Author Topic: [IC] Split ortholinear keyboard: Double Rainbow  (Read 27291 times)
Offline Dotdash32
Re: [IC] Split ortholinear keyboard: Double Rainbow
« Reply #50 on: Sat, 18 June 2016, 00:03:53 »
Interested!
Do you think that would be possible to have the case a bit less tall?
The case, at current dimensions, is only .574" tall from bottom to top of the switch plate.  It might be possible to reduce it a bit, but it's not much taller than the average Planck, according to my measurements.
Offline nevin
« Reply #51 on: Fri, 12 May 2017, 06:56:58 »
I'd love something like this but would want something with a 5x6 grid instead of 4x6. Does anyone know if anyone has plans for or has done a pair of 5x6s?
Offline ibakey
« Reply #52 on: Mon, 15 May 2017, 02:09:17 »
Exactly. I are currently looking for a split ortholinear that offers 5x6. There are plenty of split plancks but none for the preonic or the atomic.
« Last Edit: Mon, 15 May 2017, 02:11:12 by ibakey »
Offline Phenix
« Reply #53 on: Tue, 16 May 2017, 08:24:09 »
What about https://www.reddit.com/r/mechmarket/comments/6arvyi/gb_mitrosis_diy_kit/
not an split Atomic, but it has many THUMB BUTTONS :p
Winter is coming.
Offline nevin
« Reply #54 on: Tue, 16 May 2017, 08:38:19 »
GREAT FIND! Love the idea of bare PCB as a plate.
That's an extremely nice & minimal setup, but not what i am looking for. Too few switches. (23 per side, that's still 40% territory)
Offline mclow85
« Reply #55 on: Thu, 28 June 2018, 17:52:14 »
this is great... i love the frosted white !!!
are the keys also with rgb led?
i definitly would buy this keyboard if the keys are also rgb and it would had some kind of case like this
https://de.aliexpress.com/item/Customized-YMDK-60-Kit-61-Programmable-Underglow-RGB-Led-PCB-For-GH60-DIY-Mechanical-Keyboard-Bface/32813272960.html
also a wrist rest like the digma raise would be great.... maybe also a symetrical alternative would be cool!
