Author Topic: [Oddforge] VE.A  (Read 332283 times)
Offline JDragon
Re: [Oddforge] VE.A
« Reply #850 on: Thu, 01 June 2017, 15:50:46 »
Does anyone know where to get the default firmware for the VE.A? I think mine needs a reflash.
Offline dubious
  • 쏘쿨
Re: [Oddforge] VE.A
« Reply #851 on: Thu, 01 June 2017, 16:29:57 »
Firmware
and bootmapper client if you need it
Offline JDragon
Re: [Oddforge] VE.A
« Reply #852 on: Thu, 01 June 2017, 18:02:03 »
Firmware
Thank you!
Turns out my PCB is damaged. :(
Offline alienman82
Re: [Oddforge] VE.A
« Reply #853 on: Thu, 01 June 2017, 18:44:13 »
removed.
« Last Edit: Thu, 01 March 2018, 12:43:16 by alienman82 »
Offline litster
  • rare caps?! THAT'S A SMILIN
Re: [Oddforge] VE.A
« Reply #854 on: Mon, 03 July 2017, 23:25:15 »
In case you missed it, MassDrop has this keycap set going, the spacebar kit may work well with VE.A.
https://www.massdrop.com/buy/massdrop-x-zambumon-gmk-nautilus-custom-keycap-set
Offline clappingcactus
Re: [Oddforge] VE.A
« Reply #855 on: Sun, 30 July 2017, 07:37:11 »
Hey zefyr and ildustry. Any news on your upcoming work? :)
Offline redbanshee
  • actually Dade Murphy
Re: [Oddforge] VE.A
« Reply #856 on: Fri, 04 August 2017, 12:27:06 »
build album: http://imgur.com/a/lR64b
one of my favorites! love this board! :thumb:
Offline MajorKoos
  • 1 life please. Extra large.
Re: [Oddforge] VE.A
« Reply #857 on: Fri, 04 August 2017, 13:31:23 »
Looks awesome.
Lubed MOD switches rock as well - super tactile.
Offline ipreferpie
Re: [Oddforge] VE.A
« Reply #858 on: Sat, 05 August 2017, 11:19:41 »
Does anyone here have experience using Swill's plate building tool? I'm having a really tough time modifying the ALPS file for the VE.A. Essentially, I'd like to: 1) split the backspace key into 2 1u keys, 2) swap the left and right split space bars and 3) change the stabilizer cutouts from ALPS to Cherry and Costar MX. Has anyone made a similar file for themselves?
Offline KetchyKech
Re: [Oddforge] VE.A
« Reply #859 on: Thu, 24 August 2017, 09:18:57 »
x-post --- finally got her built --- Salmon ALPS, plate from lasergist using .cad file, ALPS DSA Lightcycle!
Offline dubious
  • 쏘쿨
Re: [Oddforge] VE.A
« Reply #860 on: Thu, 24 August 2017, 12:55:45 »
Offline nathanchere
Re: [Oddforge] VE.A
« Reply #861 on: Tue, 24 October 2017, 04:06:25 »
It's going to be a while if and when we see anything.
Do you know this definitively? or are you just speculating?
Thank you! I saw this one but I thought the price was a bit high...but I guess that seems to be the only good baseline. 750 is enough to build a decent PC lol.
I spent $700 on mine, which is actually more than I was trying to put a PC together for =P
Considering the time it was simply between the korean VeA GB and the Massdrop one, the time the IC was on here etc.  It'll be a whole while.
The exception would be a R2, but he's denied it over and over
and over again  :blank:
The thing is... we actually got several(hmm... yeh, tens)  requests about stock or next round.
We released about 200 VE.As to geeky-mates all over the world. AND really proud of it :)
We don't care about rarity. But it's a bit old now. For a year and a half, we stuck in one model.
And VE.A is not suitable for production, SATA connector needs to be cut by BARE hands. and it's bugging me. and of course, was hard to handle.
So...
It's like chain-reaction kind of thing.
We want it to be fixed. Yeh.
That means, we need to fix cases also.
If we have to fix case, why not design a new one?
Thoughts reached here so far, still not ended. like cost, tilting, material, diffusing and so on.
And most of all, I am such a lazy bastard.
We are hoping you don't lose interests on us before we come back.
Hey, what a nice day to swim in thick smog! Damn. I got bad throat ouch.
I hope that designing is coming along well because I would give my left nut for one of these.
Offline MandrewDavis
  • Chasin' That Neon Rainbow
Re: [Oddforge] VE.A
« Reply #862 on: Mon, 30 October 2017, 15:19:36 »
It only took a year or so, but I finished rebuilding my VE.A with the proper switches it deserves!
This is my first time trying SA since besides my Dolch Pac, it's my only MX keyboard. I didn't think I would really care for the profile but it has really grown on me!
Specs:
•Holtites installed for switches only
•Krytox lubed and stickered PCB mount vintage blacks from a busted up eBay NCR G80-0427. None of the mold numberings exceed 20.
