Author Topic: [IC] Mech27-TKL | Custom Aluminum Keyboard [Launching]  (Read 131668 times)
Offline 27
  • The Maple Man
Re: [IC] Mech27-TKL | Custom Aluminum Keyboard
« Reply #50 on: Tue, 19 April 2016, 07:43:38 »
Small update in the OP + info posts
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
Didn't notice my personal messages have been disabled for those thinking you have been blocked - to contact please reach out through Facebook messages or support email!
WEB: https://rama.works/
STORE: https://ramaworks.store/
INSTA: @ramaworks
FB: ramaworks
Offline 27
  • The Maple Man
« Reply #52 on: Tue, 19 April 2016, 21:34:24 »
New renders and a new idea!  I need to know what everyone things of this, yay or nay? Obviously would increase the price, but I don't know by how much.
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #53 on: Tue, 19 April 2016, 21:36:16 »
Looking great mate! Obviously if the price isn't substantial I reckon go for it :) You may need to radius the corners on those hexagons so the inner corner (on the enclosure) can be properly machined, but yeah, looks sweeet!
INSTA: @ramaworks
FB: ramaworks
Offline FrostyToast
  • Litshoard
« Reply #54 on: Tue, 19 April 2016, 21:40:19 »
That weight will be expensive. The Mira had to change from a single piece weight to using 3 connected pieces.
That change allowed each piece of the weight to have very simple cuts.
Machining that piece from one slab will be quote expensive and it will be unwise to separate them into multiple pieces. Those hexagons have to be oriented properly to fit in the case and therefore cannot be cut as separate pieces and screwed down unless the threads are precisely machined.
Quote from: elton5354
Offline 27
  • The Maple Man
« Reply #55 on: Tue, 19 April 2016, 21:42:06 »
Thanks for the advice! I'll definitely be looking into it a lot.  Just throwing around ideas right now :)
I'll also look at different materials for it, other than brass.
Offline FrostyToast
  • Litshoard
« Reply #56 on: Tue, 19 April 2016, 21:45:32 »
Stainless steel is the second most poplar weight material.
Also, do listen to Rama about having rounded off edges for the hexagons.
Due to the bits of cnc machines being circular, inner cuts have to be rounded at a minimum equal to the radius of the bit.
Offline 27
  • The Maple Man
« Reply #57 on: Tue, 19 April 2016, 21:52:58 »
Awesome! Thank you both.
Offline loud_asian
« Reply #58 on: Tue, 19 April 2016, 22:08:44 »
I'm digging the hexagons, can't say the same about the rectangular one. I think just having the numbers would look better than numbers + letters
Offline FrostyToast
  • Litshoard
« Reply #59 on: Tue, 19 April 2016, 22:11:15 »
The rectangular portion of the weight is the topside which is only visible when you open up the case and take our the PCB.
The hexagons are what appear on the underside of the case; it's just one single weight.
Offline 27
  • The Maple Man
« Reply #60 on: Tue, 19 April 2016, 23:30:40 »
What FrostyToast said.  They're the same piece, just different sides of it.  The larger rectangular part is inside the case, and will only be seen with the top removed.
Offline loud_asian
« Reply #61 on: Tue, 19 April 2016, 23:39:51 »
Ohh my bad, thought they were two different concepts. Anyhow, I'm all for the brass weight
Offline cozmonort
    • Coz Caps
« Reply #62 on: Wed, 20 April 2016, 05:29:33 »
Totally down for this, looks like it's going to be an amazing board!
Awesome work XX7!
Offline Patchwrks
Re: [IC] Mech27-TKL | Custom Aluminum Keyboard [NEW Renders]
« Reply #63 on: Wed, 20 April 2016, 13:10:37 »
Definitely down for the big weight
(´・ω・`)denko-chan~~~내 스레드
Offline 27
  • The Maple Man
« Reply #64 on: Wed, 20 April 2016, 22:26:09 »
Even more new renders!
This time I decided to render the weight as stainless steel, just to get an idea of how it would look.  I believe that this is the final revision before I get a prototype.  I'll try to get ballpark costs of it in a groupbuy when I place the order for a prototype. I also updated the detailing on the weight, with a maple leaf, because Canada.
Not really sure why the aluminum material causes it to look splotchy...
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #65 on: Wed, 20 April 2016, 22:42:50 »
The stainless weight plate looks amazing mate, I think it looks classier than the brass. Very nice!
INSTA: @ramaworks
FB: ramaworks
Offline SixtyLife
« Reply #66 on: Wed, 20 April 2016, 22:57:37 »
interested.
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline ntitco1
« Reply #67 on: Wed, 20 April 2016, 23:02:20 »
I'm super down  :))
Offline mrkevint
  • OK.
« Reply #68 on: Wed, 20 April 2016, 23:07:33 »
I dig the hexagon/maple leaf look... It's a unique take. I'm from Canada too so it'd be awesome to have a custom from here!
Offline rawkus
« Reply #69 on: Thu, 21 April 2016, 02:01:46 »
Very nice!
Interested...!
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #70 on: Thu, 21 April 2016, 03:00:44 »
Loving the HEX shapes and of course your Canadian Leaf which is something to like, in a world still worshiping the Stars and Stripes and Union Jacks.
Hope your keyboard becomes a reality here, we can never have too much TKL love on GH Central  8) .
Offline ika
« Reply #71 on: Thu, 21 April 2016, 03:43:27 »
hey look, perspective renders! yay!
If that gray-looking piece is a PC diffuser, you may need to consider filling the insides with it in order to get under-PCB light to diffuse properly. Otherwise you might have an issue getting even light, with the screw holes in the way, depending on rgb placement etc.
also hopefully you plan to have your plate support switch top removal!
