Author Topic: Sculpting  (Read 2164 times)
Offline izilla
Sculpting
« on: Mon, 16 May 2016, 23:16:59 »
So I am out on work this week and had nothing to do this evening so I broke down and stopped by the crafts store to give a go at sculpting what some day maybe my own keycaps.
Check out day 1:
All the tools I had were a pen and a thing for removing blackheads I found at Marshalls. I used Sculpey III and Premo! Sculpey the pictures are of the Premo! because the III was too soft for me and kept messing up my work.
« Last Edit: Mon, 16 May 2016, 23:20:41 by izilla »
Offline Bambino
  • Suited Up Keycaps
Re: Sculpting
« Reply #1 on: Mon, 16 May 2016, 23:24:51 »
Cool snail/hermit crab stuff going on there!  Be sure you test your finished sculpture on your keyboard to ensure clearance with other nearby keys.
Offline izilla
Re: Sculpting
« Reply #2 on: Tue, 17 May 2016, 07:52:55 »
Oh yea they are way too big at the moment to fit.....but I just wanted to try sculpting.
Re: Sculpting
« Reply #3 on: Tue, 17 May 2016, 10:45:40 »
FYI, the plasticizer in Sculpy will melt ABS.
Offline izilla
Re: Sculpting
« Reply #4 on: Tue, 17 May 2016, 14:01:28 »
Uh-oh probably shouldn't have used my daily caps  :eek:
