Author Topic: [IC] MIAMI DOLCH - DSA [DROPS MAY 1ST]  (Read 165363 times)
Offline B1G_B1RD
Re: [IC] MIAMI DOLCH - DSA Keyset UPDATE 04.12.2017 DROPPING IN MAY!!!!!!!
« Reply #350 on: Thu, 13 April 2017, 09:12:04 »
I'm ready for this one. I already have more caps than I need but this is a good excuse to add another to the lineup!
Offline joelfong
« Reply #351 on: Wed, 19 April 2017, 19:51:40 »
Definitely up for this! I love the colours and really like how much thought into compatibility you've put in.
Offline Dexmas
« Reply #352 on: Fri, 21 April 2017, 08:27:10 »
Wow, this set is going to absolutely kill my wallet haha. I am ready.
    POK3R
Offline atomicus
« Reply #353 on: Fri, 21 April 2017, 17:29:13 »
Wish this colourway came in Cherry profile.
Offline jihadu
« Reply #354 on: Sat, 22 April 2017, 13:51:41 »
We all have our favorite profiles! If this is popular enough we might see a GMK Miami Dolch!
Mine is Cherry as well !
Offline joelfong
« Reply #355 on: Sat, 22 April 2017, 16:49:15 »
I would really love it if there were a 6u spacebar though.. Any chance of adding it or are the kits already finalised?
Offline poolside
« Reply #356 on: Sat, 22 April 2017, 16:52:48 »
I am afraid GMK Miami Dolch might already have happened. It's called:
- Sky Dolch v2 with magenta mods (base: https://geekhack.org/index.php?topic=84769.msg2300823#msg2300823, mods: https://geekhack.org/index.php?topic=84769.msg2308401#msg2308401)
- or Dolch Reborn (https://geekhack.org/index.php?topic=85147.0)
Offline jihadu
« Reply #357 on: Sat, 22 April 2017, 18:26:35 »
Thx for the info
Offline MacGruber117
Re: [IC] MIAMI DOLCH - DSA UPDATE 04.25.2017 NEW RENDER!!! (and color update)
« Reply #358 on: Tue, 25 April 2017, 06:39:13 »
Update Bump!
We have a new render from /u/thesiscamper and a slight color change. Read the update summary on the front page of this thread for more info. Please post any comments or questions, thanks ;D
I want to buy your ETF and Garbo Pusses. PM me
Re: [IC] MIAMI DOLCH - DSA [DROPS MAY 1ST]
« Reply #359 on: Sat, 29 April 2017, 09:01:45 »
Offline joelfong
« Reply #360 on: Sat, 29 April 2017, 17:11:31 »
Overall, love the keyset. Nice work. Looking forward to the drop.
Just wondering, is it possible to add 2 x 1u Accent Colored Esc Keys to the 40% Ortho kit? It would balance out the coloured Enter key nicely as seen in the original Zambumon renders.
Cause right now the only way to have a decent looking planck layout is to either not use the colored enter key at all, or buy an entire accent kit just for a single colored escape key, which doesn't really make much sense. :/
Offline sklin
« Reply #361 on: Sat, 29 April 2017, 23:50:31 »
ahha, to cover a hhkb layout, I have to buy the UK kit for a single \|, and tsangan kit for a single 1.75 control...
« Reply #362 on: Sun, 30 April 2017, 08:38:38 »
The tsangan kit also has all of the 1.5u mods for the HHKB bottom row. I'll see what I can do about the \| key
Offline erekwednar
« Reply #363 on: Sun, 30 April 2017, 08:57:47 »
Is the 6.5u spacebar kit going to show up in the drop? I'll still be getting this to kit out a future ergodox, but I'd really like to replace the stock bar on my TK, as it's my first and only board ATM.
Offline sklin
« Reply #364 on: Sun, 30 April 2017, 09:00:27 »
Wow thanks, it would be great if it's in the base kit! :thumb: :thumb:
« Reply #365 on: Sun, 30 April 2017, 12:57:32 »
I threw it in the Tsangan Kit and the Planck Kit. Check the kits at the top of the thread, the most up to date ones are here on GH
Offline sklin
« Reply #366 on: Sun, 30 April 2017, 13:21:15 »
oh..really hope it's in the base kit, then I can just replace 1.75 ctrl with 1.75 func, and avoid buying an exta Tsangan kit. 60% mod+Whitefox kit+novelty can fit all perfectly well.
