Author Topic: Indicator lights on 1390120?  (Read 2250 times)
Offline y11971alex
  • Looking for Toronto meetup
« on: Sat, 23 April 2016, 12:24:40 »
Hello GH!
I received my 1390120 after a week of anxious waiting, along with two 1391472s, one with a completely disintegrated barrel plate due to DHL's gentle handling.
There are two mystery components on the PCB: a set of pins for what I thought was for indicator lights, and a partly transparent component on the board with 4.00 mHz p/n 1351544 and TEW5 29B.
 :D
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Indicator lights on 1390120?
« Reply #1 on: Sat, 23 April 2016, 12:31:01 »
MANDOLIN CRYSTAL IDENTIFIED
The 1390120 is a Model M that was made to be compatible with the XT (even though it also speaks AT), so it has no lock lights.
The transparent thing is a crystal oscillator that's only present on very early Model Ms.
Offline y11971alex
« Reply #2 on: Sat, 23 April 2016, 12:34:17 »
What's a Mandolin Crystal?  Is that something like a quartz oscillator in a watch?
Offline 0100010
  • Not Sure
« Reply #3 on: Sat, 23 April 2016, 12:41:00 »
Just an older component that one particular user in the past liked to hype up and talk about a lot.
