Author Topic: RAMA WAVE ANODIZED SPACE GREY CNC KEYCAP (SHIPPING)  (Read 121352 times)
Offline UTEster750
Re: RAMA WAVE ANODIZED SPACE GREY CNC KEYCAP (SHIPPING)
« Reply #200 on: Mon, 08 August 2016, 03:17:39 »
Was so happy today when I got home and found the package on my desk! Thanks a bunch Rama! :D
Woah!! You already got it! Awesome man :D  No worries at all bro :)
Not like it had to travel very far ;)
Offline nathanrosspowell
    • nathanrosspowell.com
Re: RAMA WAVE ANODIZED SPACE GREY CNC KEYCAP (ORDER THROUGH TO MANUFACTURER)
« Reply #201 on: Mon, 08 August 2016, 09:46:10 »
Looking good dude! Alps support?  :-*
Doesn't look like it at the moment. Those contacts are MX. Also Alps needs to be plate-mounted so you will need a plate as well
Sorry. It was a question, if Alps support could be added. I don't think a plate is needed for a 4 switch, personally.
I'm not sure, I always thought that Alps switches require a plate by default, since the design of the switch body does not include any locating features for alignment (unlike MX which has a central dimple and two locating pin. I suppose if you're really careful with alignment, you could do without a plate, but I certainly wouldn't recommend it. Especially since some Alps stems fit VERY snugly, you would risk pulling the switch off the PCB when you remove keycaps if you choose to go without a plate (the only thing holding the switch to the PCB would be two solder joints)
All good points. Pulling the keys can definitely be an issue, but with such a small board I'd probably just de-solder all the switches to avoid breaking them.
With something like Swills Plate Builder it should be easy to knock up a small batch of plates  :) I would be up to that challenge, I might even mod the PCB i have coming  :thumb:
Hmm actually yeah! I should replace that MX footprint with a MX/Cherry footprint.
I'll add it to the next revision for sure :)  :-*
Yeeeeeeeee!
Offline Waateva
« Reply #202 on: Wed, 10 August 2016, 08:01:22 »
Hoping for something to show up this week! :D
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #203 on: Wed, 10 August 2016, 08:28:09 »
haha yeah, I suppose you're right :)
I've also got word that Coz from cozcaps and Kruzada have received theirs too!
Yeeeeeeeee!
Yeeeee :D
Mateee!! Really hope so, please let me know when you get it! :D
Didn't notice my personal messages have been disabled for those thinking you have been blocked - to contact please reach out through Facebook messages or support email!
WEB: https://rama.works/
STORE: https://ramaworks.store/
INSTA: @ramaworks
FB: ramaworks
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #204 on: Wed, 10 August 2016, 21:58:56 »
Project Update for the M4 Mini Programmable Keypad.
The latest PCBs have arrived! Completely recreated from scratch, it's much neater now! :)
White:
Yellow:
Black:
And the back:
What the enclosure is looking like (so far):
INSTA: @ramaworks
FB: ramaworks
Offline boo
« Reply #205 on: Wed, 10 August 2016, 22:07:49 »
Anyone living in USA have gotten the package? I am patiently waiting still but it is so hard to be patient  :p
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #206 on: Wed, 10 August 2016, 22:45:45 »
I think you can expect to receive it next week - I sent the packages all at the same time, and people in other states of Australia have received it yesterday.
So yeah, ideally early next week! I know how you feel though, waiting sucks :( hopefully the surprise is worth it to you boo :D
INSTA: @ramaworks
FB: ramaworks
« Reply #207 on: Wed, 10 August 2016, 22:59:03 »
White:
Yellow:
Black:
And the back:
Very nice. Is that a plastic bottom to close the metal 1-piece?
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #208 on: Wed, 10 August 2016, 23:27:25 »
Cheers Nathan!
Yeah it's a yellow Nylon base, it could be swapped out with anything really. I think the material break for the base between the Aluminium and the Nylon will be a nice touch though.
