Author Topic: Any browns that are all brown, no heavy grey/green spacebars etc.?  (Read 2433 times)
Offline NewbieOneKenobi
As per title. I love the brown switch but can't stand heavy spacebars and prefer uniform actuation force all across the board.
Are there any confirmed brown keyboards that are absolutely, positively browns only?
(Also any identified reds-only would be valuable information.)
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Any browns that are all brown, no heavy grey/green spacebars etc.?
« Reply #1 on: Wed, 25 May 2016, 07:14:07 »
Why not just solder in a brown switch?
« Reply #2 on: Wed, 25 May 2016, 07:39:02 »
Are there that many that aren't uniform?
The only boards I've seen that have a heavier spacebar are typically older cherry boards and they are also PCB mounted so easy to change that stem out.
Offline HeeCh2ei
  • qdrw
« Reply #3 on: Wed, 25 May 2016, 07:39:27 »
I thought that uniform switches is a standard on the current market boards and that heavy spacebar thing takes place in an ancient boards and weird cherry-made stuff, mostly.
All of my keyboards are not have a heavy spacebar.
« Last Edit: Wed, 25 May 2016, 08:07:03 by HeeCh2ei »
Cherry is the Maker, Topre is the God
FC660C             FC750R (reds)     FC750R (blues)
« Reply #4 on: Wed, 25 May 2016, 07:59:18 »
Thanks, guys. Yeah, I've only ever had or pawed an old Cherry-made brown and zero experience with modern browns. Good to hear modern ones don't have the problem.
No tools and zero experience. Hard to find someone else to do it either.
How easy?
« Last Edit: Wed, 25 May 2016, 08:01:48 by NewbieOneKenobi »
« Reply #5 on: Wed, 25 May 2016, 08:02:49 »
If PCB mounted you can use tweezers, a small screwdriver or switch opening tools to remove the switch top.
« Reply #6 on: Wed, 25 May 2016, 08:53:02 »
Yeah, I've done that before on my vintage G80. Broke the metal plaque inside. ;) Now I need to transplant the switch from Scroll Lock or somewhere. Just can't solder.
« Reply #7 on: Wed, 25 May 2016, 08:55:50 »
You broke the leaf spring?
