Author Topic: [IC] TriC 60% case/kit (GB is live)  (Read 32919 times)
Offline Gengarfan
Re: [IC] TriC 60% case/kit (price dropped)
« Reply #50 on: Sat, 30 April 2016, 12:26:15 »
Hey Lunaris, would you mind making a note for me about not having the artist's mark again? I forgot to put it at the end in the notes :confused:
Sure thing. There's going to be something small, currently slated to be "1.11", within the case itself, underneath the acrylic layer. He insists on having a mark somewhere, but at least this will be out of sight unless you disassemble the case.
Anything not visible on the outside is fine with me :)
Offline Diokhan
« Reply #51 on: Sat, 30 April 2016, 13:06:36 »
Hey Lunarisdream, can you delete my previous entries? the last one I sent is the correct one :)
Offline LunarisDream
« Reply #52 on: Sat, 30 April 2016, 13:16:11 »
Done~
Offline Diokhan
« Reply #53 on: Sat, 30 April 2016, 13:16:53 »
Done~
Thanks! :)
Sent from my Nexus 6P using Tapatalk
Offline roostrc0gburn
  • its just plastic
« Reply #54 on: Sat, 30 April 2016, 18:09:44 »
definitely in on this. LD, is your TriC a silver one?
« Reply #55 on: Sat, 30 April 2016, 20:50:09 »
Yep! It looked too sleek to pass up.
Offline Diokhan
« Reply #56 on: Mon, 02 May 2016, 01:40:40 »
You got some better pictures of the different colors?
The lighting on the pictures are a bit uhm shady? :P
Offline ika
« Reply #57 on: Mon, 02 May 2016, 01:47:43 »
These pics look fine to me: https://drive.google.com/folderview?id=0B2wnMwNC5TvTclNtM1pRS3VCenM&usp=drive_web
color options are black, silver, dark gray, and a TBD (not purple). Pretty common colors. Not sure what factory is making this - maybe the same one as ZZ96/AMJ96?
Offline Diokhan
« Reply #58 on: Mon, 02 May 2016, 01:56:35 »
The pictures of the the gray and black are bit dark.
I'm not sure if I want the gray.
Would be nice to see the underside like with the silver and the purple.
« Reply #59 on: Mon, 02 May 2016, 02:00:50 »
Nope. ZZ96 is actually switching factories and some colors options were removed in the process. I had no say in the matter, and don't know if AMJ96 is doing the same. :|
Actual color samples from the factory (not actual cases) will be here in the next couple days.
Offline Diokhan
« Reply #60 on: Mon, 02 May 2016, 02:06:47 »
cool! thanks for the info
  • its just plastic
« Reply #61 on: Mon, 02 May 2016, 13:09:34 »
colors available for plates too?
« Reply #62 on: Mon, 02 May 2016, 13:38:28 »
Yep. Same factory, same colors.
Offline GiveCandyy
« Reply #63 on: Mon, 02 May 2016, 22:57:31 »
oh yes chance for purple! does non-us still use the old form? :thumb:
went on the test website and put dgb instead of ldgb....
I wish it wasn't soon
« Reply #64 on: Tue, 03 May 2016, 02:36:18 »
I received word back and purple is unfortunately not happening. Sorry folks.  :(
Offline Diokhan
« Reply #65 on: Tue, 03 May 2016, 02:41:30 »
Can't wait for the color samples :D
still a bit torn between gray and black.
Offline GiveCandyy
« Reply #66 on: Tue, 03 May 2016, 02:53:02 »
excitement crushed.
« Reply #67 on: Tue, 03 May 2016, 09:31:56 »
Color renders: http://sli.mg/a/xHgrta
Offline Gengarfan
« Reply #68 on: Tue, 03 May 2016, 13:57:26 »
I have never been so torn on what color I should choose... It's between black, silver, grey, and maybe the orange or blue. Anyone got some input?
Offline evangs
  • TheVan
« Reply #69 on: Tue, 03 May 2016, 13:58:48 »
Listen to your heart
Offline Gengarfan
« Reply #70 on: Tue, 03 May 2016, 14:00:44 »
My heart says all of them. Get all of them.
Offline evangs
  • TheVan
« Reply #71 on: Tue, 03 May 2016, 14:02:04 »
You might want to start working on that apology letter to your wallet XD
Offline Diokhan
Re: [IC] TriC 60% case/kit (GB is live)
« Reply #72 on: Wed, 04 May 2016, 02:01:50 »
Hey Lunaris I saw you had your stripe website up already.
Do we have to pay already? Or is it not live yet?
« Reply #73 on: Wed, 04 May 2016, 02:55:23 »
You can, and please also verify that the info in the Google form is accurate.
Offline vito687
« Reply #74 on: Fri, 13 May 2016, 07:59:12 »
I know I had an error with my email address and LD is going by what you have in the form so I'd double check with him
« Reply #75 on: Sat, 14 May 2016, 03:37:57 »
Thanks for trying to help! He's paid  :)
