Author Topic: Why are ALP's switches no longer used.  (Read 13593 times)
Offline megarat
  • (Not My Real Name)
    • http://www.megarat.com
« Reply #50 on: Tue, 05 January 2010, 05:58:23 »
Out of curiosity, are the Wang's keys double-shot injection molded?
If so, I may need to grab a Wang.
Home/Work:  Custom Filco FKBN87Z/EB and SGI 041-0136-001 chimera (original white ALPS, not simplified, rubber-dampened)
Gaming:  Wolfking Warrior with custom-colored layout, HHKB Lite 2 (Rubber dome)
Offline itlnstln
« Reply #51 on: Tue, 05 January 2010, 09:11:47 »
Quote from: megarat;148090
Just don't grab mine.
Offline didjamatic
« Reply #52 on: Tue, 05 January 2010, 12:17:25 »
Just be careful, it may lead to your demise.
Offline ch_123
« Reply #53 on: Tue, 05 January 2010, 12:20:14 »
Quote from: keyb_gr;146494
It could be worse.
Logitech Waves are reasonably alright I must say. I remember someone claiming that they reminded them of Black Alps. The worst thing about them is the large web browser media key which has a big blue Internet Explorer icon on it... Although that picture doesn't have one, so maybe the one I used was an older version.
« Last Edit: Tue, 05 January 2010, 12:22:54 by ch_123 »
Offline Mental Hobbit
« Reply #54 on: Tue, 05 January 2010, 12:29:59 »
Quote from: ch_123;148146
Their appearance rather reminds me of cowpie.
Typing on blues.
Offline itlnstln
« Reply #55 on: Tue, 05 January 2010, 12:41:53 »
That was me. I was rather impressed by the Logitech Waves. It seems that they use a different rubber dome setup for that 'board than they do their others. Basically, it's lighter and more crisp and feels like it has a similar force curve and resistance as black ALPS (complicated, like those in the Dell) but not as plasticky feeling as you might imgine. IMO, Logitech keyboards are like typing on stiff sponges. I can't validate, let alone describe, any physical differences between the Wave or their other offerings, but the ones I have tried at stores and a co-worker's, they are pretty consistant and rather nice (for domes). The biggest drawback of the Wave is that there are no Lock lights on the 'board, so you have to install some software to get some temporary notifications on the screen.
