Author Topic: Difficulty reflashing RS84  (Read 2512 times)
Offline Auxo
  • Formerly CJD_Anthony
« on: Wed, 29 June 2016, 19:12:57 »
Hey guys,
I just recently got an RS84 from a seller and I love the keyboard, but I wanted to change the layout as it had some functions that I have no use for. I tried to read the manual but it is a bit confusing, and I don't think I'm understanding the instructions correctly. Is there anybody out there who can help me reflash this RS84? Here is the layout I currently want...
http://www.keyboard-layout-editor.com/#/gists/ba69b636fda9b645e6c3e66f2be994d0
I tried to reflash, and I only got as far as installing Java and enabling the TMK, but I am kind of lost on what to do... Can anybody lend a hand?
I can't seem to download the .eep file even after downloading the TMK chrome extension
Thank you!
Edit: this is the thread I was trying to follow... then things got really confusing and I don't really follow what anybody is doing on that thread
https://geekhack.org/index.php?topic=69282.0
« Last Edit: Wed, 29 June 2016, 23:30:52 by CJD_Anthony »
Offline Auxo
Re: Difficulty reflashing RS84
« Reply #1 on: Wed, 29 June 2016, 23:31:12 »
Hey guys,
Thank you!
Edit: nvm got it thank you
« Reply #2 on: Wed, 29 June 2016, 23:35:22 »
You could always share how you actually got it working as I'm sure someone else will have the same question later. :D
Offline ebacho
« Reply #3 on: Thu, 30 June 2016, 00:05:43 »
I was the seller, and here was the PM I sent him:
Quote from: ebacho
Try this:
0. Put board in EEP Flash mode (hold esc while plugging it in - should be detected as a printer.
1. Start with this layout: http://www.keyboard-layout-editor.com/##@@_a:6%3B&=Esc&=F1&=F2&=F3&=F4&=F5&=F6&=F7&=F8&=F9&=F10&=F11&=F12&_a:5%3B&=PrtSc%0ANmLk&=Pause%0AScrLk&=Delete%0AInsert%3B&@_a:4%3B&=~%0A%60&=!%0A1&=%2F@%0A2&=%23%0A3&=$%0A4&=%25%0A5&=%5E%0A6&=%2F&%0A7&=*%0A8&=(%0A9&=)%0A0&=%2F_%0A-&=+%0A%2F=&_a:6&w:2%3B&=Backspace&=Home%3B&@_a:4&w:1.5%3B&=Tab&=Q&=W&=E&=R&=T&=Y&=U&=I&=O&=P&=%7B%0A%5B&=%7D%0A%5D&_w:1.5%3B&=%7C%0A%5C&_a:6%3B&=Page%20Up%3B&@_a:4&w:1.75%3B&=Caps%20Lock&=A&=S&=D&=F&=G&=H&=J&=K&=L&=%2F:%0A%2F%3B&=%22%0A%27&_a:6&w:2.25%3B&=Enter&=Page%20Down%3B&@_w:2.25%3B&=Shift&_a:4%3B&=Z&=X&=C&=V&=B&=N&=M&=%3C%0A,&=%3E%0A.&=%3F%0A%2F%2F&_a:6&w:1.75%3B&=Shift&_a:7%3B&=%E2%86%91&_a:6%3B&=End%3B&@_w:1.5%3B&=Ctrl&_w:1.5%3B&=Alt&_a:7&w:7%3B&=&_a:6&w:1.5%3B&=Alt&_w:1.5%3B&=Ctrl&_a:7%3B&=%E2%86%90&=%E2%86%93&=%E2%86%92
You might need to edit labels to match the supported tmk.io labels.
Change what you need using symbols here and editing top and bottom labels (valid symbols here: http://tkg.io/#help)
2. Click raw data on the layout generator and paste that into layer 1 on the tkg eep generator (at the tkg.io site).  Data should look like so:
[{a:6},"Esc","F1","F2","F3","F4","F5","F6","F7","F8","F9","F10","F11","F12",{a:5},"PrtSc\nNmLk","Pause\nScrLk","Delete\nInsert"],
[{a:4},"~\n`","!\n1","@\n2","#\n3","$\n4","%\n5","^\n6","&\n7","*\n8","(\n9",")\n0","_\n-","+\n=",{a:6,w:2},"Backspace","Home"],
[{a:4,w:1.5},"Tab","Q","W","E","R","T","Y","U","I","O","P","{\n[","}\n]",{w:1.5},"|\n\\",{a:6},"Page Up"],
[{a:4,w:1.75},"Caps Lock","A","S","D","F","G","H","J","K","L",":\n;","\"\n'",{a:6,w:2.25},"Enter","Page Down"],
[{w:2.25},"Shift",{a:4},"Z","X","C","V","B","N","M","<\n,",">\n.","?\n/",{a:6,w:1.75},"Shift",{a:7},"↑",{a:6},"End"],
[{w:1.5},"Ctrl",{w:1.5},"Alt",{a:7,w:7},"",{a:6,w:1.5},"Alt",{w:1.5},"Ctrl",{a:7},"←","↓","→"]
Choose 1 layer and RedScarfIII as the keyboard.
3. Setup the print plugin as outlined in the pdf and click download eep.
4. Check your print queue to see if it executed correctly.
Hope this helps other people too.
Offline ntw
« Reply #4 on: Thu, 30 June 2016, 08:40:52 »
you forgot to list out the most difficult step before step 0.
step (-1). Acquire a RS84
