Author Topic: [GB] Noxary X60 V1  (Read 675585 times)
Offline xondat
  • i'm not a star
[GB] Noxary X60 V1
« on: Fri, 10 June 2016, 16:33:49 »
Information:
  • 8 Degrees Base Angle
  • Top Mounted Plate with Switch Opening
  • Compatible with any Standard 60% PCB
  • Choice of 3 Different Top Pieces
  • ANSI or Universal Plates
  • Total of 100
X60 V1 Founders Edition:
  • Black, Dark Gray, Silver, Gold, or Red Anodizing
  • Brass Weight with Engraving & Individual Numbering
  • Aluminium or Stainless Steel Plate
  • Limited to 30 Units
X60 V1 Carbon Edition:
  • Black Anodizing
  • Stainless Steel Weight with Engraving & Individual Numbering
  • Carbon Fiber Plate
  • Limited to 10 Units
X60 V1:
  • Limited to 60 Units
« Last Edit: Thu, 16 May 2019, 10:38:41 by xondat »
Offline ramnes
  • T fou, mec?
Re: [IC] 75%, HHKB & 60% Customs
« Reply #1 on: Fri, 10 June 2016, 16:38:52 »
Awesome bud!
In for a normal 60% if you can get a nice 60% PCB that runs TMK and has LEDs.
Can you engrave something cool on the weight?
Offline muon
« Reply #2 on: Fri, 10 June 2016, 16:41:51 »
Looks good, let me know if you need any help :)
Offline cmd
« Reply #3 on: Fri, 10 June 2016, 16:47:50 »
Hi, I like the HHKB one, also, name it, "Xondike Bar"
Offline Saiph
« Reply #4 on: Fri, 10 June 2016, 16:52:18 »
I'm looking to get a nice 75% and missed out on Octagon as well. Definitely interested!
edit: I think someone else is running a hhkb case interest check as well, not sure how different yours would be.
« Last Edit: Fri, 10 June 2016, 16:53:49 by Saiph »
Offline rpeterclark
  • RPTR ❌
« Reply #5 on: Fri, 10 June 2016, 17:26:51 »
I need the HHKB case in my life please.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #6 on: Fri, 10 June 2016, 19:42:25 »
 I'd possibly be interested in a 75%. Renders are looking great man!
Offline Phenix
« Reply #7 on: Fri, 10 June 2016, 20:35:05 »
why not doing something more interesting than 75?
75% but
Smart68 arrow cluster
+second set of arrows/nav cluster on the left
Winter is coming.
« Reply #8 on: Fri, 10 June 2016, 20:40:45 »
75% but
I think 75% is unusual in itself.
« Reply #9 on: Fri, 10 June 2016, 20:41:26 »
Would any of them accommodate an RGB diffuser?
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #10 on: Fri, 10 June 2016, 20:49:45 »
This would definitely be preferred, imo.
Offline ramnes
  • T fou, mec?
« Reply #11 on: Fri, 10 June 2016, 21:02:54 »
Please no, keep it simple :(
« Reply #12 on: Fri, 10 June 2016, 21:05:31 »
Well, the RGB diffuser would be optional, of course. It could be an add-on with longer screws.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #13 on: Fri, 10 June 2016, 21:10:42 »
Having the option to do either would be pretty nice and accommodate a larger set of people.
Offline feralfoo
  • Software developer and mech keyboard nut
« Reply #14 on: Fri, 10 June 2016, 21:36:35 »
This looks fantastic. The first render looks like it will support an arrow cluster on the bottom right  :thumb:.
Would love to see the controller chip on a seperate board, think Teensy/Adafruit Feather/etc. This would raise the cost, but also means we can add our own controller and write our own firmware. What do you think?
HHKB Pro JP + Hasu controller, Realforce RF87U55G, G60 Retro, QK65
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #15 on: Fri, 10 June 2016, 22:23:11 »
+1
I really like the regular 60%
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline raymogi
« Reply #16 on: Fri, 10 June 2016, 22:38:43 »
WKL 60% please.
Please feed my addiction.
Offline loud_asian
« Reply #17 on: Sat, 11 June 2016, 02:40:03 »
HHKB plox
Would it be possible to make the 60% keyboards support premade PCBs like the GH60 or NerD 60? You mentioned the lack of cutouts for the USB connection, and I figured that's the only thing you need to modify to fit the 60% PCB standard.
Would also be interested in engraving something neato for the weight  ^-^
Offline Diokhan
« Reply #18 on: Sat, 11 June 2016, 06:02:23 »
I'm in on the hhkb one and if that doesn't make it the 60% one.
Look really sleek!
Offline dannrawr
« Reply #19 on: Sat, 11 June 2016, 08:30:11 »
Rgb diffuser hehe
WTF any Bruce, Cosmonauts
Offline juahenza
  • DoSmallThingswithGreatLove
« Reply #20 on: Sat, 11 June 2016, 08:42:14 »
 hhkb pls  :thumb:
456GT | TGR Jane CE | Dolphin v2 | Whale | 360c | LZ FE | LZ IRON | TX-CP | Varmilo VA87M | HHKB P2 | IBM SSK P.1397681| IBM Industrial SSK P.1395682 | VE.A | Realforce 87u | Datamancer Streamline TKL | Datamancer Mechinist TKL | TANK v1 | RAMA M-4 | Realforce 108UW-HIPRO
Offline nickysan92
« Reply #21 on: Sat, 11 June 2016, 11:46:03 »
I'd prefer a 60%/HHKB layout for this board.
Personally, having a RGB diffuser like the one present on Duck's Blackbird would be great.
Offline user 18
« Reply #22 on: Sat, 11 June 2016, 12:07:59 »
The renders look like it has a steep angle on it -- what's the angle of the board?
Avatar by ashdenej
Offline FoC_Tow
  • Brokehlicious
« Reply #23 on: Sat, 11 June 2016, 15:36:39 »
Would be down for a hhkb layout, or if it's even an option to vote for arrowed 60%.
I don't like how the bottom is just an angled square extending the front tbh tho.
Throwing in another angle on the back would make the design look a lot more elegant.
Hubble Mira has a angled bottom in the opposite direction for example.
Offline xondat
  • i'm not a star
« Reply #24 on: Sat, 11 June 2016, 17:11:37 »
Well I revised the design, made an acrylic diffuser and added one new top plate. I'm currently replying to comments here in a separate post.
« Last Edit: Sat, 11 June 2016, 17:18:48 by xondat »
Offline xondat
  • i'm not a star
« Reply #25 on: Sat, 11 June 2016, 17:15:13 »
Once I figure out what to put, sure.
Accommodated!
Depending on the layout it's unlikely but I'll make sure to use a PCB that supports customization.
WKL 60% please.
Done.
60% PCBs are universal so it will support the standard 60% PCB.
8 degrees.
« Reply #26 on: Sat, 11 June 2016, 17:15:36 »
:D
Offline scubaste
« Reply #27 on: Sat, 11 June 2016, 17:21:15 »
Interested in the HHKB layout.
Offline jebbra
  • jebbra.net
« Reply #28 on: Sat, 11 June 2016, 21:49:38 »
HHKB plox
It's already done in another IC by Dotdash32
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #29 on: Sat, 11 June 2016, 21:53:19 »
Other than the USB location, the plate is mounted to the sides of the case, rather than the PCB being mounted to the bottom of the case. So that would need to be modified as well but I think this was done for increased rigidity. Same as how you see it on the TKL ones.
Offline fublamchu
  • ㅋㅋㅋ
« Reply #30 on: Sat, 11 June 2016, 22:31:16 »
interested in 60% layout
LZ-CE VBlacks
910-CE
Offline xondat
  • i'm not a star
« Reply #31 on: Sun, 12 June 2016, 07:27:21 »
I'll throw it out there as it's been mentioned a couple of times.
