Author Topic: How so I properly store my keyboards when not in use?  (Read 3716 times)
Offline supamesican
« on: Thu, 12 May 2016, 20:48:22 »
Finally ordered me a model F, right now I'm using a unicomp model M and will be putting it away for a few months while I get used to the F. Its still my first mech board and has the same birthday as my dad and grandma, so I want to make sure I store it correctly. How do I do that?
Offline Jokrik
Re: How so I properly store my keyboards when not in use?
« Reply #1 on: Thu, 12 May 2016, 20:51:03 »
Keyboard sleeve, no direct sunlight, non humid condition
or better, in a safety deposit box with lots of hounds :)
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #2 on: Thu, 12 May 2016, 20:52:22 »
Does a Model F fit in a LFRB game box from USPS? I use to store all my ALPS boards and Model Ms in those.
EDIT: These...
https://store.usps.com/store/browse/productDetailSingleSku.jsp?categoryNav=false&navAction=push&navCount=0&atg.multisite.remap=false&categoryId=shipping-boxes&productId=P_GB_FRB
Offline supamesican
« Reply #3 on: Thu, 12 May 2016, 20:56:06 »
Its the same size or less than an M iirc. so it may. Do I just get them at the post office, how much do they cost?
« Reply #4 on: Thu, 12 May 2016, 21:20:25 »
They are free.
If your local post office doesn't have them,  you can order them from USPS.com you order by the pack. So an order of 1 is like 15 or so.
Offline Belfong
« Reply #5 on: Thu, 12 May 2016, 21:30:25 »
I am just putting my SSK on a bookshelf, open display. It is collecting dust but I think it's good so far.
« Reply #6 on: Thu, 12 May 2016, 22:19:49 »
Bundle up the cable in something: An empty toilet paper tube works great. Don't ever wrap cables around keyboards - plasticizers in PVC cables could eat into the plastic of the keyboard and leave ugly marks.
Offline user 18
« Reply #7 on: Thu, 12 May 2016, 22:37:44 »
Most of my keyboards that aren't in active use are on display. In the house I'm living in for the summer, I have a shelf with old boards, and a shelf with modern boards.
Avatar by ashdenej
Offline HPE1000
  • Keycap Paparazzo
« Reply #8 on: Thu, 12 May 2016, 22:50:03 »
1. Start placing them on shelves and in cabinets
2. Run out of space on shelves and in cabinets
3. Start leaning them against the wall in closet
4. Run out of space in closet
5. Continue buying more keyboards with no idea where you will put them
6. ???
7. help me
For your case either find a box to store it in or a sleeve as people have said. :P
Offline Jokrik
« Reply #9 on: Thu, 12 May 2016, 23:38:30 »
6. ???
7. help me
LOL
So....first world problem!
Offline FrostyToast
  • Litshoard
« Reply #10 on: Fri, 13 May 2016, 00:03:45 »
6. ???
7. help me
LOL
Hey!
The homeless don't have anywhere to store their keyboards either!
It's an every world problem.
Quote from: elton5354
Offline eohmiller
« Reply #11 on: Fri, 13 May 2016, 15:25:07 »
At my house?
Offline Rad
« Reply #12 on: Fri, 13 May 2016, 15:47:31 »
In the box it came in?
Offline eohmiller
« Reply #13 on: Fri, 13 May 2016, 16:34:13 »
This makes sense realistically. ^
Offline Damonskv
« Reply #14 on: Fri, 13 May 2016, 16:38:43 »
The best way to store your keyboard is using pocker chips case. For model F - 500 chips case.
Offline Damonskv
« Reply #15 on: Fri, 13 May 2016, 16:42:31 »
Sorry, the model F is more than 23 cm in depth, but the pocker chips cases is 22 cm max. e.g. my ssk in perfectly suited 400 chips case
Offline supamesican
« Reply #16 on: Fri, 13 May 2016, 18:25:45 »
I'ma get one box for my unicomp and then buy a buffet cabinet to store them in and put their boxes in storage.
Offline jacobolus
« Reply #17 on: Fri, 13 May 2016, 18:44:08 »
You can store a Model M or Model F pretty much any way you want. They’re built like tanks. For best results though, don’t store it with the keys held down (i.e. don’t just make a stack of 20 loose keyboards on a shelf), and protect it from dust with some kind of cover or container. If there are ABS parts (e.g. the case on a Model M), keep it out of direct sunlight. Any kind of box would be fine.
Offline FrostyToast
  • Litshoard
« Reply #18 on: Fri, 13 May 2016, 19:53:45 »
Good luck finding intact boxes for vintage boards.
And custom keyboards don't have boxes either.
Those are the only two kinds of keyboards I collect.
Offline khirin
  • Do more, with less.
« Reply #19 on: Fri, 13 May 2016, 20:03:03 »
I used to put keyboards in a large & sturdy cardbord box, kept them dry and out of light. Years later, I discovered that the box was severely damaged by termite infesations!
