggs
  • @switzcaps
« Reply #2 on: Mon, 04 April 2016, 20:42:06 »
Ah well that clears things up. I have the model that isn't PS/2 compatible. Looks like I'll need to track down an SGI cable.. if I can figure out what that is exactly..
Offline Mattr567
« Reply #3 on: Mon, 04 April 2016, 20:46:13 »
You'll need to convert it, a cable won't help. Currently no off the shelf converters exist. TMK has the solution however.
Have a PS/2 Granite, good luck!
IBM P77, SKCC Green, 1984
Offline h1ggs
  • @switzcaps
« Reply #4 on: Fri, 09 September 2016, 15:51:20 »
Oo any chance someone could direct me to the TMK solution for this?
Offline Mattr567
« Reply #5 on: Fri, 09 September 2016, 19:09:19 »
Sorry to say but I am mistaken from April. I remember Hasu talked about this but a converter isn't currently available from him or elsewhere. I think possible get a Dell Bigfoot and combine the two together to make one good board however.
