Author Topic: List which switches you have tried and your rating 1-10 of the switch?  (Read 60583 times)
Offline appaboy
Re: List which switches you have tried and your rating 1-10 of the switch?
« Reply #150 on: Fri, 17 May 2019, 12:31:02 »
MacBook keys 1/10
Kailh red 2/10
Kailh box black 2/10
Ergoclears 9/10
Retooled blacks 9/10
Vintage blacks 10/10
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
Offline mlev6
« Reply #151 on: Wed, 07 August 2019, 09:22:02 »
Has anyone tried the Varmilo EC switches and can give a reference comparison vs other switches out there. I heard they where pretty good being ec capacitative but that the 55g Rose and the tactile? heavier Ivy stand out. Thanks!
And another question and seeking advice: what switches should I try as I am considering making a second custom? I am using ergo clears at work right (keyboard came with nos clears that I lubed/ replaced spring) now and got them to a place I like the weighting and tactility but sometimes I miss a nice sharp click about a 1/4th or 1/5th  of the way down after a switch is pressed.  Is there a switch with such a click but afterwards still with heavier/ smooth tactility on the way down that does not bottom out. For practical purposes would want to stick with MX stems, but some customization is an option. Much appreciated.