Will see how it looks with the first prototype :D
INSTA: @ramaworks
FB: ramaworks
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #209 on: Thu, 11 August 2016, 01:30:22 »
Clean as always omg
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #210 on: Thu, 11 August 2016, 01:53:04 »
Clean as always omg
That's the aim! Thanks heaps mate <3
INSTA: @ramaworks
FB: ramaworks
Offline Data
« Reply #211 on: Thu, 11 August 2016, 11:45:17 »
New 4% renders... sweet baby Jesus.  Didn't know a 4-key keyboard could look so damn sexy.
Offline jal
  • I can't believe it's not gravy!
« Reply #212 on: Thu, 11 August 2016, 20:36:09 »
Beep.
145074-0
Sweet baby Moses in a sidecar, with a trumpet and gong, these are frickin' gorgeous.
Offline duynguyenle
  • Personal text? What personal text???
« Reply #213 on: Thu, 11 August 2016, 20:43:43 »
Cheers Nathan!
That's an excellent case design  :thumb:
Will the switches clip into the case (like an integrated plate) or do they just slot through freely? Is the bottom flush with the top? Are you going to run a GB for the case or open source the files for people to try and make their own? Will the case work the PCB you gave us in the keycap buy? (So many questions, but I need to know more about this magnificent slab of metal!  :)))
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #214 on: Thu, 11 August 2016, 21:05:07 »
Goals are to make it feel as good and look as sexy as possible ! Can't wait to have a prototype made :) Cheers!
Beep.
Ohhhh dude! Awesome!! Glad to see some US orders coming in! :D Really happy you like it too mate :)  Thanks for making me smile :P
Will the switches clip into the case (like an integrated plate) or do they just slot through freely? Is the bottom flush with the top? Are you going to run a GB for the case or open source the files for people to try and make their own? Will the case work the PCB you gave us in the keycap buy? (So many questions, but I need to know more about this magnificent slab of metal!  :)) )
Thanks bro!
The switches do not clip into the case, they slot freely - mounted to the PCB. The bottom sticks out a little bit, so the Aluminium will appear to be floating :D For style of course :p I have to get it all prototyped up, but I'm confident it will feel and look really good in person!
The PCB will fit into this yes! However, I'm not sure that the USB will line up the same, I will have to check. Regardless, through this groupbuy, the new PCB will be included anyways! PCB's are cheap! Also yes, I will release versions of the case that people can make on their own as a complete DIY project :)
« Last Edit: Thu, 11 August 2016, 21:23:47 by KingRama »
INSTA: @ramaworks
FB: ramaworks
Offline boo
« Reply #215 on: Fri, 12 August 2016, 03:01:00 »
Beep.
I'm also in CA and had my hopes up for some mail but didn't happen today.  :(
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #216 on: Sat, 13 August 2016, 03:21:32 »
Beep.
Oh damn dude :( no fair! Another guy on Instagram in LA got his too: https://www.instagram.com/p/BJCMtBsjunY/?taken-by=lokia007
Definitely will get it next week for sure mate :)
INSTA: @ramaworks
FB: ramaworks
Offline duynguyenle
« Reply #217 on: Sat, 13 August 2016, 05:30:32 »
They're here! And Christ on a bike they're amazing  :D
Plz Rama make more of these (maybe in Cherry profile? Pretty please? ;))
(Sorry potato quality picture)
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #218 on: Sat, 13 August 2016, 06:42:48 »
Plz Rama make more of these (maybe in Cherry profile? Pretty please? ;) )
Oh wow! That looks awesome on that board, so happy you like it bro!! :D
Hahaha yes! I know, EVERYONE wants Cherry profile :P The next keycap GB will be Cherry profile, promise!!
INSTA: @ramaworks
FB: ramaworks
Offline duynguyenle
« Reply #219 on: Sat, 13 August 2016, 15:41:55 »
So glad to hear  :D
If there's enough demand, would you consider offering range of colours like the first round? That would make me very happy!
