Author Topic: HELP! Ducky Shine 3 stopped working  (Read 5416 times)
Offline ZippY_S
« on: Sun, 15 May 2016, 09:05:55 »
Good afternoon, I had a problem with the keyboard Ducky Shine 3, I examine her, took the body, disabled PCB of the controller, cleaned the keyboard and plugged back in, but it has ceased to work, the keyboard is the power, but it is not lit and is not determined by the PC. I live in Russia, I bought it on this site: http: //****en.pro/, it ended guarantee  and so I decided to disassemble and clean it. What do i do? = ((
Re: HELP! Ducky Shine 3 stopped working
« Reply #1 on: Sun, 15 May 2016, 09:42:06 »
Check the wires where the cable connects to the PCB - they are thin and not made to move, so break easily.
What did you use to clean it?
Offline ZippY_S
« Reply #2 on: Sun, 15 May 2016, 09:59:37 »
compressed air
Offline HeeCh2ei
  • qdrw
« Reply #3 on: Sun, 15 May 2016, 11:05:03 »
Do you already tried to disassemble the board and check everything: connectors, pcbs, ribbon cables, etc?
Is it possible that a controller can be damaged by static electricity while being disassembled?
Cherry is the Maker, Topre is the God
FC660C             FC750R (reds)     FC750R (blues)
« Reply #4 on: Sun, 22 May 2016, 04:56:31 »
Have you tried resetting the board?  How down both Win keys for at least 3 seconds (while it is plugged in).  The LEDs should flash a couple of times while it is resetting.
Or you could try updating the firmware.
Offline ZippY_S
« Reply #5 on: Tue, 24 May 2016, 05:36:17 »
Yes i tried ,my pc dont see keyboard (sorry for my english)
Offline itzmeluigi
  • ПБТ
« Reply #6 on: Tue, 24 May 2016, 05:57:10 »
What was wrong with the Shine 3 before you took it apart?  When you put it back together did you make sure the black wires were on the top position and the red wire on the bottom?  If the connector was connected the wrong way then the board might be fried since a lot of people have fried the Shine 3 by connecting it the wrong way when putting it back together.
« Reply #7 on: Tue, 24 May 2016, 05:58:14 »
Your English is fine - 100% better than my Russian!
Can you try the keyboard on a different computer?
Can you try a different USB cable?
Even a different USB port on your computer?
Offline ZippY_S
« Reply #8 on: Tue, 24 May 2016, 06:07:11 »
Can you try the keyboard on a different computer?-
Can you try a different USB cable? +
Even a different USB port on your computer? +
 Bios dont see
« Reply #9 on: Wed, 25 May 2016, 06:13:25 »
I have run out of ideas.
Perhaps the controller on the PCB has been zapped :(
