Author Topic: Starting keycap crafting  (Read 176497 times)
Offline Suembeaux
Re: Starting keycap crafting
« Reply #250 on: Thu, 23 June 2016, 16:35:59 »
i like the 2nd from left if u decrease the length like not making the round shape on top of the caps
Yeah, pushing the body of the Chain Chomp further down onto the cap would make it a must have design for me.
A bunch of stuff. Someone teach me how to properly solder.
/u/Shartastical
Offline appleonama
  • Trollo en USA
« Reply #251 on: Thu, 23 June 2016, 16:38:52 »
« Reply #252 on: Thu, 23 June 2016, 17:23:13 »
Offline SBJ
  • Tactile pls
« Reply #253 on: Fri, 24 June 2016, 08:54:03 »
These are super cute!
Well done m8.
Offline Moistgun
  • Slippery When Wet
« Reply #254 on: Fri, 24 June 2016, 15:14:02 »
Can you explain the tom and jerry meme?
Offline appleonama
  • Trollo en USA
« Reply #255 on: Fri, 24 June 2016, 15:14:42 »
just me posting random tom and jerry images?
Offline JT_Sea
  • Um hi
« Reply #256 on: Fri, 24 June 2016, 16:01:14 »
Is that all it is, or are do they mean something?
Is Tom and Jerry going to be the next egg head or sax guy?
« Reply #257 on: Fri, 24 June 2016, 16:55:41 »
It's just apple forcing another "meme."
Offline JT_Sea
  • Um hi
« Reply #258 on: Tue, 28 June 2016, 10:02:28 »
Been working on something else while I keep working on the topre Bonk.
The bubs are real there on the minty/celets ones. Fortunately for me I'm only using them as tests.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #259 on: Tue, 28 June 2016, 10:12:35 »
So slick, especially the faded look of the purple modifiers
« Reply #260 on: Tue, 28 June 2016, 10:17:03 »
Hot tamale, those red/purple blanks are on fire.
Offline JT_Sea
  • Um hi
« Reply #261 on: Tue, 28 June 2016, 10:22:13 »
So funny that you guys like them so much, I was actually trying to do a multi shot, you know with the distinct layers...
Moar work for me.
They did turn out alright for a failure though, and they have a matching bonk!
Offline JT_Sea
  • Um hi
« Reply #262 on: Wed, 29 June 2016, 10:01:22 »
So I tried a thing last night
Lots o bubs but an interesting experiment thats mostly successful.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #263 on: Wed, 29 June 2016, 10:16:20 »
Hold on, is that a peach gummy or a keycap?!
« Reply #264 on: Wed, 29 June 2016, 10:22:32 »
Both!
Offline JT_Sea
  • Um hi
« Reply #265 on: Wed, 29 June 2016, 10:36:09 »
Offline misconceit
« Reply #266 on: Wed, 29 June 2016, 10:57:21 »
Is dremel or a normal engraving knife better when making the prototype?
HHKB Pro 2 Type-S
HHKB Pro 2
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #267 on: Wed, 29 June 2016, 12:01:55 »
Just eat it and find out ;)
@JT_Sea, it looks pretty awesome!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #268 on: Wed, 29 June 2016, 12:34:03 »
Offline Epic
« Reply #269 on: Wed, 29 June 2016, 12:37:30 »
Keep those away from me... they look like delicious haribo peach gummies!
Offline JT_Sea
  • Um hi
« Reply #270 on: Wed, 29 June 2016, 12:44:38 »
Thanks man!
I use some of those dental tools you can find on ebay, then I have a variety of sanding devices for after I bake the initial sculpt.
Offline Peripheral Prophet
  • Lets change the game
« Reply #271 on: Wed, 29 June 2016, 17:37:02 »
JT, did you make those HHKB Topre modifiers?
Check out my live build streams on twitch and join my discord! https://discord.gg/QzeSQj2  https://www.twitch.tv/peripheral_installer
« Reply #272 on: Wed, 29 June 2016, 18:15:07 »
He sure doded.
Offline JT_Sea
  • Um hi
« Reply #273 on: Wed, 29 June 2016, 22:27:44 »
Like Romevi said - sure did
Offline JT_Sea
  • Um hi
« Reply #274 on: Thu, 30 June 2016, 10:19:36 »
So more experiments with mods
These look cool when they aren't on a board, but I think they are a bit overwhelming once they are there. Oh well, just an experiment.
And more importantly, getting closer on the topre base
Still not quite there, but much much better and loving the thick walls too.