Offline airs
« Reply #220 on: Sat, 13 August 2016, 15:48:53 »
Wait what? It's not cherry profile?
Octagon v2, LZ CLS
Offline duynguyenle
« Reply #221 on: Sat, 13 August 2016, 16:29:48 »
It's OEM profile. Still fits great with a Cherry keyset and you will not have any problems with it unless you've got a case of the OCDs. It won't bother most people. The difference between R1 Cherry and R1 OEM is rather small.
Offline airs
« Reply #222 on: Sat, 13 August 2016, 21:24:49 »
Disappointed. Doesn't make much sense to have an artisan in OEM profile but what do I know.
Octagon v2, LZ CLS
Offline duynguyenle
« Reply #223 on: Sun, 14 August 2016, 04:01:08 »
What other Artisans are in Cherry profile? I have most often seen OEM ones
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #224 on: Sun, 14 August 2016, 04:15:44 »
Seriously, OEM is more popular with the majority of mechanical keyboard users, even though Cherry might be more popular with GH users
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #225 on: Sun, 14 August 2016, 08:10:46 »
So glad to hear  :D
Hmm, I definitely would like to do investigate some designs with color again, but maybe not so many next time :p Was such a mission getting that sorted hahaha, but yeah I'll definitely look into it bro!
Apologies airs :( Cherry is definitely in the pipeline for the future! I tried very hard to make it clear that these where OEM profile  :-\
INSTA: @ramaworks
FB: ramaworks
Offline xondat
  • i'm not a star
« Reply #226 on: Sun, 14 August 2016, 09:28:21 »
I mean it says it on the page you order it from... Most earlier artisans are OEM :)
Offline duynguyenle
« Reply #227 on: Sun, 14 August 2016, 09:44:13 »
So glad to hear  :D
Thanks man! Great to see a creator as communicative as you! Would be great for me to get on in Orange in Cherry profile to go with my upcoming GMK Carbon!
Offline airs
« Reply #228 on: Sun, 14 August 2016, 12:16:23 »
Not your fault Rama - as others have said it is on the product page and admittedly I am an artisan newbie.
Octagon v2, LZ CLS
Offline Giorgio
« Reply #229 on: Sun, 14 August 2016, 12:27:34 »
Need more rama key caps. Maybe a little bit cheaper, if possible  :thumb:
Maybe a water themed keycap to be sold with the new hydro set?
Offline vito687
« Reply #230 on: Mon, 15 August 2016, 18:39:00 »
Oh yeeeaaa these are sweet
Offline boo
« Reply #231 on: Tue, 16 August 2016, 00:03:22 »
Rama,
Got the package. One word: beautiful. Thank you
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #232 on: Tue, 16 August 2016, 00:49:10 »
I did really like the orange myself so there's a high probability of that! :P
GMK Carbon  :o  Nice dude! Excited for you :P
Yeah, I really want to get the price down as low as possible, very hard when dealing with low quantities though unfortunately :(
Water themed keycap sounds cool for sure! :O Got a few experiments I want to try out actually :P
Awesome Vito!! Glad to hear you got them and are liking them!! :D
Rama,
Boo!!
WOOO! No worries at all mate, glad you finally got your hands on them, enjoy!!
INSTA: @ramaworks
FB: ramaworks
Offline Spaceman1200
« Reply #233 on: Thu, 18 August 2016, 09:22:57 »
Got my cap w/pcb in today, utterly fantastic!
Offline Waateva
« Reply #234 on: Thu, 18 August 2016, 10:08:12 »
Mine came yesterday, here are a couple pics.
Packaging and caps are stellar as usual, great work Rama!
Offline rpeterclark
  • RPTR ❌
« Reply #235 on: Thu, 18 August 2016, 11:14:32 »
Mine came in yesterday as well. The finish on these is excellent. Thanks Rama!
