Author Topic: Keycaps for Ducky shine 5  (Read 7816 times)
Offline Erzegovaz
« on: Sat, 23 April 2016, 12:39:16 »
Hi guys, my friend has a beatiful ducky shine 5 RGB, and today ask me if in the future he could change keycaps without lose backlight.
Are there some keycaps set for RGB/backlite keyboard? PBT or ABS doubleshot? :D
Thankssssssssssss  :thumb:
Offline SKD
Re: Keycaps for Ducky shine 5
« Reply #1 on: Sat, 23 April 2016, 15:14:15 »
IKBC 104 PBT Double shot Translucidus Backlit Keycaps Key Cap For Cherry/Keycool/NOPPOO/PLU/HPE/Ducky/Filco Mechanical Keyboard
 http://s.aliexpress.com/63UraiEv
Sorry on my phone at the moment so can't link properly. I have a set on my Shine 5 at the moment and they are great for their price. Minr arrived in a week of ordering them. Would recommend if you're in a budget.
Offline carmenohio
« Reply #2 on: Sat, 23 April 2016, 20:32:21 »
There is this Vortex PBT+POM backlit compatible set that is double shot (1st shot pbt, 2nd shot pom).  I have this set and it works, only complaints I have are the legends are a bit fuzzy and the number row will only show the symbol lit instead of the numbers due to the placement of the legends.
http://www.wasdkeyboards.com/index.php/products/keycap-set/pbt-104-key-cherry-mx-keycap-set-backlit-doubleshot-black.html
« Last Edit: Sat, 23 April 2016, 20:34:27 by carmenohio »
« Reply #3 on: Sun, 24 April 2016, 01:12:35 »
Being in Italy, does your friend have an ISO layout keyboard?
Keycap sets might be a bit harder to find, but Ducky themselves do make a few backlight-friendly replacement sets.
Offline Erzegovaz
« Reply #4 on: Sun, 24 April 2016, 04:56:46 »
This is the keyboard, so they layout is ANSI :D https://www.amazon.co.uk/Ducky-Channel-Mechanical-Keyboard-Lighting/dp/B018LVLICS/ref=sr_1_1?ie=UTF8&qid=1461491754&sr=8-1&keywords=ducky+shine+5
I`ll tell to him, to contact ducky :D
Offline seville57
« Reply #5 on: Sun, 24 April 2016, 05:17:55 »
Check with your friend, sometimes Ducky use photos of the ANSI layout k-boards when the layout is a ISO layout.
https://www.amazon.co.uk/Ducky-Channel-Mechanical-Keyboard-Lighting/dp/B018LVLICS/ref=sr_1_1?ie=UTF8&qid=1461491754&sr=8-1&keywords=ducky+shine+5#Ask
This is from a Swedish shop sellin ISO/Nordic Ducky Shine 5 RGB/ Ducky One k-boards, we have/use the ISO/Nordic layout here in Sweden.
But in the links, you have  photos of the ANSI layout k-board.
https://www.inet.se/produkt/6607688/ducky-shine5-rgb-mx-red
https://www.inet.se/produkt/6607863/ducky-one-mx-red-white-led-black-chassi
My ANSI Ducky One RGB YOTG and my ISO/Nordic Ducky Shine 3.
« Last Edit: Sun, 24 April 2016, 05:55:58 by seville57 »
Offline SKD
« Reply #6 on: Sun, 24 April 2016, 10:11:04 »
I'm so confused. Are the cap sizes on both them boards different? How does the Ducky one look so much smaller than the Shine?
Offline seville57
« Reply #7 on: Sun, 24 April 2016, 14:32:10 »
Standard bottom row size on the ANSI/Ducky One RGB YOTG and on the ISO/Nordic Ducky Shine 3.
The only caps size different is the ISO "Big Ass Enter" and the ISO Left Shift.
The 2 orange Pumpkin caps on the Ducky One RGB don't belong to the Jukebox SA set.
My Ducky One RGB YOTG with the original white keycaps set.
« Last Edit: Sun, 24 April 2016, 15:51:31 by seville57 »
Offline SKD
« Reply #8 on: Mon, 25 April 2016, 12:36:09 »
I think it's just the perspective playing tricks on my eyes. It really looks like a whole numpad section smaller.
