Author Topic: Noxary Keyboards  (Read 57680 times)
Offline xondat
  • i'm not a star
Noxary Keyboards
« on: Mon, 06 June 2016, 16:59:12 »
« Last Edit: Fri, 10 May 2019, 13:20:57 by xondat »
Offline Firebolt1914
  • POM Overlord
Re: Custom 75% Case
« Reply #1 on: Mon, 06 June 2016, 17:10:48 »
literally a rectangle with brass 0/10
Offline TheVengeance
Re: Custom 75% Case
« Reply #2 on: Mon, 06 June 2016, 17:41:57 »
Is this not literally the RS84 special edition, brass and all.?
Re: Custom 75% Case
« Reply #3 on: Mon, 06 June 2016, 17:44:58 »
The two look nothing alike, aside from the form factor. Git out.
Offline xondat
  • i'm not a star
Re: Custom 75% Case
« Reply #4 on: Mon, 06 June 2016, 17:47:01 »
Form factor is the same. Every 60% is a Pok3r so I see where you're coming from.
Feel free to show me a picture of it looking like mine :))
Re: Custom 75% Case
« Reply #5 on: Mon, 06 June 2016, 17:49:09 »
I know where you're coming from.
And I guess yours is solid walled etc.
But the brass bit is super similar.
Offline xondat
  • i'm not a star
Re: Custom 75% Case
« Reply #6 on: Mon, 06 June 2016, 17:50:28 »
Didn't even know this existed.
My weight is on the inside, opposite to the RS84. I can show you a range of kustoms with weights though, it's pretty normal.
Re: Custom 75% Case
« Reply #7 on: Mon, 06 June 2016, 17:50:38 »
How unique can one make a rectangle of brass? It's not even mounted on the same face by the way.
Re: Custom 75% Case
« Reply #8 on: Mon, 06 June 2016, 17:54:18 »
I guess I'm just a big n00b, I'll sit down.
I'm sorry.
I didn't realise that brass weights were such a thing. Had only seen on the RS84, which is also 75%.
As such looks cool, 75% appears to be the sweet spot for me.
Offline xondat
  • i'm not a star
Re: Custom 75% Case
« Reply #9 on: Mon, 06 June 2016, 17:55:57 »
I'm sorry.
Welcome to the world of customs!
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
Re: Custom 75% Case
« Reply #10 on: Mon, 06 June 2016, 18:10:48 »
Great work Xondat! Very impressive that you dived straight in and came out with this  :D Looks like a fun project to test out your new found abilities - best of luck with it!  :-*
Didn't notice my personal messages have been disabled for those thinking you have been blocked - to contact please reach out through Facebook messages or support email!
WEB: https://rama.works/
STORE: https://ramaworks.store/
INSTA: @ramaworks
FB: ramaworks
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Custom 75% Case
« Reply #11 on: Mon, 06 June 2016, 18:14:53 »
Looks like a serious 75% case to me.
Offline Zorberema
  • IG: @ZorbCaps
Re: Custom 75% Case
« Reply #12 on: Tue, 07 June 2016, 07:43:18 »
Looks great mate, you should've used sketchup though ;)
Offline xondat
  • i'm not a star
Re: Custom 75% Case
« Reply #13 on: Wed, 08 June 2016, 06:45:52 »
Just got quoted - "it would cost over £500 at least". This is for one, anodized with the weight. That's $730 for people that use USD.
Anyway my goal for today is to try a different layout, 60%, and see if I can finish with a case/plate/weight like this.
Offline xondat
  • i'm not a star
Re: Custom 75% Case
« Reply #14 on: Thu, 09 June 2016, 18:34:34 »
This is currently what I'm working on.
Offline xondat
  • i'm not a star
Re: Custom 75% Case (& 60% In Development)
« Reply #15 on: Fri, 10 June 2016, 10:57:46 »
Getting closer to finishing this. I just need to add a couple of finishing touches and it'll be done for now.
