Author Topic: [GB] Noxary X60 V1  (Read 676125 times)
Offline aaron6301
  • Pixel Pusher
Re: [GB] X60
« Reply #1000 on: Sun, 27 November 2016, 11:18:51 »
I think I'm going to have the spacing matched for the inner engravings, and make sure the X60 is identical on both sides.
Are you referring to the padding around the X60 branding or the positioning of the branding. Of its the prior, yes, I think the padding around X60 should be identical on both sides. If you're referring to the positioning, an offset X60 logo will look odd without the text on the left.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Offline xondat
  • i'm not a star
Re: [GB] X60
« Reply #1001 on: Sun, 27 November 2016, 11:20:31 »
I meant the spacing of the text, as the NOXARY is more spaced out compared to the other text.
Offline FoC_Tow
  • Brokehlicious
Re: [GB] X60
« Reply #1002 on: Sun, 27 November 2016, 11:33:39 »
This is the layout I'm going to stick with. I think I'm going to have the spacing matched for the inner engravings, and make sure the X60 is identical on both sides. Obviously it's a mockup so it's slightly wonky. Also not sure on whether it should be "Limited to 100" or "Limited to 100 cases", so comment on that too.
I'm going to have each design prototyped and shipped with all parts and then approve the full production instead of taking the gamble and hoping it looks nice. Unfortunately this will push it into shipping next year, which is obviously a disappointment, but I don't want to screw this up. Thanks for the continued support and patience.
Glad to see an update on the weight design! =)
I'm sorry to bring this up, but to be perfectly honest I'm not a fan of the font used and the way it's layed out tho.
I think a slightly wider an less tall font would work a lot better with the width of the weight, especially on the bottom side aswell as look more aesthetically pleasing overall.
Imo placing the logo off center on the bottom following the golden cut/ratio could improve things aswell.
To me it looks like a pretty square logo slapped in the middle of the rather long weight.
Just my two cents of course, so if no one shares my opinion I'm ok with that.
Not trying to cause trouble here just my honest opinion.
Incase it's appreciated I would gladly create a mockup of what I'm imagining in terms of layout.
Offline aaron6301
  • Pixel Pusher
Re: [GB] X60
« Reply #1003 on: Sun, 27 November 2016, 11:39:45 »
I think the letter spacing is ok, I would however change the font weight of "NOXARY". Perhaps add a little weight to emphasize the branding.
If changing the font weight is out of the question, then yes, unify the letter spacing.
Offline Jemaunji
Re: [GB] X60
« Reply #1004 on: Sun, 27 November 2016, 16:12:34 »
I think that weight design looks clean.
Offline logomachy
Re: [GB] X60
« Reply #1005 on: Sun, 27 November 2016, 16:36:42 »
I agree. Off center bottom logo.
Maybe left aligned inside text without variable spacing.
And LIMITED EDITION OF 100 imo
Offline xondat
  • i'm not a star
Re: [GB] X60
« Reply #1006 on: Mon, 28 November 2016, 05:52:05 »
If you could demonstrate this in paint or something, that'd be great. Not too sure what you are going for, but it's certainly not the direction I'm taking it.
As above, a crappy paint mockup would help here in visualizing it.
Got it - good idea.
Offline Damonskv
Re: [GB] X60
« Reply #1007 on: Mon, 28 November 2016, 06:54:08 »
man, thanks for hard work for community  :thumb: :thumb:
Can I make a small suggestion?
For my it seems to me a little unnatural arrangement of the font stretched vertically on such big horisontal space, it may cost a little stretch horizontally?
Offline FoC_Tow
  • Brokehlicious
Re: [GB] X60
« Reply #1008 on: Mon, 28 November 2016, 06:57:56 »
Sure! Here's a quick and dirty mockup, to illustrate what I was refering to.  :)
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: [GB] X60
« Reply #1009 on: Mon, 28 November 2016, 07:07:43 »
Im personally not a big fan of the off center logo. But widening the inner lettering seems like a good idea.
Only thing im worried about is the increased time. Xond spent quite a while finding the one he likes, and he landed on this one which is pretty nice to be honest. Im a fan of the design and the logo, but the widening for the inner weight seems like a decent idea.
Offline FoC_Tow
  • Brokehlicious
Re: [GB] X60
« Reply #1010 on: Mon, 28 November 2016, 07:14:30 »
The off center logo comes down to personal preference I guess.
My main point was going with a wider font / letter spacing to fit better with the huge horizontal space of the weight, just as you mentioned aswell.
Heres a centered version for refference :)
Offline Fictiouz
  • That "White" Guy
Re: [GB] X60
« Reply #1011 on: Mon, 28 November 2016, 07:44:36 »
When do you expect to see a final prototype of the weight xondat?
Offline pace8500
Re: [GB] X60
« Reply #1012 on: Mon, 28 November 2016, 07:47:47 »
Great work with the mock ups but I much prefer the original font to this. It has something distinctive about it that I like.
Offline xondat
  • i'm not a star
Re: [GB] X60
« Reply #1013 on: Mon, 28 November 2016, 07:55:13 »
Sure! Here's a quick and dirty mockup, to illustrate what I was referring to.  :)
Unfortunately to some, the font isn't going to change. The things that can change is the weight, the spacing, and the layout of the text. I'm not a fan of the offset X60, it just looks out of place and holds no purpose. Thanks for the mockups.
For my it seems to me a little unnatural arrangement of the font stretched vertically on such big horizontal space, it may cost a little stretch horizontally?
I don't think stretching the font would look as nice; perhaps increasing the spacing to give the appearance of a longer font may work. I'll come back with some alternate spacing and give that a go.
Only thing I'm worried about is the increased time. xondat spent quite a while finding the one he likes, and he landed on this one which is pretty nice to be honest. I'm a fan of the design and the logo, but the widening for the inner weight seems like a decent idea.
3 months in and I found the font (and complete design) I like, so I think spacing is the one thing that can change at this time.
My main point was going with a wider font / letter spacing to fit better with the huge horizontal space of the weight, just as you mentioned as well.
Here's a centered version for reference :)
As said above, I think increasing the spacing is the way forward here.
I'll send over the feedback I got here and get a final design soon, hopefully. After that it's a 1-3 week sample production. The sample weights will ship with the finished parts, so up to 4 weeks from when I get the final design I'd say.
I'm not too sure if this has been shared, but this is the final logo and branding that I'll be using in the future. Spacing and weight can change, but we'll keep playing around with the weights.
Offline wodan
Re: [GB] X60
« Reply #1014 on: Mon, 28 November 2016, 08:00:39 »
*nods*
I'm glad 7bit taught me patience. Linearity of time is cruel
Offline aaron6301
  • Pixel Pusher
Re: [GB] X60
« Reply #1015 on: Mon, 28 November 2016, 10:47:56 »
Typography 101 - Never distort a typeface. Adjust letter-spacing, kerning, and weight... If that still doesn't do it, find another typeface.
Offline loud_asian
Re: [GB] X60
« Reply #1016 on: Mon, 28 November 2016, 10:50:38 »
The original looks best imo
Offline smittysteve
  • Tea > Coffee. Clack > Thwock.
Re: [GB] X60
« Reply #1017 on: Mon, 28 November 2016, 11:07:30 »
Agreed. I quite like the look of the original plate.
My vote is for "Limited to 100" or "Limited Edition - 100 Cases" and again, like the typeface you've gone with there.
Thanks for the chance to give input, Xondat.
Offline aaron6301
  • Pixel Pusher
Re: [GB] X60
« Reply #1018 on: Mon, 28 November 2016, 11:12:59 »
Here's my layout suggestion sans your font choice, can't seem to find it.
Offline FoC_Tow
  • Brokehlicious
Re: [GB] X60
« Reply #1019 on: Mon, 28 November 2016, 11:24:11 »
Love it! Huge improvement compared to the original imo.
Offline SixtyLife
Re: [GB] X60
« Reply #1020 on: Mon, 28 November 2016, 11:32:15 »
+1 great job, love this
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
Re: [GB] X60
« Reply #1021 on: Mon, 28 November 2016, 12:01:34 »
Something like that looks a lot cleaner imo
Offline RobotMalcolmX
  • hackerman
Re: [GB] X60
« Reply #1022 on: Mon, 28 November 2016, 12:03:40 »
And would pair really well with a pexon cable...
Offline brighenne
Re: [GB] X60
« Reply #1023 on: Mon, 28 November 2016, 12:39:40 »
http://i.imgur.com/AwTx9d1.jpg
 :thumb:
Offline Fictiouz
  • That "White" Guy
Re: [GB] X60
« Reply #1024 on: Mon, 28 November 2016, 12:42:39 »
This would be clean as hell with xondat's typeface. And do something like Carbon Edition 01/10, Founder Edition 01/30, Standard Edition X/100 so it keeps the same form but standard isn't numbered (use xondat's X he uses in Noxary and X60)
Offline aaron6301
  • Pixel Pusher
Re: [GB] X60
« Reply #1025 on: Mon, 28 November 2016, 12:50:09 »
My plan was to hunt down the font that Xondat's designer used as I like it as well... But, alas, my patience grew thin  :rolleyes:
Offline loud_asian
Re: [GB] X60
« Reply #1026 on: Mon, 28 November 2016, 12:50:35 »
that pretty ****in neato, I think I like this one more
Offline Jemaunji
Re: [GB] X60
« Reply #1027 on: Mon, 28 November 2016, 12:52:02 »
I'm really digging this one too.