•Gateron blacks on the macros, vintage grey for the spacebar.
•Springs swapped with Victorinox lubed SPRiT 63.5g 24k gold springs.
•GMK screw-in stabs with WYSE (pre-clipped) plate mounted inserts. Gold plated screws and wires.
•Black 3M Vinyl applied where the white pcb is exposed and as landing pads for stabilizers.
•Spacebars sourced from a 1976 grab-bag in order to match the Chocolatier alphas.
•SIP sockets paired with the color change lock LEDs
•Wenge wrist rests from Alienman's groupbuy.
« Last Edit: Mon, 30 October 2017, 15:22:59 by MandrewDavis »
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline theillumedpanda
  • Don't point that gun at me - I'm an unpaid intern!
Re: [Oddforge] VE.A
« Reply #863 on: Mon, 30 October 2017, 15:33:26 »
That‘s a beautiful board! Thanks for sharing
Re: [Oddforge] VE.A
« Reply #864 on: Mon, 30 October 2017, 17:09:59 »
Yeah, that's a whole lot of good taste presented in two pictures and one list!
Offline MajorKoos
Re: [Oddforge] VE.A
« Reply #865 on: Fri, 03 November 2017, 12:30:12 »
A Stock, B Stock and DIY
« Last Edit: Sun, 05 November 2017, 16:42:38 by MajorKoos »
Offline Tre3Cycl3S
Re: [Oddforge] VE.A
« Reply #866 on: Fri, 03 November 2017, 23:33:30 »
Would you mind pointing out where did you get those SATA cable (the one on your DIY and the left VE.A)? Considering getting one myself.
QFR           HHKB Pro-2     JD45         VE.A                    XMIT 61-Key       JD40 Mk.II                    Realforce 87U     M65-A                 Custom:Annie      NightFox      Pearl                  E6-V2 R2                          Norbaforce
MX Blue     45g Topre        MX Blue     R5 67g Zealios     50g Hall Effect     Modded Gateron Red     55g Topre           R5 78g Zealios     62g Ergo Grey     Hako True     R9 62g Zilent     Lubed Holy Trash Panda     OG Sony BKE Domes
Offline MajorKoos
Re: [Oddforge] VE.A
« Reply #867 on: Sat, 04 November 2017, 07:32:50 »
They're made by Silverstone - CP11B
http://www.silverstonetek.com/product.php?pid=445
I got mine from Newegg.
Offline Tre3Cycl3S
Re: [Oddforge] VE.A
« Reply #868 on: Mon, 06 November 2017, 21:16:33 »
Thank you good sir!
Offline ildustry
Re: [Oddforge] VE.A
« Reply #869 on: Mon, 20 November 2017, 00:11:58 »
Hello!!!!!!!!!!!!!!!!!!!!!!!
Long time no see.
We are preparing for the following versions of VE.A
We are trying to meet before 2017.
We finished the sample and I'm going to post some pictures later.
We hope you're looking forward to it.
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
Re: [Oddforge] VE.A
« Reply #870 on: Mon, 20 November 2017, 00:12:39 »
Long time no see.
Holy crap.
Offline FoC_Tow
  • Brokehlicious
Re: [Oddforge] VE.A
« Reply #871 on: Mon, 20 November 2017, 01:19:08 »
Long time no see.
O_O
Re: [Oddforge] VE.A
« Reply #872 on: Mon, 20 November 2017, 03:50:04 »
Long time no see.
Guess all my other keyboard plans are on hold. :))
Offline wodan
Re: [Oddforge] VE.A
« Reply #873 on: Mon, 20 November 2017, 04:52:09 »
Long time no see.
YES YES YES
Offline avid
Re: [Oddforge] VE.A
« Reply #874 on: Mon, 20 November 2017, 05:49:59 »
This is so cool. Cant wait to buy a split keyboard.
Will you run this GB on massdrop or geekhack?
« Last Edit: Mon, 20 November 2017, 06:05:45 by avid »
Offline alienman82
Re: [Oddforge] VE.A
« Reply #875 on: Mon, 20 November 2017, 10:05:17 »
removed.
« Last Edit: Thu, 01 March 2018, 00:21:55 by alienman82 »
Offline clasicks
  • Formerly KeyboardUser4
Re: [Oddforge] VE.A
« Reply #876 on: Mon, 20 November 2017, 10:06:22 »
hype
Offline mech0nly
Re: [Oddforge] VE.A
« Reply #877 on: Mon, 20 November 2017, 10:15:03 »
i'm ready.
356mini | 360C | G81-3000SAT | G81-3000SAU | G80-3000LPCXY-2 | G80-3485LWNUS-2
Diamond Polished Cherry Switches!
Offline schoolbus
Re: [Oddforge] VE.A
« Reply #878 on: Mon, 20 November 2017, 10:16:04 »
oh man, hype.
