Author Topic: IBM 5150 w/ 5170 keyboard  (Read 5136 times)
Offline y11971alex
  • Looking for Toronto meetup
« on: Fri, 13 May 2016, 16:20:11 »
http://www.ebay.ca/itm/Vintage-IBM-5150-Personal-Computer-and-Color-Monitor-/201579425190?hash=item2eef11eda6:g:OHsAAOSwbwlXATdw
This is an interesting deal... the computer is a 5150 (PC), but the keyboard appears to be part of a 5170 (AT).
If someone buys this computer, wouldn't that result in a non-functioning keyboard?  Or did converters exist back in the early '80s?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: IBM 5150 w/ 5170 keyboard
« Reply #1 on: Fri, 13 May 2016, 18:13:26 »
At best, you'd be sending wrong scancodes along. At worst, one wouldn't understand the other.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Fri, 13 May 2016, 20:30:09 »
A 5150 will not understand the AT keyboard.
« Reply #3 on: Sun, 15 May 2016, 22:08:20 »
An IBM PC (5150) or XT (5160) Will understand most model Ms. Little known fact.
Same goes for the AT model F. Thanks to John Elliot: http://www.seasip.info/VintagePC/ibmat_kbc.html
model M info from the vintage computer forum.
Updaet: seems the AT keyboard will work on a 5150 - 5160 http://www.vcfed.org/forum/showthread.php?42091-IBM-AT-Keyboard-or-Model-F
« Reply #4 on: Mon, 16 May 2016, 06:25:25 »
KBXT is for attaching an XT keyboard to a 5170.   Not an AT to a 5150.
If you're talking about the converter mentioned in that thread, well, suppose it's not too surprising they exist.
