Author Topic: KC60 on Massdrop  (Read 66780 times)
Offline chuckdee
KC60 on Massdrop
« on: Mon, 09 May 2016, 10:00:35 »
KC60 dropping again on Massdrop
Also, found a good answer on Reddit that answered my questions about programmability, and difference from Pok3r.
https://www.reddit.com/r/MechanicalKeyboards/comments/3awybs/help_need_pok3r_programmability_clarification/
« Last Edit: Mon, 09 May 2016, 12:21:54 by chuckdee »
Re: GH60 on Massdrop
« Reply #1 on: Mon, 09 May 2016, 11:16:25 »
That font.. What were they thinking!?
Offline WNovizar
« Reply #2 on: Mon, 09 May 2016, 12:15:04 »
GH60 dropping again on Massdrop
Don't be ridiculous, that is not GH60.
I like mechanical keyboards
Offline ander
  • I type, therefore I am
« Reply #3 on: Tue, 10 May 2016, 00:47:37 »
Yeah, it didn't have to be bolded, did it? Looks fuzzy.
Pardon my ignorance, but where's Esc on these things? And can you still use the equivalent of Alt+Print Screen to take screenshots?
I'm also assuming you must use combinations for any kind of cursor movement... How can it be considered easier to use two or three keys for what you can normally do with one?
