Author Topic: New Keyboard Build  (Read 1358 times)
Offline cpeterson19
New Keyboard Build
« on: Fri, 13 May 2016, 10:32:39 »
Hello,
This may sound really dumb and i apologize, but here i go! I am looking to build my first keyboard but do not know where to start. Is there any good list or anything that i can go off of so i know at least what to buy.
Any help would be great!!!
Thanks,
Offline chuckdee
Re: New Keyboard Build
« Reply #1 on: Fri, 13 May 2016, 11:40:44 »
I've had the same question, and a lack of luck in finding anything consolidated.  What I've been doing is:
(a) doing research on relevant communities
(b) reading build logs
(c) watching others efforts
(d) taking it slow, and starting small, and breaking it down into digestible pieces
I might try to gather that together once I get more proficient.  But I don't feel qualified to at the current point.
« Reply #2 on: Fri, 13 May 2016, 11:54:17 »
@rowdy these guys need your search skills, I know there are at least a half dozen threads like this
@chuckdee has the right idea
Also help us help you and give us more information.
Offline cpeterson19
« Reply #3 on: Fri, 13 May 2016, 15:50:51 »
Ok well I'm looking to build a 60% board using veailo purples 65g and I would like led glow from the bottom and sides ummmmm. Hope that helps ha