Offline pexon
    • Pexon PCs
Re: [GB] X60
« Reply #1028 on: Mon, 28 November 2016, 13:17:20 »
:3
Offline jessica
  • Formerly CuteDreamsOfYou & Brazzers
  • HHKB is the only good layout
Re: [GB] X60
« Reply #1029 on: Mon, 28 November 2016, 14:11:51 »
Hopping on the bandwagon here, that looks stellar. Xondat, I think the opinion is clear here :P
GMK Plum /// GMK Necro
I am going to re-run these sets soon
Offline lishi
  • Luxury Taste Buds
    • Personal Website
Re: [GB] X60
« Reply #1030 on: Mon, 28 November 2016, 14:45:48 »
Yes, please never distort a typeface!
All the kustom 60s
Offline Khers
  • Schrödinger's box
Re: [GB] X60
« Reply #1031 on: Mon, 28 November 2016, 15:50:58 »
I like this!
Offline Gatix
  • #!/bin/sh
  • console.log
Re: [GB] X60
« Reply #1032 on: Tue, 29 November 2016, 09:26:41 »
This is awesome. I like this one a lot better
Offline dgneo
  • Supervillain
Re: [GB] X60
« Reply #1033 on: Tue, 29 November 2016, 10:04:12 »
Killer  :thumb:
Offline fendent
Re: [GB] X60
« Reply #1034 on: Tue, 29 November 2016, 10:13:32 »
This looks really nice
Re: [GB] X60
« Reply #1035 on: Tue, 29 November 2016, 10:32:27 »
I'm also a fan of that design, and I'm not even in this GB.  :))
  • hackerman
Re: [GB] X60
« Reply #1036 on: Tue, 29 November 2016, 10:37:19 »
That's how you know it's good.
Offline pace8500
Re: [GB] X60
« Reply #1037 on: Tue, 29 November 2016, 10:47:40 »
If anyone wants to swap their Black or Gray HHKB case for my Black 60% case then let me know.
The chances are slim but it's worth a try!
« Last Edit: Tue, 29 November 2016, 10:58:33 by pace8500 »
Offline Jumie
Re: [GB] X60
« Reply #1038 on: Wed, 30 November 2016, 01:15:56 »
Btw is this going to have a diffuser?
Offline loud_asian
Re: [GB] X60
« Reply #1039 on: Wed, 30 November 2016, 01:17:19 »
no xondat mentioned that the diffuser was scrapped
his prototype also doesn't have one
Offline wodan
Re: [GB] X60
« Reply #1040 on: Wed, 30 November 2016, 01:19:25 »
A whimpy diffuser is just going to save weight. I bet it there was a way to do it, xondat would have made this keyboard out of cast iron.
Offline duynguyenle
  • Personal text? What personal text???
Re: [GB] X60
« Reply #1041 on: Wed, 30 November 2016, 02:36:05 »
Nah, nickel alloy  :p
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline Khers
  • Schrödinger's box
Re: [GB] X60
« Reply #1042 on: Wed, 30 November 2016, 02:46:29 »
Shot peened titanium with a tungsten plate and weight.
Offline jchan94
  • Keyclack Inc
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
Re: [GB] X60
« Reply #1043 on: Wed, 30 November 2016, 03:28:40 »
Progress is looking good! I really like that logo that everyone is liking above.
Hard anodizing is amazing and it's nice to see it go this way. Can't wait to see a new prototype from the new manufacturer since I'm sure you want to see their quality before running full production!
Good luck Xondat :D
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
Offline jorgenslee
Re: [GB] X60
« Reply #1044 on: Wed, 30 November 2016, 05:28:51 »
Good luck Xondat :D
AFAIK, production has already been started and hard anodizing was dropped last month.
Offline trexous
Re: [GB] X60
« Reply #1045 on: Wed, 30 November 2016, 11:10:41 »
if anyone drops out ill happily take your spot (:
Offline pace8500
Re: [GB] X60
« Reply #1046 on: Wed, 30 November 2016, 11:59:37 »
I managed to get this swapped!
Now if anyone wants to swap their dark gray ANSI plate for my dark gray universal plate then let me know.
Offline xondat
  • i'm not a star
Re: [GB] X60
« Reply #1047 on: Thu, 01 December 2016, 12:27:09 »
Clean as **** - I love it. I'll have this made/mocked up on the weight, and this will most likely be the engraving.
Diffuser doesn't work with the alignment tabs. Maybe for V2.
I was actually going to have a full stainless steel case made, but I passed for some reason, probably because I have no idea how it'd be finished.
P.S. I have 10 extra cases that I've not sold yet, but had made, so those will probably be for sale when I commence shipping.
P.P.S. I should be trialling some new shipping boxes, methods, and packaging within the next couple of weeks. No custom packaging this time, maybe for X65 though.
Offline Khers
  • Schrödinger's box
Re: [GB] X60
« Reply #1048 on: Thu, 01 December 2016, 12:32:16 »
:thumb:
Offline jessica
Re: [GB] X60
« Reply #1049 on: Thu, 01 December 2016, 12:43:45 »
WOOT
