Author Topic: I need ideas for programmable keypad settings!  (Read 2701 times)
Offline QuincyJones
« on: Wed, 15 June 2016, 04:42:57 »
What shortcuts have you got mapped to your keys, either direct shortcuts or through software like AHK?
Post there here and let's share some ideas to make our life even better!
My ideas so far:
Visual Studio:
debug start, stop, pause, restart, current line, step in, step over, step out
next file (ctrl+tab), previous file
team explorer view
save all files
generic:
winamp open, winamp play, next track in playlist, vol up/down
« Last Edit: Wed, 15 June 2016, 04:47:54 by QuincyJones »
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline lee+
Re: I need ideas for programmable keypad settings!
« Reply #1 on: Sat, 18 June 2016, 16:52:16 »
Key Down                A       5       GotoPage 0p 1p
Key Left                A       5       GotoPage -1p 0p
Key Right               A       5       GotoPage 1p 0p
Key Up                  A       5       GotoPage 0p -1p
Key Home                W       5       Resize
Key F1                  W       S       Function EighthReplace
Key F1         A   S1   Function StartClient
Key F2                  W       S       Function QuarterReplace
Key F2                  A       S1      Function StartSeamonkeyLocal
Key F3                  W       S       Function HalfReplace
Key F4                  W       S       Function MvCenter
Key F5                  W       S       Function GrowReplace
Key F6                  W       S       Function WidenReplace
Key F7                  W       S       Function set1920
Key F8                  W       S       Function set2560
Key F9                  W       S       Function rightReplace
Key F9                  W       S1      Function leftReplace
Key F10                 W       S       Stick
Key F10                 W       S1      Function FuncToggleLayer
Key F11                 A       S       Menu MenuScreenshot
Key F11                 W       S1      Function ToggleDecor
Key F12                 W       S       Maximize
Key F12                 W       S1      Iconify
Key Menu                W       A       Menu MenuArrangeWindows
Key Menu                A       1       Menu MenuFvwmRoot
Key Print               A       A       Screenshot
Key Pause               A       A       Screenshot-Frame
Key Tab                 A       4       WindowList
Key Tab                 W       1       RaiseLower
My current keyboard doesn't have a menu key, so that is subject to change.  I could sure use a couple more keys.
Do you have some extra key to switch between different layers of keybindings once the keys are programmed?
(Not that I really understand why one would need a programmable keyboard, since all keys can be assigned with something and then some more and yet something else on top of that.  The problem is how to remember what you put onto which key.)
« Last Edit: Sat, 18 June 2016, 16:57:51 by lee+ »
Offline Morituri
« Reply #2 on: Sun, 19 June 2016, 13:37:02 »
Huh.  It looks like most people are using macros for "doing things".  I'm using them mostly for "typing things."
I'm using cap lock (whose original purpose is nearly useless to me) as a modifier key to invoke a macro layer.  So CL should be read as "holding down that key."
CL- most of the alphabetic keys --> Greek alphabet
CL- numeric keys --> ∀ ∃ ∄ ∋ ∌ ∧∨∩∪ ∅
CL-much of spacing punctuation --> combining accents. (, for cedilla, ` for grave, ' for acute, " for umlaut, - and / for different kinds of strikeout, _ for underline, = for double underscore, . for dot-below, ^ for circumflex  etc, Basically whatever combining accent they sorta look like, plus some arbitrary mappings like @, &, * for circle-above, overbar, and breve).
CL-!  is ¡ and CL-? is ¿, CL-< is  « and CL-> is » (Spanish inverted punctuation and french quotation marks)
CL-numpad *  /  + - for  ×  ÷ ± ≅
CL-numpad 2, 3, 4 for √, ∛, ∜ (roots)
CL-numpad 8 for ∞ (infinity)
several others but you should see a geeky pattern emerging....
« Last Edit: Sun, 19 June 2016, 13:51:47 by Morituri »
We're going to solve strong AI.  Then it's going to solve us.