These are two very different cases. His is a normal 60% mounting style, with the PCB screwing into the case, identical for the traditional 60%. My PCB mounts to the plate, which mounts to the top case, similar to the great customs. His aim is to replicate the HHKB case but for MX whereas mine is just because people like the layout. Finally price points are completely different. To quote him "the goal is sub 100". Mine is a lot, lot more.
I'm going to be putting a questionnaire up in a few hours, it'll help if people fill it out.
Offline jebbra
  • jebbra.net
« Reply #32 on: Sun, 12 June 2016, 14:49:56 »
Yep I pointed out Dotdash just because what he search is the one Dotdash make, yours is a different story all the way, more like KMAC Happy / Viper
Offline loud_asian
« Reply #33 on: Sun, 12 June 2016, 15:22:40 »
nah I'd rather have xondat's hhkb than dotdash's. Xondat's version looks better
« Last Edit: Sun, 12 June 2016, 15:24:48 by loud_asian »
Offline xondat
  • i'm not a star
« Reply #34 on: Sun, 12 June 2016, 18:05:54 »
Questionnaire is live. All but a couple of questions are optional, so only answer the questions you think are relevant (although I'd appreciate you answering all questions).
I finished a complete remodel of the 60% form factors and will be doing a 75% remodel tomorrow. The remodel is just to make sure everything is working properly.
Offline vito687
« Reply #35 on: Sun, 12 June 2016, 18:36:01 »
Filled it out, really excited to see
This happening
Offline ramnes
  • T fou, mec?
« Reply #36 on: Sun, 12 June 2016, 20:26:27 »
Completed. :)
Offline billnye
  • ability man
« Reply #37 on: Sun, 12 June 2016, 20:29:01 »
Filled out.
If you make HHKB custom I love you long time :-*.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #38 on: Sun, 12 June 2016, 20:54:01 »
Filed it out. Wasn't too sure on comes but the blue/grey would be cool.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #39 on: Sun, 12 June 2016, 23:34:26 »
Filled out for regular 60% without a defuser  :thumb:
Blue-Grey would be one of my top choices for color.  Would also like to see a light, or medium Grey color option.
WTB/WTS/WTT ---->
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #40 on: Mon, 13 June 2016, 00:58:14 »
Nice, definitely interested in HHKB or WKL with diffuser to use with a B. Face X2 :thumb:
Offline brighenne
« Reply #41 on: Mon, 13 June 2016, 02:24:45 »
I'd be interested in a diffuser 60% or 75%.
Offline alveeno
« Reply #42 on: Mon, 13 June 2016, 09:54:01 »
I'd be interested in the hhkb, will it support SMD's?
Offline xondat
  • i'm not a star
« Reply #43 on: Mon, 13 June 2016, 09:59:07 »
As long as the PCB does.
Offline brighenne
« Reply #44 on: Mon, 13 June 2016, 11:58:29 »
I'd also like to throw it out there that I'd love to get one in raw alumin(i)um to do custom anodizing.
Offline Malenky
« Reply #45 on: Mon, 13 June 2016, 13:44:09 »
Interested in HHKB style case for sure.
Offline braidn
« Reply #46 on: Mon, 13 June 2016, 14:51:34 »
This is pretty epic Xondat. Will totally be in for the WKL case. Want some blockers in my life. Also doubly down if the PCB has some TMK love behind it.
Offline xondat
  • i'm not a star
« Reply #47 on: Mon, 13 June 2016, 18:09:59 »
These are the two weight shapes I'm deciding between - input would be appreciated. I made a strawpoll here. Please note that I haven't added tilt/chamfers/fillets yet. Screw holes aren't final.
Thank you to everyone that filled the questionnaire in so far.
Offline bocahgundul
  • a seal
« Reply #48 on: Mon, 13 June 2016, 18:14:41 »
bottom fo sho
Offline brighenne
« Reply #49 on: Mon, 13 June 2016, 18:25:30 »
Why not the longer dimensions of both? :D
