Author Topic: folding keyboards  (Read 3809 times)
Offline hotrattz
folding keyboards
« on: Tue, 12 April 2016, 18:30:17 »
i know i know WHAT ARE YOU TALKING ABOUT but yes i use an ipad alot and would love to find a good folding keyboard for some journaling (decent amount of typing) that i'm doing and my leopold 750 just doesn't fit well in my bag all the time currently looking at the
1.  ec technology folder
http://www.amazon.com/dp/B00QT8WQ86/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3R21U2VVKKXD2&coliid=I1YDMEKU1ZLONP&psc=1
2. iwerks folder
http://www.amazon.com/dp/B00FEYJOTK/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3R21U2VVKKXD2&coliid=I18FNWE7ZHMHZZ&psc=1
3. Amtop folder
http://www.amazon.com/dp/B00OYSUM98/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3R21U2VVKKXD2&coliid=I3OBXY6MSF1W6W
anyone have any experience with these? Good?, Bad? Ugly?
Offline iLLucionist
  • Topre is Love.
Re: folding keyboards
« Reply #1 on: Tue, 12 April 2016, 18:34:44 »
No experience, but what about a HHKB? It is a bit smaller than the leopold and because it is case-mounted it is really light (opposed to the plate-mounted fc660)
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #2 on: Tue, 12 April 2016, 20:22:56 »
I approve, get a HHKB and a nice sleeve for it (!). 👍 (⬅ You see that? That's the Thumb of approval.)
« Last Edit: Tue, 12 April 2016, 20:24:29 by Olumin »
Offline chuckdee
« Reply #3 on: Tue, 12 April 2016, 21:26:51 »
I don't have any experience with those specifically, but I did use a folding keyboard for the purpose that you said (writing on the ipad), and it was an exercise in frustration.  I also tried those folio type keyboards, and didn't like that either.  I finally got the logitech keys to go, and it feels surprisingly good.
http://www.amazon.com/Logitech-Ultra-Portable-Bluetooth-Keyboard-920-006701/dp/B00R0I71S4
The clamcase also felt good, but it added too much weight for me.
Offline Olumin
« Reply #4 on: Tue, 12 April 2016, 21:43:14 »
Just as a note for the Thread Starter, the pictures of the "Logitech Keys-To-Go" might suggest that it is flexible or rubbery, it is not, it is indeed a solid keyboard made of hard plastic with a kind of smooth texture to it, it is really quite durable. That being said, if you might suggest getting the "Logitech Keys-To-Go", keep in mind that a HHKB is about the same size, perhaps even smaller, so you might as well just get a HHKB, but the "Logitech Keys-To-Go" will save you a bit of money.
« Last Edit: Tue, 12 April 2016, 21:52:13 by Olumin »
Offline Olumin
« Reply #5 on: Tue, 12 April 2016, 21:43:37 »
I posted this comment accidentally and don't know how, or in fact IF I am even able to delete it, wouldn't that be quite a feature hm? In the meanwhile, try to ignore it, I know its hard.
« Last Edit: Tue, 12 April 2016, 21:48:06 by Olumin »
Offline iLLucionist
  • Topre is Love.
« Reply #6 on: Wed, 13 April 2016, 05:07:36 »
Well.. it must be really durable. If it is as with all my previous logitech keyboards, I threw them away after 6-8 months. So in the long term, a HHKB may me more durable.
Also, on the HHKB you can replace caps but you cannot do that with this logitech thingy.
Offline chuckdee
« Reply #7 on: Wed, 13 April 2016, 09:23:03 »
I've had mine for about 2 years, and it has gone with me in my bag almost every day.  I'd think that replacing caps would be less of an issue than durability and size.  And though the layout is the same size as the HHKB, the thickness is not.  As the poster said, it is firm enough to give support, but it's only about as thick as a thin magazine.
Dimensions of HHKB from Amazon:
Item Weight   1.7 pounds
Product Dimensions   11.5 x 5 x 1.5 inches
Dimensions of Logitech Keys-to-Go from Amazon:
Item Weight   6.2 ounces
Product Dimensions   5.4 x 9.5 x 0.2 inches
As you can see, there's quite a difference in dimensions.  Especially considering 1.7 pounds to 6.2 ounces (.3875 lbs)  Or to put it another way, one weighs more than an iPad Air.  The other one, considerably less.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #8 on: Wed, 13 April 2016, 09:54:17 »
How about the Microsoft folding keyboard?
I have one and it feels quite nice. The only thing is that if you have bad typing habits it will take a while to get used to it.
|||My other keyboards :
x
Offline chuckdee
« Reply #9 on: Wed, 13 April 2016, 10:29:56 »
I tried that one, and the keys got to me (and that gap!).  Not enough feel from the keys as they're flush- sort of like the g20 keycaps.  If you can get past that, either (the folding or non-folding) are good products. I just tried both and couldn't get past that.  The universal mobile keyboard has the distinct keys, but I never tried that one as it seemed it had issues with the hardware from the reviews.
« Last Edit: Wed, 13 April 2016, 10:32:35 by chuckdee »
Offline iLLucionist
  • Topre is Love.
« Reply #10 on: Wed, 13 April 2016, 10:46:24 »
Yeah I see what you mean. I'm just heavily biased against logitech kb because I find them crap. But apparently they can last very well. And yeah the logitech is smaller in height, I can see that being important.
Still, I would buy a HHKB. But that's personal, of course.
Offline hotrattz
« Reply #11 on: Wed, 13 April 2016, 10:58:16 »
I decided to try the EC technology keyboard http://www.amazon.com/EC-Technology-Foldable-Bluetooth-Smartphones/dp/B00QT8WQ86?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00  gonna give it a go.  I considered getting a planck https://www.massdrop.com/buy/planck-mechanical-keyboard but $160 in plus needing a 40 connector cable for my ipad it was a bit more than i wanted to spend right now.  we shall see...
Offline iLLucionist
  • Topre is Love.
« Reply #12 on: Wed, 13 April 2016, 11:29:01 »
Cool! Let us know what you think. Gonna post a (brief) review maybe?
Offline chuckdee
« Reply #13 on: Wed, 13 April 2016, 13:36:57 »
It's got good reviews- so that's a good thing (as long as they're kosher).  I have a planck I just got, and the case makes it a bit heavy for carrying around, though some do it.
I have a stowaway personally, and have had it forever and it still works!  But I found that for long-term typing, I wanted something a bit larger, if not heavier.  but I hope it works for you!
Offline hotrattz
« Reply #14 on: Wed, 13 April 2016, 13:39:04 »
Yeah this is just for on the go "im in a coffee shop today" deal not my main board by any stretch
Sent from my iPad using Tapatalk
Offline Darkshado
« Reply #15 on: Thu, 14 April 2016, 01:08:59 »
If the foldable doesn't pan out, maybe this one could be interesting: http://www.amazon.com/ThinkPad-Compact-Bluetooth-Keyboard-TrackPoint/dp/B00C32FWJC
