Author Topic: I would like to see a switch like this:  (Read 4608 times)
Offline PRISONER 24601
« on: Tue, 15 December 2009, 09:07:32 »
Check it, dudes:
5-6mm travel
light springs
actuation point @ around 1mm with prominent "bump" in resistance near the top of the key press.
It might work better with heavier springs, but the key here is an actuation point right near the top. Something that takes only a "tap" to register a keypress, but still has 4mm or so before bottoming out.
I know that this is theoretically impossible with cherry's design, but couldn't they be changed? no doubt the switch would be "taller", but I don't think it would affect the feel negatively. There's got to be a way!
I've been fooling around with 4.5g weights on my cherry brown keys, and I love the response (that's what spurred this idea). They feel much lighter, and the weights make the tactile bump more noticeable. When I'm typing on them, it sort of "rolls" with the movements of my hands. It's pretty cool.
Any thoughts? Keep in mind I'm 'new' to this keyboard crowd, so if my ideas seem half-baked, it's probably because they are.
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
Offline elbowglue
« Reply #1 on: Tue, 15 December 2009, 11:07:48 »
Quote from: PRISONER 24601;142570
Check it, dudes:
5-6mm travel
light springs
How you you weight a cherry brown key without messing up the typing surface?  Maybe attach some putty to the underside of the keycap?
Dell AT101W has actuation point near the top of the switch, but the actuation force is much higher than the 45gram of cherry browns... If I recall correctly they are 70 grams.
Of topic by the way, now I like my MX8100 again.  It turns out if I position the keyboard just perfectly at the right height, with a wrist rest about 1.5 inches from the lip of the keyboard, all of the keys actuate well 100% of the time.  It's not tolerant to odd angle typing.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline Rajagra
« Reply #2 on: Tue, 15 December 2009, 11:17:27 »
Check it, dudes:
5-6mm travel
light springs
Sounds good to me, I don't know why there aren't switches like that. Maybe there are?
Although long travel avoids the need to bottom out, ideally some way of cushioning the impact when it did happen would be another good feature. I've mentioned before (in jest) the idea of a rising rate linkage, but that wouldn't be practical. Other ways would be a rising-rate spring (very practical and inexpensive), or a Nike Air type bubble at the end of travel.
Offline leos
« Reply #3 on: Tue, 15 December 2009, 12:34:10 »
Check it, dudes:
5-6mm travel
light springs
this oldie has a 6mm key travel micron_lapi
you can ask if this company wanna produce for you a ruber dome with a 6mm travellink
also read this: MEASUREMENT OF IMPEDANCE CHARACTERISTICS
OF COMPUTER KEYBOARD KEYS
« Last Edit: Tue, 15 December 2009, 13:16:18 by leos »
HHKB 2 Pro Black in use :typing:
Offline ch_123
« Reply #4 on: Tue, 15 December 2009, 13:10:37 »
Check it, dudes:
5-6mm travel
light springs
The top with switches where all the force is concentrated at the top is that you tend to bottom out quite easily. You seem to have got around this by speccing a longer travel, but then what's the point of that? Bottoming out isn't necessarily a bad thing, it's just not conducive to quick typing. The same is true though of a switch with long travel. At the end of the day, you're better off with a switch whose force builds up gradually, like a Blue Cherry or Buckling Spring. That way you can train yourself to feel when they are actuating and therefore not bottom out on them.
Offline leos
« Reply #5 on: Tue, 15 December 2009, 13:22:24 »
Quote from: ripster;142618
I wonder if I could build one of these out of Legos?
why build one of legos if you can stole....ahhhh have/borrow one from IKEA. They use those mashines to promote their Chairs in every shop. At least here in germany.
Offline ch_123
« Reply #6 on: Tue, 15 December 2009, 14:31:14 »
That sounds like a pretty serious test to me!
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #7 on: Tue, 15 December 2009, 15:46:22 »
Quote from: leos;142615
Good article!:thumb:
« Reply #8 on: Tue, 15 December 2009, 17:10:51 »
Quote from: elbowglue;142604
I jerry-rigged this thing last night. I used the 4.5g weights that come with a logitech mouse, hotglued them to a cap, then glued a few small keytops from my G86. I really love the feel. When you're typing quickly, they get into this "roll" motion that I've never felt in a keyboard before.
I'd like to make something that would work with an entire board.
The browns are light switches anyway, but I can get these weighted ones to fully actuate with just a gentle 'tap' (they have momentum now!), while the non-weighted ones take a bit more of a "pressing down" motion.
oh, here's an example. I know it looks like crap, it was just an experiment.
