Author Topic: GMK Triumph Adler, what is its real color?  (Read 7072 times)
Offline kasakka
« on: Fri, 29 April 2016, 15:42:52 »
The GMK Triumph Adler set seems to be notoriously difficult to photograph. Looking at the pics online the color ranges from a lighter teal-ish shade to a pretty dark blue tinted shade. What would you say is the real color of the keyset and is there any picture that comes close to reality? Is it more blue than teal?
Re: GMK Triumph Adler, what is its real color?
« Reply #1 on: Fri, 29 April 2016, 15:47:58 »
Dark teal, with more blue than green.
Offline Malenky
« Reply #2 on: Fri, 29 April 2016, 15:54:41 »
Renders would make it look more faded or retro than it is. The blue of the modifiers is actually a pretty deep blue, and as Romevi said, more blue than green.
« Reply #3 on: Fri, 29 April 2016, 16:01:31 »
Okay. I don't have TA in front of me, but I'm taking a wild stab here based off memory. I turned off my screen's blue filter, so hopefully I have this right.
This hex is pretty close to TA in real life, based solely off memory:
http://www.color-hex.com/color/1e7990
Offline Malenky
« Reply #4 on: Fri, 29 April 2016, 16:05:35 »
I'm typing on it right now, here is a picture comparing it to cyan. I feel like in the flesh, the blue is a bit deeper and more vibrant than it shows in the image.
Edit: Wow, Romevi, pretty damn close!
« Last Edit: Fri, 29 April 2016, 16:07:18 by Malenky »
Offline kasakka
« Reply #5 on: Sat, 30 April 2016, 06:12:41 »
Thanks! I guess I'm more into the GMK Cyan, just wish I could buy just a modifier set somewhere as the set on originative is hideously expensive to get to Finland.
Offline blighty
« Reply #6 on: Sat, 30 April 2016, 07:38:16 »
http://www.ebay.com/itm/GMK-Double-shot-keycaps-Cyan-Mod-Pack-for-MX-mechanical-keyboards-/222090922688
Cyan mod set for a hair under $70 usd shipped from Germany.  Seller seems legit.
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline gorillionaire
  • really gorilly
« Reply #7 on: Sat, 30 April 2016, 14:39:48 »
GMK seems highly regarded but 170 for keycaps seems excessive........... is it worth it?
« Reply #8 on: Sat, 30 April 2016, 14:43:09 »
Only if you want the best modern doubleshots.
  • really gorilly
« Reply #9 on: Sat, 30 April 2016, 14:47:21 »
I see my guy romevi!!!!!!
Offline ThoughtArtist
« Reply #10 on: Sun, 01 May 2016, 02:14:41 »
Welcome to a 8-bit-Colorland!
Is it a Teal? Is it a Green? Is it a Teal-Green? Or is it a Blue? It's up to YOU, my friend!!!
Offline zslane
« Reply #11 on: Sun, 01 May 2016, 12:01:21 »
Only if you want the best modern cylindrical doubleshots.
There, fixed it for you, romevi.
GMK keycaps are an excellent choice for folks who like cylindrical keycaps. I use sphericals exclusively, so as far as I'm concerned, GMKs aren't worth it at any price. Obviously, YMMV.
Offline jonathanyu
« Reply #12 on: Sun, 01 May 2016, 12:35:56 »
imo, any gmk set i have seen so far worth for 170, except ta.
Offline kasakka
« Reply #13 on: Sun, 01 May 2016, 23:54:52 »
Cyan mod set for a hair under  shipped from Germany.  Seller seems legit.
Thanks for the link but it doesn't have enough bottom row keys (missing one 1.25u) for my keyboard layout, no ISO shift nor the HHKB size right shift and backspace/delete key.
Offline Malenky
« Reply #14 on: Mon, 02 May 2016, 17:36:18 »
Maybe contact the seller? Missing a 1.25u bottom row key doesn't seem like something that would happen for any GMK set. Also, including an ISO enter without ISO left shift seems really weird. This leads me to believe that the first image just doesn't include all the keys.
Offline rand77
« Reply #15 on: Tue, 10 May 2016, 14:32:44 »
The color does seem to vary depending on the lighting in the photographs.
Looking at my set in daylight right now, I'd say its dark teal.  Firmly in the blue territory, with a hint of green.
Photographing at night under yellow indoor light makes it look really blue.
Offline Malenky
« Reply #16 on: Tue, 10 May 2016, 18:21:48 »
Yeah, to me this is totally too blue.
Offline rand77
« Reply #17 on: Tue, 10 May 2016, 18:40:16 »
Yea its "greener" and closer to teal in real life.  Could be the way my camera processes the colors too (Nexus 6).