Offline xondat
  • i'm not a star
Re: Xondat's Keyboard Design Stuff
« Reply #16 on: Fri, 15 July 2016, 19:47:06 »
Dumping final pictures and renders of the X60 here and will post pictures of what I'm up to tomorrow. I finished the base model for a TKL, and will finish up a 75%. Numpad work will start as soon as I'm happy all my designs are accurate.
Offline Jokrik
« Reply #17 on: Fri, 15 July 2016, 19:51:31 »
Offline xondat
  • i'm not a star
« Reply #18 on: Sat, 16 July 2016, 16:00:02 »
75% and TKL bases complete. Numpad development is going on now. :))
Offline xondat
  • i'm not a star
« Reply #19 on: Sat, 16 July 2016, 17:10:10 »
Wasn't too difficult. Going to take suggestions on what next - someone has said ergodox (ew).
« Last Edit: Sat, 16 July 2016, 17:14:25 by xondat »
Offline stillzman
« Reply #20 on: Sat, 16 July 2016, 19:22:18 »
really want that 75% ;D
Offline QuincyJones
« Reply #21 on: Sat, 16 July 2016, 20:31:38 »
OH! Look! It's every other keyboard that exists!
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline xondat
  • i'm not a star
Re: xondat's projects
« Reply #22 on: Wed, 31 August 2016, 20:02:46 »
« Last Edit: Sat, 20 January 2018, 12:20:10 by xondat »
Offline Phenix
« Reply #23 on: Thu, 01 September 2016, 10:09:00 »
I would really like to see something like that but with also arrows on the left side.
And more bottom row options for split space
Winter is coming.
« Reply #24 on: Thu, 01 September 2016, 16:46:15 »
No idea how I totally missed this thread.
Offline xondat
  • i'm not a star
« Reply #25 on: Thu, 01 September 2016, 17:13:07 »
I mean it's nothing significant... I forgot about it until yesterday :))
Offline xondat
  • i'm not a star
« Reply #26 on: Fri, 02 September 2016, 06:24:50 »
**** render but im still learning, new one in a bit
had a request for a blocker on a 75% to separate the arrow keys and whatever, most likely will offer it when i release this
Offline xondat
  • i'm not a star
« Reply #27 on: Fri, 02 September 2016, 09:18:02 »
it's too zoomed out but **** it
probably will put an IC up as I pack 60S, and launch when I'm done I guess
Offline stillzman
« Reply #28 on: Mon, 05 September 2016, 10:30:13 »
any idea when when this will be released?
Offline xondat
  • i'm not a star
« Reply #29 on: Mon, 05 September 2016, 11:13:35 »
X75? November providing everything goes to plan.
Going to finish X60 first.
« Last Edit: Mon, 05 September 2016, 11:58:45 by xondat »
Offline xondat
  • i'm not a star
« Reply #30 on: Mon, 17 October 2016, 13:52:52 »
I updated the OP to show everything I plan on doing in the next 6 months that I've revealed :)
Offline Niomosy
« Reply #31 on: Mon, 17 October 2016, 18:34:26 »
Dat 75%.  One with Gateron reds would be fantastic.
Offline cribbit
« Reply #32 on: Mon, 17 October 2016, 21:44:31 »
Where/how do you get the physical product produced?
Any tips for using CAD software? Trying some out right now but I feel like a moron trying to use it.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
Offline R4WBIT
« Reply #33 on: Tue, 18 October 2016, 15:22:31 »
Would love to see your take on a 96% board in the future. We desperately need one without LED diffusers į la ZZ96 & RS96. Absolutely love the style of just plain aluminum without anything unnecessary :)
Offline xondat
  • i'm not a star
« Reply #34 on: Tue, 18 October 2016, 18:54:29 »
Lots of searching for the perfect manufacturer. Pour hundreds of hours into practice and understanding how it all works. I probably did 100 in the first couple of weeks.