« Reply #275 on: Thu, 30 June 2016, 10:25:16 »
I need those blue/white mods.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #276 on: Thu, 30 June 2016, 10:29:05 »
Whoa..
« Reply #277 on: Thu, 30 June 2016, 10:34:36 »
Are the topre stems hard to get to fit properly?
Do the castings from the original topre caps not replicate the stem in the same way?
Offline JT_Sea
  • Um hi
« Reply #278 on: Thu, 30 June 2016, 10:39:07 »
They fit fine if you just take a cast of a regular cap, but the difference between thermoplastic and smoothcast liquidplastic is noticeable. The stem ends up being a little less sturdy because its thinner.
This is why you'll see reinforced stems from artisan makers, it just makes the whole thing much more solid and easier to deal with.
« Reply #279 on: Thu, 30 June 2016, 12:23:40 »
That makes sense, casting resin probably is more brittle as well, with less flex Im assuming...  Im putting in an order with smooth on so I guess Ill see for myself soon enough lol.
Offline dannrawr
« Reply #280 on: Sun, 03 July 2016, 16:48:26 »
Got my bonks last friday! Colorway are so cool but Kinda hard to capture the real color. Thanks jt
WTF any Bruce, Cosmonauts
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #281 on: Sun, 03 July 2016, 17:19:57 »
I just want to bite it, one little nibble *nom nom*
Offline Suembeaux
« Reply #282 on: Mon, 04 July 2016, 00:37:57 »
Exciting stuff dude, keep it coming.
/u/Shartastical
Offline JT_Sea
  • Um hi
« Reply #283 on: Mon, 04 July 2016, 17:35:32 »
Yeeeeee!
This makes me so happy, thanks for sharing.
Offline JT_Sea
  • Um hi
« Reply #284 on: Thu, 07 July 2016, 10:07:11 »
Finally got around to thickening up the sidewalls of Alps.
Not really worried about the bubbles, that I can deal with when I'm not pouring at 3 am.
Fresh Topre stem
Oh hai
Whaley McWhaleface still needs more work, but I was super excited to get er cast and see how it looked.
« Reply #285 on: Thu, 07 July 2016, 10:21:19 »
Dat whale.
Offline JT_Sea
  • Um hi
« Reply #286 on: Thu, 07 July 2016, 13:26:23 »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Offline dannrawr
« Reply #288 on: Thu, 07 July 2016, 13:44:50 »
laboon one piece
« Reply #289 on: Thu, 07 July 2016, 15:03:13 »
Offline JT_Sea
  • Um hi
« Reply #290 on: Thu, 07 July 2016, 15:46:55 »
Dat whale.
:D
Just do it.
What kind of whale is that sculpt?
Not a narwhale, probably close to a sperm whale if its mouth was up higher
Offline Raenbo
  • IG: @aero_keys
« Reply #291 on: Wed, 13 July 2016, 04:28:14 »
The whale looks promising! Can't wait to see your final draft of it  :p
Offline JT_Sea
  • Um hi
« Reply #292 on: Fri, 15 July 2016, 10:19:28 »
Offline Suembeaux
« Reply #293 on: Fri, 15 July 2016, 20:45:21 »
I like the lower profile, I think if you can clean up the sides to better differentiate the flat walls of the cap from the whale it would be more distinguishable.
Progress looking good!
/u/Shartastical
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #294 on: Fri, 15 July 2016, 20:58:45 »
whalewizbro is chill whale :D
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #295 on: Fri, 15 July 2016, 21:02:13 »
Dude, those whales look awesome  :thumb:
« Reply #296 on: Sat, 16 July 2016, 00:00:06 »
Why did you revise it? Did the other one not work too well? How does the new one sit compared to the old?
Offline kawasaki161
« Reply #297 on: Sat, 16 July 2016, 08:59:04 »
Just wanted to thank you for this, especially because I only expected one Bonk to arrive.
Offline JT_Sea
  • Um hi
« Reply #298 on: Mon, 18 July 2016, 10:09:11 »
:D Glad you got one of the bonus sets. I had a few bonks + matching blanks when I did the raffle and just randomly sent them out. You are also the first person to say anything!
Offline JT_Sea
  • Um hi
« Reply #299 on: Mon, 18 July 2016, 10:18:15 »
So the red and purple ones are the newer slimmer profile. The brown is the original. We've been tossing around the name in the Seattle r/mk meetup slack of Regina.
I actually broke the master when I pulled it out of the mold, so I've been using the red one as the 'new master' and refining that one.
Finally have enough torpe bonks to make new molds. I'll be pouring my first topre mold tonight.
