Author Topic: dvorak mechanical keyboard?  (Read 27425 times)
Offline chimera15
« on: Wed, 16 December 2009, 11:46:40 »
Learning dvorak has been kind of difficult for me, I've been at it for about 2 weeks now.  I keep finding myself going back to qwerty cause the disparage of my speed is too great, 90-100 wpm in qwerty to 15 in dvorak currently.
Remembering back to when I was learning qwerty I would constantly glance down at my keys on my keyboard to give my brain a visual cue where the keys were before I had them totally ingrained in my mind.
One of the things I'm having difficulty remembering is that it's a o e u i layout for the vowels, this slows me down a bunch having to remember which key is under which finger constantly.  Also I think it would force me to use the board more if I couldn't just switch back to qwerty so easily.
So does anyone know if there's a proper mechanical dvorak keyboard?  Preferably using white alps or blue cherries?
Preferably one that doesn't cost a fortune either. lol
http://cgi.ebay.com/RARE-FingerWorks-TouchStream-LP-DVORAK-Keyboard_W0QQitemZ270502124811QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item3efb2edd0b
This one looks interesting:
http://cgi.ebay.com/TypeMatrix-Ergonomic-Keyboard-Dvorak-Qwerty_W0QQitemZ190348000777QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item2c519ffe09
Scissor switches I guess?
I guess I could get those stickers hmm.
« Last Edit: Wed, 16 December 2009, 11:54:49 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline AndrewZorn
« Reply #1 on: Wed, 16 December 2009, 12:01:12 »
1 - switching back is what is going to make the process take longer, if it doesnt stop it from happening completely.
2 - print layout and hang it on wall behind monitor.  reminds you of keys without looking down.
3 - google for the QIDO device, use any keyboard you want, get "hardware" dvorak support.  ignore lettered keys, get blank keys, sometimes you can even rearrange keys... but you severely limit your choices when you are picking a keyboard just by its [non-physical] layout.
Offline chimera15
« Reply #2 on: Wed, 16 December 2009, 12:09:41 »
Quote from: AndrewZorn;142995
Those are good suggestions.. I did the hanging the layout on the wall thing, except I used a separate computer screen which is essentially the same thing, but I don't think it has the same psychological impact as pressing your finger on the actual letter.  I mean if I glance down at my board and see that I'm pressing nothing, or even the wrong letter it doesn't enforce the idea in me to the bone that this key equals this letter you know?
Sides there's the coolness factor, and not having to use a tsr or different driver/input change if you change the board to a different pc. lol
I suppose I can make one, the problem will be the caps.  I suppose I could make it a steampunk dvorak board...hmm...
Alps boards:
Offline Viett
« Reply #3 on: Wed, 16 December 2009, 12:16:27 »
Quote from: chimera15;143000
This is just something you're going to have to get used to. Ideally, you won't look down at all. I know it's really uncomfortable at first (I went through this 3 times), but you become a much better typer in the long run.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline AndrewZorn
« Reply #4 on: Wed, 16 December 2009, 12:45:10 »
and the QIDO device is small, portable... the whole POINT is to avoid trouble when moving the keyboard to a different computer.  a single hardware dvorak keyboard is probably more trouble than dvoraking any keyboard.
Offline ecru
« Reply #5 on: Wed, 16 December 2009, 15:12:01 »
IBM Model M or derivatives have identical keycaps that can be interchanged without messing up key heights / angles.  Also some older membrane boards are similar.  As you mentioned, stickers are another alternative.
Personally I found keyboard drills more useful than swapping keycaps.
Eg http://gigliwood.com/abcd/
Offline leos
« Reply #6 on: Wed, 16 December 2009, 16:17:08 »
is easy to learn dvorak or colemak if the user uses qwertz? is also efficient to do this?
can i type ü,ß,ö,ä, also with dvorak or colemak?
HHKB 2 Pro Black in use :typing:
Offline leos
« Reply #7 on: Wed, 16 December 2009, 16:32:07 »
Quote from: webwit;143086
If you haven't learned this, it is pretty hard.
ohhhh!!
i know this site -----lmgtfy.com
but... i dont know that colemak was multilingual.
many thanks
edit-----
 German (Deutsch)
    * ä, ö, ü: AltGr+[q], AltGr+[;], AltGr+[y]. Alternative: AltGr+[d] {letter}
    * ß: AltGr+
forget it
Offline lowpoly
« Reply #8 on: Wed, 16 December 2009, 16:39:20 »
I use Colemak with International English input language and dead keys for ' and ". I'm not too happy with the dead keys but rather that than AltGr. I never use the ß.
Offline spremino
« Reply #9 on: Wed, 16 December 2009, 18:27:09 »
Quote from: chimera15;142987
Glancing down at the keyboard does not help with Dvorak, since the letter your are looking for is very likely right under a finger of yours. Moreover, you will keep glancing, and that will slow down your memorization process.
As it has been suggested already, do not swap keycaps on your keyboard, but print the layout and hang the print somewhere. I know it's difficult, but it can be done, and it will be rewarding in the long term.
Yes, vowels are an issue while you are learning. I remember having issues with V and W too.
By all means, practice with a tutor like ABCD.
Keep up the good work!
A long space bar... what a waste of space!
Offline AndrewZorn
« Reply #10 on: Wed, 16 December 2009, 18:58:19 »
or give up and give in to colemak
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #11 on: Wed, 16 December 2009, 19:48:26 »
Quote from: AndrewZorn;143128
Lol.
Be patient, you'll learn the layout eventually.
Switch back to QWERTY whenever you get frustrated, then back to dvorak once you calm down again. This really helped (my sanity) when I was learning dvorak (and Colemak as well).
I've been learning Colemak for a over a month now, and I finally feel like I have a good grasp of the layout (never have to look at a Colemak layout now). The more familiar with the layout you are the higher you can get your maximum typing speed.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline spremino
« Reply #12 on: Thu, 17 December 2009, 02:44:54 »
And start complaining that on Colemak you're pressing R instead of S and viceversa all the time, and that some rolls give you the willies ;-)
Jokes apart, each layout has its stumbling blocks you'll overcome eventually.
Offline lowpoly
« Reply #13 on: Thu, 17 December 2009, 03:26:04 »
Quote from: webwit;143099
Exactly. :-(
Offline spremino
« Reply #14 on: Thu, 17 December 2009, 03:39:13 »
Quote from: leos;143085
Colemak has been designed to be an easy transition from Qwerty. I'd say that is the same from Qwertz.
Nope.
Dvorak hasn't any official variant supporting accented characters. Unofficial variants exists which do that. Search the Internet for a Dvorak layout targetting your language.
Colemak does have an international variant, but AFAIK it has not been designed for extensive use. Maybe there are Colemak variants for different languages too. Check the Colemak forum: http://forum.colemak.com/
Offline lowpoly
« Reply #15 on: Thu, 17 December 2009, 05:45:48 »
Maybe NEO is something for you.
Offline leos
« Reply #16 on: Thu, 17 December 2009, 14:12:21 »
Quote from: lowpoly;143190
take look to the "Sonderzeichenebene".
()[] are in the wrong place for me
