Author Topic: Poker 3 LED: new functions  (Read 2712 times)
Offline jcoffin1981
« on: Mon, 09 May 2016, 01:38:17 »
So I discovered a new LED function that I have not seen before listed anywhere.  Fn + X controls the LED functions, but I accidentally pressed Fn + left Ctrl and while it scrolls through the functions, I found an additional one: there is a light which illuminates single keys that dances across all the rows.  There is also one of the settings which illuminates only the number 3.
After fixing the non-working LED's I may have shorted something when the excess length from the LED bulb was trimmed and it fell across the PCB.  What is really strange is that I have no LED function at all now in the layer 3, and I cannot get Fn + left Ctrl to initiate any functions.  After spending countless hours fixing non-working lights and switches this no longer works and I feel like I'm missing something now.  Can anybody confirm that their board also has this dancing light feature, and does the number 3 illuminate by itself?
Offline jcoffin1981
Re: Poker 3 LED: new functions
« Reply #1 on: Fri, 13 May 2016, 17:16:04 »
I was hoping somebody would reply.  I think this version of the poker may not have been so popular?  I'm curious about this illuminated number "3" as well as the dancing light that goes back and forth across the rows.
This is my new favorite keyboard and even though it functions perfectly for my needs, the fact that there are some features that are no longer working bother me and I'm considering replacing it.  I'm worried some functions my continue to deteriorate, such as the LED's not working in Layer 3 at all.  It's just $150 bucks can go to use for a lot of other things.
FN + left Ctrl = Win got this function working again.  I'd love to see if somebody else can do this, but apparantly no one owns the board.
« Last Edit: Mon, 16 May 2016, 11:38:12 by jcoffin1981 »
Offline lunas
« Reply #2 on: Fri, 20 May 2016, 18:14:43 »
Sorry can't help you on this. I've got the non-backlit Pok3r. I installed a handful of LEDs but not enough to test the setting you discovered. What version of firmware do you have on yours?
Pok3r Whitefox