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #72 on: Thu, 21 April 2016, 06:36:33 »
The new renders look great!
Offline guy12
« Reply #73 on: Sat, 23 April 2016, 09:03:04 »
Any chance we could get roman numerals, ex: XX2, XX7.
Offline kiwi99
  • that's a gnarly dookie
« Reply #74 on: Sat, 23 April 2016, 13:15:15 »
do you mean XXVII for 27? This could be cool I guess,
Offline 27
  • The Maple Man
« Reply #75 on: Sat, 23 April 2016, 13:30:34 »
I'm not quite sure where you'd want that on the board.  I can't do individually numbered boards, so it would be the same  across all of them.
Offline Waateva
« Reply #76 on: Sat, 23 April 2016, 13:35:16 »
I like custom TKLs
Offline 27
  • The Maple Man
« Reply #77 on: Sat, 23 April 2016, 13:39:06 »
Offline Waateva
Offline alveeno
« Reply #79 on: Sat, 23 April 2016, 14:03:54 »
I'd be in!
Offline fi0x
« Reply #80 on: Sat, 23 April 2016, 22:19:42 »
Keyboard looks great!
If the Hubble Mira doesn't go through I will definitely be in on this.
Great to see an awesome project from Canada! All for that maple leaf.
« Last Edit: Sat, 23 April 2016, 22:21:41 by fi0x »
~I̶ ̶a̶m̶ ̶n̶o̶t̶ ̶a̶ ̶k̶e̶y̶b̶o̶a̶r̶d̶ ̶g̶e̶e̶k̶ ̶(̶I̶ ̶w̶o̶u̶l̶d̶ ̶l̶i̶k̶e̶ ̶t̶o̶ ̶t̶h̶i̶n̶k̶ ̶I̶'̶m̶ ̶o̶n̶e̶)̶ I am a keyboard geek~
Offline AgentZen
« Reply #81 on: Sun, 24 April 2016, 04:00:47 »
I'm really starting to get my heart set on this keyboard. For those that have joined GB for custom TKLs with a limited number of spots, how hard do you think it is going to be to get into this buy? I guess I should start keeping a very close eye on the group buys forum.
KUL ES-87 w/ Clears (GMK Hyperfuse) | Working on: Custom 60% w/ 65g feelios (BSP blanks)
Offline ntitco1
« Reply #82 on: Sun, 24 April 2016, 04:26:01 »
iirc, 25 slots of jane ce ran out in like 10 minutes lol
Offline 27
  • The Maple Man
« Reply #83 on: Wed, 27 April 2016, 07:42:47 »
Adding a partial plate option
Should be something nice to try out.
Offline ccarlitos2
« Reply #84 on: Wed, 27 April 2016, 13:31:08 »
Yeeeeee I'm hyped
Offline 27
  • The Maple Man
« Reply #85 on: Wed, 27 April 2016, 19:57:28 »
Guess who has more renders!  I know everyone is probably tired of just renders, but this should be fairly representative of the colour options.
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #86 on: Wed, 27 April 2016, 20:25:14 »
Awesome work yet again 27!! Looking great, loving the color schemes you came up with :D
INSTA: @ramaworks
FB: ramaworks
Offline FrostyToast
  • Litshoard
Re: [IC] Mech27-TKL | Custom Aluminum Keyboard [Renders of Colour]
« Reply #87 on: Wed, 27 April 2016, 21:22:43 »
Those renders with the brass look more like champagne gold to me.
I wonder what the real colour will be though.
Offline Butter
« Reply #88 on: Wed, 27 April 2016, 21:23:47 »
That gold one. So hype!!
Offline 27
  • The Maple Man
« Reply #89 on: Wed, 27 April 2016, 21:27:34 »
Is that what it would be called? I was describing it as a darkish-gold.
Offline FrostyToast
  • Litshoard
« Reply #90 on: Wed, 27 April 2016, 21:46:40 »
It actually looks lighter than most golds I have seen.
Champagne gold is a pale light variant of gold. Perhaps the lighting in the renders is off.
Offline exitfire401
  • The Force is Re/\l
« Reply #91 on: Wed, 27 April 2016, 21:49:46 »
If that Cyan comes out anywhere remotely close to that render, I'll have to be all over this.
Offline 27
  • The Maple Man
« Reply #92 on: Wed, 27 April 2016, 21:54:00 »
I'll just call it gold and finalize the colour once the prototype is ready to be ordered.
Offline KetchyKech
« Reply #93 on: Wed, 27 April 2016, 22:02:26 »
these renders are phenomenal, I've never seen so many great color choices in one place when it comes to IC/GBs. Awesome  :thumb:
Offline 27
  • The Maple Man
« Reply #94 on: Wed, 27 April 2016, 22:05:54 »
Thanks :) I've been learning a lot while working up to getting a prototype, and I think the slow improvement of the renders really shows that.
Offline guy12
« Reply #95 on: Thu, 28 April 2016, 15:22:54 »
HYPE!!! Excited for this GB :D
Offline AgentZen
« Reply #96 on: Fri, 29 April 2016, 02:21:31 »
I'm all in on cyan
Offline kurtle107
« Reply #97 on: Fri, 29 April 2016, 10:48:07 »
im totally in, please let me know when you want to run it
Offline Jemaunji
« Reply #98 on: Fri, 29 April 2016, 10:48:33 »
Okay 27 you got me, I'm in. I'm going to hold you to that chronic edition though!
Offline 27
  • The Maple Man
« Reply #99 on: Fri, 29 April 2016, 17:47:07 »
Show your support with this beautiful banner!
Code: [Select]
[url=https://geekhack.org/index.php?topic=81351.0][img width=400 height=120]http://i.imgur.com/LshJ7SB.png[/img][/url]
I'll update it once I get moving out of the IC stage :)