« Reply #9 on: Tue, 15 December 2009, 17:18:12 »
Wow, great post.
I want to pick up one of those notebooks now... 6mm travel sounds really unique for (i'm assuming) a scissor switch
Not really into rubber domes, they would actuate at the bottom of the stroke, I'm thinking of something that actuates right at the top, then has lots of travel before bottoming out.
also, that's a kickass PDF find. Reading it now. I should look for some stuff like that in my school's academic library :)
« Reply #10 on: Tue, 15 December 2009, 17:28:55 »
Quote from: ch_123;142624
Since I got my spacesaver, I've seriously increased the accuracy and speed of my typing. It's pretty miraculous. Yeah, bottoming out is not a bad thing, but IMHO it impedes ergonomics. For instance, I love typing on scissor switches (because of the short travel to actuation) but my hands get really tired after all that impact.
What I'm thinking is blue cherry switches with lighter, longer springs (along with more travel) would be absolutely perfect. I don't think that's moddable, though. I'd have to design and build an entirely new switch with a taller housing, longer stem, and new springs.
Offline leos
« Reply #11 on: Tue, 15 December 2009, 18:07:20 »
i found this on ebay. maybe one guy in us buy this and then can tell us about this incredible 6mm keys depress.
« Reply #12 on: Tue, 15 December 2009, 18:28:12 »
Quote from: leos;142748
Has anyone here tried these keyboards? I'd friggin' pick it up right now if it weren't for the $80 shipping to US.
Sigh, I need to get out more
Offline leos
« Reply #13 on: Tue, 15 December 2009, 18:34:51 »
Quote from: PRISONER 24601;142735
ok if you need stuff you ll take....
Measurement of Stiffness and
Damping Characteristics of
Computer Keyboard Keys
and dont forget Fatigue
1
2
3
« Last Edit: Tue, 15 December 2009, 18:41:39 by leos »
« Reply #14 on: Tue, 15 December 2009, 19:40:43 »
Quote from: leos;142757
1
2
3
domo arigato, keyboardo-san
Offline skriefal
« Reply #15 on: Tue, 15 December 2009, 20:00:21 »
That laptop is $24 to US, not $80.  See eBay US, here.
Offline hyperlinked
« Reply #16 on: Tue, 15 December 2009, 20:06:09 »
I think you'll need to get some more Yodas first.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline ak_nala
« Reply #17 on: Wed, 16 December 2009, 01:50:52 »
Quote from: Rajagra;142606
Or, a short, somewhat stiffer spring in the keycap to cushion the bottoming out. As I mentioned in this thread, Olympia put springs in their manual typewriter key tops back in the 50's and 60's for just this purpose.
Something like that might work here as well - a short spring at say 2-4 times the relative stiffness to the main switch spring should help eliminate any stresses to bottoming out.
It would have two added benefits as well - tactile feedback on switch end-of-travel, but before key end-of travel - and a bit of extra push back on your finger when releasing the key under those circumstances.
« Last Edit: Wed, 16 December 2009, 01:58:01 by ak_nala »
No matter where you go, there you are...
Offline keyb_gr
  • Cherrified user
« Reply #18 on: Wed, 16 December 2009, 06:48:36 »
Quote from: ak_nala;142816
Same idea in Alps switches with rubber dampers.
I'd see increased key travel as a bit of a problem - it influences height, and that is a factor in ergonomics. Historically people always tried to reduce height while keeping key travel as long as possible.
While we are at switch design ideas, I wonder whether one could combine the OKI style "clicky spring" mechanism with the "lever spring" idea used in Cherry MYs in order to obtain both tactility and a low actuation force.
« Reply #19 on: Thu, 17 December 2009, 11:35:06 »
I would hope that a few extra mm of height wouldn't make much of a difference (to enthusiasts, anyhow). Most people use wrist rests anyway. It does go way against current market trends though, when slim=money in the bank.
Plus, the board could be made a bit slimmer with plate-mounted switches + a thin PCB and top-mounted controller. Someone here (with money, not me) should convince those Tiawanese cherry-clone making dudes (strongman?) to produce a prototype switch with 6-7mm travel and 1.5mm actuation point.
I'm thinking it would work well with linear too, and a spring designed with a steep resistance curve.
Once again, excuse me if my terminology is a bit off. I'm still learning :D
I still seriously think that all this research pointing to 4mm being "just right" is a little short-sighted. People have different preferences
