Author Topic: Split keyboard pcb  (Read 8286 times)
Offline climbalima
  • likes building stuff
Split keyboard pcb
« on: Sun, 05 June 2016, 01:45:09 »
Howdy clackers! Im doing an IC for a split keyboard and designed an extra pcb This one has all throuhole components and runs off a pro micro. It is untested, but I have some on the way.
Ifd anybody out there wants to make a split ortho, but doesnt want to handwire you can test out my pcb! It can be purchased from easyEDA for around 30 for 10 pcbs. It uses the same trrs connector as the ergodox. https://github.com/climbalima/split-pcb-throughole Github link
PCB
Offline FletchINKy
  • Troy Fletcher, Kentucky USA
    • Troy Fletcher Dot Net
Re: Split keyboard pcb
« Reply #1 on: Mon, 06 June 2016, 13:35:19 »
Looks great! I'll be doing a split matrix http://www.keyboard-layout-editor.com/#/gists/941c1a33a3370eec9ba0165341e6ce63 soon, but it'll be handwired. Since it's hardware wired (for now?) a PCB seems pretty daunting to me, especially since I want to make two methods of connecting the halves. Think wired when separated, but no wire when snapped together.
Offline mrbishop
  • Evil Genius
    • Bishop Computer Design web
« Reply #2 on: Fri, 18 November 2016, 20:51:49 »
going to be building some of these soon. ;D
Projects
Offline layornos
« Reply #3 on: Thu, 05 January 2017, 12:54:26 »
As i can see, the pcb is just usable from one side, right? Not as, for example, the ErgoDox pcb.
Offline climbalima
« Reply #4 on: Sat, 07 January 2017, 12:55:55 »
The v2 is reversible. This version is not.
Offline mrbishop
  • Evil Genius
« Reply #5 on: Sat, 07 January 2017, 13:19:15 »
does that mean the PCB goes both ways?  :eek:
Projects
Offline layornos
« Reply #6 on: Sat, 07 January 2017, 13:34:32 »
The time you release v2, i definitely will build one  :cool:
Offline mrbishop
  • Evil Genius
« Reply #7 on: Sat, 07 January 2017, 14:52:25 »
Projects