Offline xondat
  • i'm not a star
« Reply #35 on: Tue, 15 November 2016, 16:15:52 »
Updated.
X65 will come before X75, just confirming some information before I officially start a thread or something.
Offline Saiph
« Reply #36 on: Tue, 15 November 2016, 16:17:26 »
Updated.
Darn :P
Offline xondat
  • i'm not a star
« Reply #37 on: Tue, 15 November 2016, 16:40:25 »
Actually, I need to expand further.
For future releases (X65, X75, etc), they will be in rounds of 25 and each design will max out at either 50 or 100. I want to do rounds to break everything up a bit, but also it gives flexibility to what I run. For example, I could do X65 R1 December, then X75 R1 January, then X65 R2 February etc. It works for everyone. This also allows me to fulfill rounds/orders much quicker, as the parts will already be machined, so I'd start the GB and within a week they should be ready to ship to me as they'd only need anodizing.
I'll also be changing the colors I use, this is all very much in the air right now, but it's looking like I'll be dropping Gold. Dark Gray and Silver are here to stay, Red most likely is too. I'm uncertain about the future of Black, Dark Blue and Purple. Most of this depends on how I like the color when I actually see it on a board (X60 production). I've also been thinking about introducing a custom, user-polled color for each round, so for example, X65 R1 might have a Sky Blue, and then X65 R2 might have Viper Green.
Regarding "Edition" boards, the future of those is uncertain. I personally like having numbered, and/or limited things, but I'm aware some people also get rather annoyed which ruins it for some people that actually enjoy it. It also might **** with the aftermarket price, but that isn't a massive concern. I really like the Carbon Edition, but I feel like it limits the users that chose that too much, so I'll have to rethink that.
For PCBs, now that I'm not using a universal platform (60%), I have to either outsource or learn how to do it myself. This is why X65 is coming a lot sooner, as I was going to be learning how to make my own, and then releasing it with my own custom PCB. X75 was always going to be sooner, as I would've used the winkeyless b.mini and then that would've delayed enough until I knew how to make my own for X65. Instead, I've been in talks with someone and they'll be supplying the PCBs for X65 so in the meantime I'll learn how to design PCBs.
And finally, just because it needed to be mentioned, there will be no group buys until I have fulfilled X60. However, there probably will be teases/interest checks up until then. Oh and if anyone read all of this, please leave some feedback/discussion points on your thoughts. Thanks!
:thumb:
Offline Saiph
« Reply #38 on: Tue, 15 November 2016, 17:00:23 »
I really like that you're aiming for such fast rounds. Sometimes planning builds 6 months in advance can get tiring. Do you know what firmware your pcbs will be supporting yet?
Offline xondat
  • i'm not a star
« Reply #39 on: Tue, 15 November 2016, 18:57:40 »
X65 will be a modified version of TMK, I'll probably follow the same path, but honestly I've not looked into it yet so I don't really know much about firmware.
Offline PlastikSchnittstelle
« Reply #40 on: Wed, 16 November 2016, 07:37:05 »
will it be possible, to order the 65% PCB separately?
great work!
Offline xondat
  • i'm not a star
« Reply #41 on: Wed, 16 November 2016, 07:38:59 »
great work!
Not from me no, you'd also have the problem of finding a case for the PCB although I think the designer of the PCB is doing a lower cost case.
Offline Fictiouz
  • That "White" Guy
« Reply #42 on: Wed, 16 November 2016, 08:07:39 »
:thumb:
Everything looks great xondat. Plans are well thought out and fairly clear for everyone interested. And THANK YOU for prioritizing the GB's you're currently working on versus ones that are still in the development. It's way better to get one thing out the door then be micromanaging many different things in my opinion.
Can't wait to see what's in store with your future designs. That dark grey and red color scheme you always preview is really growing on me. Maybe that's what I'll get when X75 rolls around.
