Author Topic: Coral Reef Key Cap  (Read 3682 times)
Offline mkeeley
Coral Reef Key Cap
« on: Sun, 15 May 2016, 05:33:56 »
My first play with polyclay. Someone said they liked the marine & pond scenes people do with polyclay in Altoids tins so thought I'd see if I could shrink that down to keycap size for them.
It's not fully pushed on in the pics as the clears on the Pok3r are a pretty snug fit and didn't want to risk damaging it when it's removed, it's also on a little wonky because of that. All the way down it's not much taller than standard escape key. It looks a bit delicate but is actually pretty solid. As you can imagine the parts are pretty tiny, lots of swearing as I tried to get the hang of things. The clownfish isn't painted it's layers of clay.
I used a Pok3r alpha key that I sanded down to give more work room. I sanded the top flat and made the sides thinner. Did test a spare ABS key but, as expected, it went a bit gooey. The Pok3r caps are the only PBT's I have but as they've been swapped out it's no loss (plus they're not the best quality anyway).
If they like it I was thinking of a version encased in clear resin, means there could be more variation in height and also allow for more fine detail that wouldn't be squished. But not for a while, have to do some more practicing first.
Anyway, I'm fairly happy with how it turned out and learnt a bunch of things along the way (like start with something larger!).
« Last Edit: Sun, 15 May 2016, 05:41:31 by mkeeley »
Marc
Re: Coral Reef Key Cap
« Reply #1 on: Sun, 15 May 2016, 08:54:36 »
That is some seriously impressive sculpting!
As the clownfish is singled out as not printed does that mean everything else is?  Amazing painting skills too if so :eek:
Offline juahenza
  • DoSmallThingswithGreatLove
« Reply #2 on: Sun, 15 May 2016, 09:03:32 »
very welldone.  :thumb:
456GT | TGR Jane CE | Dolphin v2 | Whale | 360c | LZ FE | LZ IRON | TX-CP | Varmilo VA87M | HHKB P2 | IBM SSK P.1397681| IBM Industrial SSK P.1395682 | VE.A | Realforce 87u | Datamancer Streamline TKL | Datamancer Mechinist TKL | TANK v1 | RAMA M-4 | Realforce 108UW-HIPRO
Offline Waateva
« Reply #3 on: Sun, 15 May 2016, 09:34:51 »
Wow, amazing work!
Offline mkeeley
« Reply #4 on: Sun, 15 May 2016, 10:57:47 »
Thanks. No nothing was painted it's just that I've seen most people paint the stripes on the clownfish I decided to layer the clay instead. Would have liked to add more fine details but would have been too fragile, next time though.
Marc
Offline Leslieann
« Reply #5 on: Sun, 15 May 2016, 17:15:40 »
Fantastic work, I want one!
Encased to look like water would be an awesome way to finish and protect it.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #6 on: Sun, 15 May 2016, 17:19:28 »
Way cool! Amazing sculpting :)
Offline Natatat
« Reply #7 on: Sun, 22 May 2016, 04:01:29 »
Awwww love the detail ! Great job!
Offline mkeeley
« Reply #8 on: Sun, 22 May 2016, 07:32:42 »
Thanks, was a good experience. Am doing some more playing and sort of thinking about the best way to encapsulate it in resin to allow proper layering.
Marc
