Author Topic: Do they make Soarer's Converter for xt to ps/2?  (Read 6029 times)
Offline supamesican
« on: Fri, 13 May 2016, 06:22:02 »
Got a model F xt last night and need one. This one(http://www.ebay.com/itm/NEW-XT-AT-to-USB-Soarers-Converter-Remapping-Macros-NKRO-Support-IBM-Model-F-/281476427201) is for xt to usb and would work but I perfer ps2 if possible.
thanks
Re: Do they make Soarer's Converter for xt to ps/2?
« Reply #1 on: Fri, 13 May 2016, 08:00:50 »
probably not possible unless you plugged a USB-to-PS/2 (male) adapter at the other end
- D Trump 2026-10-24
Offline Tactile
« Reply #2 on: Fri, 13 May 2016, 08:43:48 »
I have one of those converters & it works very well, even preserving N-key rollover over USB. I've never tried adapting it to a PS/2 port, although my motherboard has them. There is just no advantage that I can see in connecting this converter to PS/2 instead of the USB port it's designed for.
REΛLFORCE
Offline supamesican
« Reply #3 on: Fri, 13 May 2016, 18:24:49 »
Okay, I'll try just this and if I feel like I need the direct hardware access I'll just get a usb to ps2 thing
Offline acid2000
« Reply #4 on: Wed, 18 May 2016, 11:43:03 »
I've tried putting a USB to PS/2 adapter on one. It didn't work. Your mileage may vary.
Offline supamesican
« Reply #5 on: Wed, 18 May 2016, 12:08:57 »
It may need an active converter instead of passive then, but I did hear about a way to soldier my own ps2 on to the xt so eh I may do that when I get a spare, for now usb will work.
Offline y11971alex
  • Looking for Toronto meetup
« Reply #6 on: Wed, 18 May 2016, 13:13:47 »
I think Soarer's converter converts the key encoding; the PS/2 and USB differ only in the shape of the connector, not the electrical signals involved.  In any event:
https://www.hagstromelectronics.com/products/ke18xtat.html
« Reply #7 on: Wed, 18 May 2016, 17:18:36 »
Those small purple ones are for keyboards that are able to talk USB or PS/2 but has only one cable.
Offline acid2000
« Reply #8 on: Wed, 18 May 2016, 17:28:07 »
Actually I think the problem is that Soarers converter is a USB serial device and a USB HID device. Simple adapters can't tell the difference, you'll need something with more active logic.
If this is the case it might work with the TMK firmware as that IIRC only comes up as a single generic HID device.
« Last Edit: Wed, 18 May 2016, 17:31:07 by acid2000 »
Offline acid2000
« Reply #9 on: Wed, 18 May 2016, 17:30:46 »
Nope, Soarers converter does a lot more. PS/2 and USB are very different. You might be getting confused with AT DIN adapters and PS/2 a those are compatible.
« Reply #10 on: Wed, 18 May 2016, 17:34:57 »
Putting an AT-to-PS/2 adapter on the XT cable would fit mechanically but would not actually work.
Offline y11971alex
« Reply #11 on: Wed, 18 May 2016, 17:36:56 »
The OP asked for an XT -> PS/2 solution.  Disregard my comments on USB compatibility if it's inaccurate.
