Author Topic: Whats The Best Keyboard Around $200?  (Read 3957 times)
Offline Brannan
« on: Wed, 25 May 2016, 15:42:50 »
I Im just looking for a new keyboard under and around $200 bucks. IF the keybaord is under $200 By 40 bucks then I will by keycaps as well.
Anu suggestions on a keyboard?
My current  keybaord is a pok3r with cherry mx clears and blank beige keycaps.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Whats The Best Keyboard Around $200?
« Reply #1 on: Wed, 25 May 2016, 16:26:20 »
If you wanted to stick to the same 60% size you could try a HHKB Pro 2. No need to buy an extra set of keycaps, although it does open up a world of Topre artisan choices.. I'm recommending a HHKP because you're not giving us much info to work with.
Are you going to use the keyboard for gaming? Do you want a keyboard with more keys (tkl, full-sized, etc.)? Would you want to try Cherry MX type switches like Greetech, Kailh, or Gateron?
« Reply #2 on: Wed, 25 May 2016, 16:27:32 »
HHKB. I don't own one, but I've tried it and easily worth the money.
Offline Bucake
« Reply #3 on: Wed, 25 May 2016, 16:34:25 »
don't listen to these chumps.
get a 55g RF.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4 on: Wed, 25 May 2016, 16:38:54 »
get a 55g RF.
Ok cupcake, no need to be crass ;)
But seriously, RF 87U is also a good option. It might be more expensive than a HHKB, but it would be different from your Pok3r so there's the plus side
« Reply #5 on: Wed, 25 May 2016, 16:48:29 »
get a 55g RF.
Oh, yeah. That too. Typing on one now.  :))
Offline appleonama
  • Trollo en USA
« Reply #6 on: Wed, 25 May 2016, 16:48:53 »
get a 55g RF.
Offline Bucake
« Reply #7 on: Wed, 25 May 2016, 16:49:56 »
cupcake
so demeaning :'(
in all seriousness @Brannan, it probably helps to mention what your 'demands' are, and what you'll be using the keyboard for.
as much i enjoy the RF, i don't use it for gaming. for gaming i usually use cherry mx reds or 45g topre (hhkb), not only because of the switches but because 60% is a must for me when i play games.
Offline NewbieOneKenobi
« Reply #8 on: Wed, 25 May 2016, 17:30:46 »
I'm not qualified to comment on either Matias or ergo, but you may want to take a look at this. It's 70%-kinda quiet clicky ergo board that can be split in half, with a column of extra keys that are actually useful (in editing), and a wrist rest.
« Last Edit: Wed, 25 May 2016, 17:33:51 by NewbieOneKenobi »
Offline fknraiden
« Reply #9 on: Wed, 25 May 2016, 17:34:59 »
i second the realforce 55g
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #10 on: Wed, 25 May 2016, 18:04:35 »
Man, that keyboard has a bottom row for giant thumbs :eek:
Offline carmenohio
« Reply #11 on: Wed, 25 May 2016, 21:04:16 »
Realforce 87U with uniform 55g domes if you want a TKL, or HHKB Pro 2 if you want a 60%
Offline alienman82
« Reply #12 on: Wed, 25 May 2016, 21:46:23 »
removed.
« Last Edit: Thu, 01 March 2018, 15:08:23 by alienman82 »
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #13 on: Wed, 25 May 2016, 21:51:32 »
hhkb