Offline DormantLemon
Re: [Oddforge] VE.A
« Reply #879 on: Mon, 20 November 2017, 10:27:18 »
My body and wallet have been long preparing for this day
Sent from my iPhone using Tapatalk Pro
VE.A Silver | GMK Hyperfuse Origins
TGR Alice Pink | GMK Laser
Re: [Oddforge] VE.A
« Reply #880 on: Mon, 20 November 2017, 10:28:38 »
I really hope that they‘ve removed the odd SATA connector and replaced it with something else.
Offline zacheadams
Re: [Oddforge] VE.A
« Reply #881 on: Mon, 20 November 2017, 10:35:03 »
x2
Offline toan
Re: [Oddforge] VE.A
« Reply #882 on: Mon, 20 November 2017, 10:36:54 »
Long time no see.
Yes, are we going to have an IC or go directly to GB? And is there a limit quantity for this or everyone can get one?
Offline mbsurfer
Re: [Oddforge] VE.A
« Reply #883 on: Mon, 20 November 2017, 10:40:26 »
x2
x3
Offline MajorKoos
Re: [Oddforge] VE.A
« Reply #884 on: Mon, 20 November 2017, 11:32:57 »
Long time no see.
Yes please!
I'll take 2.
Re: [Oddforge] VE.A
« Reply #885 on: Mon, 20 November 2017, 11:42:33 »
x2
x3
-1
I like that it's SATA
Offline HouseofSuffering
Re: [Oddforge] VE.A
« Reply #886 on: Mon, 20 November 2017, 11:50:25 »
x2
x3
-1
-2
I liked that/didn't mind that it was SATA as well. Especially considering ZeFyr has previously explained all the reasons why SATA was the chosen for the VE.A 1.
https://geekhack.org/index.php?topic=79183.msg2042517#msg2042517
« Last Edit: Mon, 20 November 2017, 12:02:13 by HouseofSuffering »
Offline mbsurfer
Re: [Oddforge] VE.A
« Reply #887 on: Mon, 20 November 2017, 12:15:37 »
x2
x3
-1
-2
USB-C meets all of those needs, unless I'm missing something
Offline kiwi99
  • that's a gnarly dookie
Re: [Oddforge] VE.A
« Reply #888 on: Mon, 20 November 2017, 12:27:28 »
usb-c is cheap, easy to source and easy to hand solder ?  :confused: . Don't get me wrong USB-C is great but for a product you want to be able to customize and DIY it's still not the greatest.
Re: [Oddforge] VE.A
« Reply #889 on: Mon, 20 November 2017, 12:34:09 »
Exactly. Not to mention ZeFyr's post was from Feb 2016...which means his decision in the favor of SATA was probably made in 2015. How common/cheap was USB C in 2015???
USB C is probably a more likely option now though.... it will be interesting to see what he chose now.
Offline hkf
  • your #1 fan
Re: [Oddforge] VE.A
« Reply #890 on: Mon, 20 November 2017, 16:42:33 »
My phone had usb-c in 2015 so yeah
Re: [Oddforge] VE.A
« Reply #891 on: Mon, 20 November 2017, 17:00:34 »
Fancy.  :cool:
Offline FoC_Tow
  • Brokehlicious
Re: [Oddforge] VE.A
« Reply #892 on: Mon, 20 November 2017, 17:48:04 »
I don’t mind either Sata or usb.
Never got over the regrets of only getting one VE.A first round, so definitely in for atleast two this time around =)
Offline OneNightFriend
Re: [Oddforge] VE.A
« Reply #893 on: Mon, 20 November 2017, 18:54:14 »
The only problem I had with sata is that it is hard to find custom color cables for. Looking forward to a new improved VE.A!
Offline FoC_Tow
  • Brokehlicious
Re: [Oddforge] VE.A
« Reply #894 on: Mon, 20 November 2017, 19:00:39 »
Sata Cables should be fairly easy to get custom cables for.
In addition too of the shelve sleeved cables, mdpcx sleeving is available for Sata cables, so if you say order a custom usb from Pexon you can always get matching sata.
Nothing against going usb-c, but I quite liked sata =)
Re: [Oddforge] VE.A
« Reply #895 on: Mon, 20 November 2017, 20:13:54 »
Mine came from Pexon. Just a shame there's not a US option for something like this when there are so many options for USB.
Offline schoolbus
Re: [Oddforge] VE.A
« Reply #896 on: Mon, 20 November 2017, 20:32:00 »
biggest thing IMO is trying to address the latency issues.
Offline mech0nly
Re: [Oddforge] VE.A
« Reply #897 on: Mon, 20 November 2017, 21:04:11 »
I got rid the latency issue by setting the debounce number to 1.
Initially it was 5, and yeah, i feel the latency.
Offline schoolbus
Re: [Oddforge] VE.A
« Reply #898 on: Mon, 20 November 2017, 21:12:51 »
Wow... thank you so much! Just fixed everything for me.
Offline Gatix
  • #!/bin/sh
  • console.log
Re: [Oddforge] VE.A
« Reply #899 on: Tue, 21 November 2017, 06:02:23 »
How do you set the debounce value? My VE.A has been sitting around because of this issue