Offline airs
« Reply #236 on: Thu, 18 August 2016, 12:31:57 »
It's here! The profile difference doesn't bother me at all. I love this keycap, thank you Rama :)
Octagon v2, LZ CLS
Offline boo
« Reply #237 on: Thu, 18 August 2016, 13:15:43 »
That hyper fuse. Jealous
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #238 on: Thu, 18 August 2016, 18:41:29 »
Great! Cheers mate :D
Thanks for the photos mate! No worries at all, onto the next project now! :) Good to see people are receiving their packages, I get so nervous during this period and hope that it all turns out okay :S
Glad you like it bro! Enjoy them :D
Yup, very jealous too. That looks awesome bro!!
Thanks all for the kind words and the photos, means a lot to me!
INSTA: @ramaworks
FB: ramaworks
Offline ba7777
« Reply #239 on: Sat, 20 August 2016, 20:52:25 »
Hi Rama. Please check out my pm. Thanks.
从我的 iPad 发送,使用 Tapatalk
Offline airs
« Reply #240 on: Sat, 20 August 2016, 22:17:20 »
Octagon v2, LZ CLS
Offline duynguyenle
« Reply #241 on: Sun, 21 August 2016, 05:34:30 »
Oh golly gosh, check out that colour matching with Dolch's alpha base. Maybe it's time to dig out that old set of GMK Dolch I got lying around!
What next project Rama plz tell!  :D
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #242 on: Sun, 21 August 2016, 08:35:08 »
Hey mate, thanks for pm'ing - replied!
Damn dude!! Thanks for the photos, that looks awesome on that board :o Really matches for sure!
HMMM good question actually :P Got so many going on, question is which do I release first! A lot of them are ready for prototyping, just need to save up some money first so I can get them made -
then we'll be good to go! Whichever project it is, I cannot wait to get it out to people :D
INSTA: @ramaworks
FB: ramaworks
Offline Data
« Reply #243 on: Tue, 23 August 2016, 16:06:28 »
Received my cap and PCB today.
Your GB did not prepare me for the ultimate badassness I was about to receive.  Are you a wizard?
My only regret is the board I intended to use the RAMA cap with isn't quite ready.  I guess I know what I'm doing this weekend...  :rolleyes:
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #244 on: Tue, 23 August 2016, 18:53:35 »
My only regret is the board I intended to use the RAMA cap with isn't quite ready.  I guess I know what I'm doing this weekend...  ::)
Awesome mate! Great to hear! Hah, if getting things manufactured is wizardry, then yes!
Oh damn dude, hope you get to put it to use ASAP - please post photos when it's assembled! :)
INSTA: @ramaworks
FB: ramaworks
« Reply #245 on: Tue, 23 August 2016, 20:54:09 »
Yeeeee maaaane! The cap arrive with the extra PCBs, thanks a lot!
The  color is so so tight! Going to try and get some snaps of it on my TX1800 pronto!
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #246 on: Tue, 23 August 2016, 21:01:17 »
YEEE!!!
No worries man! :D Gotta get me some photos of that please! :)
INSTA: @ramaworks
FB: ramaworks
Offline Giorgio
« Reply #247 on: Wed, 24 August 2016, 02:48:46 »
White:
Yellow:
Black:
And the back:
I've never seen such a meticulous work, surely you'll find a gratifying job, if you don't already have one :-)
Offline ba7777
« Reply #248 on: Thu, 25 August 2016, 03:11:20 »
The envelope was in my mailbox this morning.  The caps are so beautiful. Will try to take some pics for them.
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #249 on: Thu, 25 August 2016, 05:46:25 »
Wow, thanks heaps mate, means a lot! Not my dream job, but work's work :P
Omg, good! Was starting to worry, glad they got to you mate!! Cannot wait to see the photos!! :D PHEW!
INSTA: @ramaworks
FB: ramaworks
