Author Topic: Solder Flux Removal Question  (Read 1580 times)
Offline UnFocused
« on: Tue, 17 May 2016, 22:52:09 »
I just replaced all of the MX brown switches in a QFR with vintage MX blacks and everything is working as it should.
I'm a somewhat new to soldering and I used a bit of flux on several switches from a Kester "Soldering Flux #186 RMA FLUX PEN". I tried cleaning the flux from the PCB with 91% isopropyl and a not so stiff anti-static brush, but now there's a sticky residue all over the PCB. I don't think the alcohol was dissolving the bristles of the brush because they look normal.
Wikipedia tells me that "RMA flux is formulated to result in a residue which is not significantly corrosive, with cleaning being preferred but optional."
So, while I don't think I NEED to clean it, should I? Will leaving the sticky residue on the PCB cause problems down the road?
Exactly what product should I use if I do clean it?
Also, these vintage MX blacks (from a Wyse board with what looks to be a 1989 date code) are wonderful!
Offline jcoffin1981
Re: Solder Flux Removal Question
« Reply #1 on: Wed, 18 May 2016, 01:57:35 »
I see many circuit boards with the residual flux still left on.  It's non conductive and non corrosive.  A thick solder paste I would probably try to clean the excess.  I am not the authority on soldering, I'm simply telling you what I have seen and in my opinion it's not a problem.
If it's liquid flux from a pen you could simply dab it with lens paper or a tissue and soak up most of the remaining flux.