Stop stealing all my money and good luck with all your endeavors. :thumb:
EDIT: Also, when designing the 65% PCB, for the love of god, do not make the USB in the center of the PCB. :p
« Last Edit: Wed, 16 November 2016, 08:15:55 by Fictiouz »
« Reply #43 on: Wed, 16 November 2016, 08:11:43 »
thanks for your quick reply.
damn, i cant find no 65% pcb being sold separately anywhere. i do like your case-design. but i want to make my own. i have experience in lasering alu and folding, so it is really not a big deal for me. since i will not design my own caps nor pcb, the case is the only chance for me to give it a more personal note.
any idea where i could find a 65% pcb?
« Last Edit: Wed, 16 November 2016, 08:14:43 by PlastikSchnittstelle »
Offline Fictiouz
  • That "White" Guy
« Reply #44 on: Wed, 16 November 2016, 08:12:12 »
I made a little guide to help the lost firebort get back on track... It was using a layout idea by switchnollie and then vamped by frostytoast.
http://imgur.com/a/i6IRw
If someone can make a PCB for this, I'll have a few made because it looks fun :))
Just saw this now. This layout gets me hot and bothered.
If this supports HHKB Num row, ANSI Enter and uses short right shift I would wait a lifetime for this layout.
EDIT: Missed the album. See the design better now. Maybe not what I thought, but still a neat design!
« Last Edit: Wed, 16 November 2016, 08:13:54 by Fictiouz »
Offline cribbit
« Reply #45 on: Wed, 16 November 2016, 20:44:44 »
If you have a dream layout and money you could always build it yourself, or pay someone like me to build it for you :)
Offline gzprime
« Reply #46 on: Thu, 17 November 2016, 00:44:48 »
:thumb:
I like that you're changing things up to finish projects one at a time. I look forward to different colorways and options in the future. If there was an option of purple anodizing with the x75 that would be some end game stuff for me. I was already considering having the plate re-anodized to be purple but I still can't find anyone local that is up to my standards. Don't make me beg for purple.  :-X
I, too, like the limited nature of things. This will (hopefully) be my 3rd 75% and I'm kinda crazy and wouldn't be opposed to owning multiple x75s if they offered feature sets that made them unique enough to own multiples.
I just had a custom PCB designed for an ortholinear layout so if you need people to talk to, just send me a PM. It was more cost-effective than I thought it'd be.
Offline xondat
  • i'm not a star
« Reply #47 on: Mon, 21 November 2016, 20:03:47 »
I believe the PCB I will be offering will be available on its own slightly after mine. My 65% PCB could also be sold separately on request, but will be packaged with my designs.
You're too kind :-* The 65% PCB will be centered so it works with X65 and another design. Why should it not be centered?
I will probably do this one day for fun. What was the design you thought it was?
I can't remember if I mentioned it, but the Blue and Purple I ordered with X60 are test colors, so you might see those in the future without having to beg. When I get started properly with PCB design, I'll be sure to message you.
Offline xondat
  • i'm not a star
« Reply #48 on: Sun, 11 December 2016, 16:30:16 »
It might be obvious, but this is a tray mount 60% case that I'll have readily available on my store next year along with my sandwich style case. The dimensions are identical to X60, including the height of the sides. It's compatible with all tray style cases, unless the corners on your plate isn't rounded.
Naming wise, either XT60 or T60. XT60 is a reference to my poor attempt last year at a tray mount case, but I didn't actually know anything to do with CAD. T60 is obvious too - Tray 60. It'll fit with my scheme which will be X (Flagship), T (Tray), and N (Sandwich). We'll stick with T60 for now.
I'll be getting this prototyped and shipped with X60 weights, along with N60. I'll post a picture of N60 in the next few days once I've finished the last little details.
Offline Brammm87
« Reply #49 on: Wed, 14 December 2016, 09:41:09 »
Damn, awesome stuff!
pls gief bbv2