But anyway, I'm in for 8 or 9 kits. Wish the GB be a great success  :thumb:
« Reply #367 on: Sun, 30 April 2017, 13:24:54 »
Yes you can buy a the 6.5u spacebar kit which includes a gray, pink and cyan 6.5u spacebar
Offline erekwednar
« Reply #368 on: Sun, 30 April 2017, 13:58:25 »
Thank you for clarifying, just got a bit panicky when the text didn't reflect that, even with the same image as this thread.
Offline joelfong
« Reply #369 on: Sun, 30 April 2017, 16:34:04 »
Thanks for responding to community feedback and requests! I'll definitely be supporting this when the drop goes live!
Offline joelfong
« Reply #370 on: Sun, 30 April 2017, 16:45:22 »
Oh I just took a closer look and there seems to be a missing dark ' " key that's not in any kit that I see, but is depicted in the Planck layout/render. I personally won't use that key but you might want to either add that key in or modify the renders/layout.
Offline vafan
« Reply #371 on: Sun, 30 April 2017, 23:53:10 »
All in
Sent from my SM-J710F using Tapatalk
Offline E.E.L. Ambiense
  • Acrylic Heretic
« Reply #372 on: Mon, 01 May 2017, 08:42:16 »
Jumped in too.  DSA fan.  I recently jumped in on the Lightcycle full-set GB, but I need to fill out a 75% board anyway so this will look lovely on there.  I hope they add the bonus kits and any of the other misc. stuff soon!
Good job on the set,  MacGruber117, and good luck on the drop!  Here's to unlocking all the breaks.   :thumb:
Case modder by trade; mech-deck'r for fun!
Offline xondat
  • i'm not a star
« Reply #373 on: Mon, 01 May 2017, 08:51:55 »
It's a shame this launched with such oddly split kits. For example, you need "Base Alphas", "60% Modifiers Kit", "WhiteFox, 65%, 75% Modifiers Kit" and "Tsangan Colemak Kit" just to cover a HHKB.
For a WKL layout (with the 1u winkey) you need the same as above.
There are so many duplicate keys that just haven't been considered. For HHKB you end up with 3/4 duplicates.
"WhiteFox, 65%, 75% Modifiers Kit" is generally a super weird kit. It's got 1800 keys, some novelties, a Clueboard shift, and a couple HHKB keys.
"Tsangan Colemak Kit" is also flawed. It has 1 key regarding Colemak, but you need to combine it with "WhiteFox, 65%, 75% Modifiers Kit" to actually make it useful on 90%+ boards. It also has elements of 40%, when there is a Ortholinear kit below?
Kits are supposed to make it so you don't have to buy unnecessary kits, but you end up buying lots as the compatibility is so spread out. I'm guessing its too far in to change anything, so good luck, but it's really a shame that it wasn't done properly.
Offline handcraftedbits
« Reply #374 on: Mon, 01 May 2017, 09:07:49 »
To be fair, I doubt this kit was designed with the HHKB in mind, seeing as how you have to mod it to take MX keycaps.
Offline Vigrith
« Reply #375 on: Mon, 01 May 2017, 09:32:19 »
There are MX HHKBs - Viper, etc. Either way, I personally have not ran into any issues with the kits, probably because I bought everything other than ergodox and tsangan but still I think for most boards it seems to be mostly on point.
Offline testplsignore
  • I am one with the Cup Rubber...
« Reply #376 on: Mon, 01 May 2017, 09:59:03 »
The only thing that seems to be missing is the option to have an all dark f-row.
IMO this is essential for layouts like a 75%, or the 96 key layout where the f-row lines up next to the number keys.
Having the two tone looks weird in those types of layouts...
Realforce 10AE 45g Type-S & 55g    HHKB BT & Type-S    Realforce RGB Hype-S    FC980C    FC660C    Filco BT TKL
Offline Moderation Team
« Reply #377 on: Mon, 01 May 2017, 10:17:24 »
Now that the interest check phase has completed and the group buy has been launched on Massdrop, please discuss the GB progress on Massdrop directly or on the MassDrop section of this site.
