Author Topic: Radical Edward Keyboard  (Read 44853 times)
Offline Charger
Re: Radical Edward Keyboard
« Reply #50 on: Mon, 11 July 2016, 12:16:23 »
I I bent up some rack mount style handles for it but im not sure if they are too tall still or not.
they are not mounted on the board yet just sitting on it to give me an idea of their size.
images of the ed keyboard for referance
every time I look at them I remember how much they change from screen shot to screen shot lol
« Reply #51 on: Mon, 11 July 2016, 12:31:06 »
Whatever I was expecting from the title, it didn't live up to the thread content. Any time there's machining porn in a thread I'm really happy. Love where this build is going.
Offline Charger
« Reply #52 on: Mon, 11 July 2016, 12:42:30 »
there would me more machining porn but I have to drive 45 minutes to and from my lathe and mill which is at my parants house so I just bought a cheap $60 harbor fright drill press so I can keep working on it with out having to drive lol
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #53 on: Mon, 11 July 2016, 17:36:07 »
This is coming along nicely.
I think a bit of artistic license could be in order with those handles.
Are you planning on using a mouse too - if so I think those handles are going to get in the way quite quickly.
Anything higher than the keycaps themselves is going to get in the way I think.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #54 on: Mon, 11 July 2016, 17:41:26 »
That keyboard wouldn't be the same without the handles :confused:
Offline Charger
« Reply #55 on: Mon, 11 July 2016, 22:13:06 »
some is needed regardless because every time they drew it at a different angle even in the same part of the show it changes lol. But I don't view this as a practical keyboard so it being a little hard to use is fine by me.
agreed It needs that random rack mount keyboard feel lol
Offline Data
« Reply #56 on: Tue, 12 July 2016, 06:39:15 »
Does her computer have a cardboard case on it?   :))
Offline dgneo
  • Supervillain
« Reply #57 on: Tue, 12 July 2016, 07:12:18 »
IMO I'd shorten the height of the handles ever so slightly and they'll be perfect.
This build is incredible, great work here!
Offline Charger
« Reply #58 on: Tue, 12 July 2016, 11:39:45 »
ya... may want to try making that as well at some point lol. The fact that you said her tells me you know the anime lol.
I cut them down another 1/8" and they seem a bit better. I think I'm going to keep them at that for now but I could always cut them down more later.
Offline Data
« Reply #59 on: Tue, 12 July 2016, 12:55:45 »
Oh yeah.  Who doesn't know about Bebop at this point?  It's legendary.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #60 on: Tue, 12 July 2016, 13:01:32 »
A full rig build would need its very own glass case for viewing purposes :eek:
Offline invariance
  • ...here with all the other boson's
« Reply #61 on: Tue, 12 July 2016, 19:25:03 »
Nice work there Charger.
What about using countersunk screws for your top plates and then bog over the screw heads as it is going to be painted?
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline Charger
« Reply #62 on: Tue, 12 July 2016, 23:54:27 »
im part of an anime club on another forum and alot of the members have never seen it which just seems odd lol
no fun if it cant be used lol.
what I did was drilled through it and taped the holes so they are only small little spots where the screws are. I may leave them like that as I was thinking about leaving the top plate as raw aluminum. But if I do paint it I would be filling the holes before painting like you are saying.
On a side note... As I typed this replay my dog managed to knock over a unopened pepsi on my desk where it hit a tape measure and put a hole in it spraying my monitor and desk as well as resulting it a trail of soda all the way to the nearest sink... fun fun.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #63 on: Wed, 13 July 2016, 09:14:11 »
Very true! It must be used!
Offline Charger
« Reply #64 on: Fri, 14 October 2016, 22:33:37 »
just thought I should do a bit of an update just to prove this project is not dead I just have not had the time to finish it lately
I finally made the washers for under the handles as well as mounted the handles and made the bottom plate I was missing and a few other little things that I don't think need to be shown.
all that is really left in the todo list is order an Ethernet jack and cut a hole in the side for it before painting and putting keycaps on it... Oh and I still need to order keycaps and stabilizers.
Offline MajorKoos
« Reply #65 on: Sat, 15 October 2016, 09:22:25 »
That enter key is massive.  Where did you find it?
Offline Charger
« Reply #66 on: Sat, 15 October 2016, 10:11:48 »
i hunted ebay for a keyboard that had a big ass enter, 10u space bar, and used cherry switches for a few months
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #67 on: Sat, 15 October 2016, 10:18:07 »
That layout is surely as weird ss edward!! :) i love this show, cant wait to see the end product!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #68 on: Sat, 15 October 2016, 10:19:52 »
Offline a-c
« Reply #69 on: Mon, 28 November 2016, 12:15:34 »
Your project inspired my 40% Edward keyboard. http://www.40percent.club/2016/11/40-edward.html
Can't wait to see it completed.
Offline Dr_Alphabet
« Reply #70 on: Mon, 28 November 2016, 12:19:49 »
that's pretty slick. do you find those handles get in the way of typing at all?
Look at me. Look at me. Look what I can do. I'm amazing - Peter Gabriel
Offline a-c
« Reply #71 on: Mon, 28 November 2016, 12:51:02 »
They are fine when typing. It's when you reach for the mouse that it gets in the way. But Ed doesn't use a mouse.
Offline ProCarpet
« Reply #72 on: Sun, 27 August 2017, 06:40:12 »
I know i shouldn't bump old threads but i was wondering if you're still working on this? because i thougth it was an awesome project and it came along nicely.
Offline Fantaku
« Reply #73 on: Wed, 06 January 2021, 03:20:42 »
Just as the last guy, sorry for replying to an old thread (super late to the party here at this point) but I gotta see some resolution here 🙏 please, if there was ever a finished product from this project I gotta see it! This looks so cool, and I can't stand not knowing how the final build turned out if it was ever finished (if it wasn't, please I finish this work of art for the love of God!)
